02-23-2019, 12:56 PM
2018 Chevrolet Express Roadtrek Wheels & Tires LIKE NEW TAKE OFFs
Selling my LIKE NEW take off aluminum wheels, tires, TPMS and spare. I converted to a dually rear axle so do not need. Only 2,400 miles on tires and wheels. LT245/75R/16 Bridgestone V-Steel Rib 265. E Load Rating . Excellent condition. Roadtrek wheels 16x7.5" approx 3.5" back spacing load rating 3250 LB. 8 lug on 165.1 mm bolt pattern, 131 mm center bore. These will fit any 8 lug Chevy Express & GMC Savana 2500 or 3500. $1,800
4) Aluminum Wheels with center caps, tires and TPMS (sensors) 2,400 miles
1) Steel GM spare with tire zero miles.
Pickup in SE Michigan or can ship freight (extra cost).
02-23-2019, 01:52 PM
If you get a chance, would you be able to take a look at them and see what the offset is? Most aluminum wheels would have it marked on the back side of them, but may need to be measured.
We haven't had much information on the newer versions of the Chevy Roadtrek aluminum wheels, so it would be very interesting.
02-23-2019, 04:35 PM
with tires on and not being able to measure the thickness of the bead, they appear to be 16x7.5" (maybe 16x7") with approx 3.5" back spacing.
02-23-2019, 06:06 PM
Thanks, valvegod, that would indicate a zero offset or slightly minus, which typical for aftermarket wheels, like older AR were also, and quite wrong for the Express vans, IMO, which are stock at +28mm offset.
You should be able to measure the offset directly by laying it on by putting a board across the tire side wall and measure to the wheel mounting surface from the inside and outside of the tire. I am surprised the wheels aren't marked with size and load capacity, as that is pretty important on aluminum wheels, especially cast ones.
02-23-2019, 06:25 PM
they normally measure from the inside of the bead for wheel width, offset and back spacing but beads are buried in the tire wall so cannot be specific. The load capacity on the wheels are 3250 lbs. just no size listed. only part numbers, casting numbers etc.
02-23-2019, 06:55 PM
That is the normal way to measure a wheel, but with tires on you can't ever do that accurately. The tires locate off the inside of the wheel bead, and the tires should be symmetrical, so you can take the outside of the sidewall to wheel locating surface and subtract them/2 for offset, but it doesn't work for wheel width or backspace.
06-07-2019, 01:04 AM
Do you still have the wheels for sale?
03-13-2020, 11:45 PM
Was it difficult to convert to duallies? Was it expensive? I'd like to do that, but I'm not sure what I'm getting into.
03-13-2020, 11:56 PM
