Old 02-23-2019, 05:37 PM   #1
Default 2017 Chevrolet Express 3500 10.5" Floater Rear Axle Assembly
This axle was removed from a 2017 Chevrolet Express 3500 with less than 5000 miles. This axle is an American Axle 10.5" FREE floating design 3.54 ratio NON locking. with JL4 anti lock brakes. 8 lug on 165mm. I purchased 2 of these through a GM bid program I am in and was going to use to upgrade my RV and a friends. I went with a dually axle so no longer need.
Will fit all 2010-2019 Chevrolet Express and GMC Savana with GHO or GU6 Option codes (single rear wheel) Gas engine will need pinion yoke changed and computer programmed for gear ratio change. Diesel is a direct bolt in. This axle is stronger than the 9.5"
Has been sitting out side so rotors are rusty but will clean up. $600.00
Pickup in SE Michigan or can ship freight.
valvegod is offline   Reply With Quote
