Old 04-08-2014, 12:23 PM   #1
Default Ram Promaster Recalls
RECALL Subject : Brake Fluid Leakage From Brake Hose
Report Receipt Date: FEB 04, 2014
NHTSA Campaign Number: 14V034000
Manufacturer: Chrysler Group LLC
SUMMARY:
Chrysler Group LLC (Chrysler) is recalling certain model year 2014 Ram ProMaster vehicles manufactured July 1, 2013, through November 15, 2013. During manufacturing, a tool may have damaged one of the brake hoses which may result in a leakage of brake fluid from the brake hose.
CONSEQUENCE:
Brake fluid leakage would result in a reduction of brake performance, lengthening the distance needed to stop the vehicle, increasing the risk of a crash.
REMEDY:
Chrysler will notify owners, and dealers will inspect and replace the brake hoses, as necessary, free of charge. The recall began on March 26, 2014. Owners may contact Chrysler at 1-800-853-1403. Chrysler's number for this recall is P03.
NOTES:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
Old 04-08-2014, 12:24 PM   #2
Default Re: Ram Promaster Recalls
RECALL Subject : Stuck Pedal with Wide Open Throttle
NHTSA Campaign Number: 14V032000
Component(s): VEHICLE SPEED CONTROL
SUMMARY:
Chrysler Group LLC (Chrysler) is recalling certain model year 2014 Ram ProMaster vehicles manufactured July 1, 2013, through December 10, 2013. In the affected vehicles, if the accelerator pedal is pushed downward at a certain angle, the pedal may get stuck in the wide open throttle position due to interference with the accelerator pedal stopper.
CONSEQUENCE:
A stuck accelerator pedal can result in uncontrolled acceleration, increasing the risk of a crash.
REMEDY:
Chrysler will notify owners and dealers will replace the accelerator pedal stopper with a larger one, free of charge. The recall is began on March 27, 2014. Owners may contact Chrysler at 1-800-853-1403. Chrysler's number for this recall is P02. Note: These vehicles are equipped with a brake override system. In the event a pedal is trapped, pushing on the brake pedal will brake the vehicle and enable the driver to slow and stop and turn off the vehicle.
NOTES:
Old 01-15-2015, 01:58 PM   #3
RECALL Subject : Head Restraint Exceeds Measurement/FMVSS 202a
Report Receipt Date: SEP 04, 2014
NHTSA Campaign Number: 14V533000
Component(s): SEATS
SUMMARY:
Chrysler Group LLC (Chrysler) is recalling all model year 2014 Ram ProMaster vans manufactured July 1, 2013, to August 26, 2014. The affected vehicles may have been manufactured with head restraints that exceed the maximum backset measurement limit of 55mm. As such, these vehicles fail to comply with the requirements of the Federal Motor Vehicle Safety Standard No. 202a, "Head Restraints."
CONSEQUENCE:
If the vehicle is struck from behind, the head restraint may not properly limit the seat occupant's head movement rearward, increasing the risk of injury.
REMEDY:
Chrysler will notify owners, and dealers will replace the head restraints, free of charge. The recall began on December 1, 2014. Owners may contact Chrysler customer service at 1-800-853-1403. Chrysler's number for this recall is P53.
NOTES:
Old 01-15-2015, 01:59 PM   #4
RECALL Subject : TPMS may not Locate Sensors/FMVSS 138
Report Receipt Date: OCT 08, 2014
NHTSA Campaign Number: 14V633000
Component(s): TIRES
SUMMARY:
Chrysler Group LLC (Chrysler) is recalling certain model year 2014 Ram ProMaster vehicles manufactured April 23, 2013, to August 22, 2014. In the affected vehicles, the Tire Pressure Monitoring System (TPMS) may fail to learn the locations of the individual sensors while the vehicle is being driven. As a result, the low tire pressure warning light will illuminate, despite the the tire pressures being within specification. Should one of the tires lose air pressure, the driver would not be notified of the change in air pressure. As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard No. 138, "Tire Pressure Monitoring Systems."
CONSEQUENCE:
If the TPMS light illuminates because the sensors cannot be located, it could mask an actual low tire pressure condition, possibly resulting in tire failure, increasing the risk of a crash.
REMEDY:
Chrysler will notify owners, and dealers will update the TPMS module with new software, free of charge. The recall began on December 8, 2014. Owners may contact Chrysler customer service at 1-800-853-1403. Chrysler's number for this recall is P62.
NOTES:
Old 02-08-2016, 06:15 PM   #5
RECALL Subject : Intermittent Loss of Ignition Switch Contact
Report Receipt Date: NOV 25, 2015
NHTSA Campaign Number: 15V799000
Component(s): ELECTRICAL SYSTEM
Manufacturer: Chrysler (FCA US LLC)
SUMMARY:
Chrysler (FCA US LLC) is recalling certain model year 2015 Ram ProMaster vans manufactured October 1, 2014, to June 17, 2015. The affected vehicles have an ignition switch that may experience an intermittent loss of electrical contact.
CONSEQUENCE:
An intermittent loss of contact can result in a vehicle stall and/or a partial or complete loss of the air bags, anti-lock brakes, electronic stability control and/or instrument panel cluster. Loss of functionality of these systems may increase the risk of crash and/or increase the risk of injury in the event of a crash.
REMEDY:
Chrysler will notify owners, and dealers will replace the ignition switch contact holder block, free of charge. Owners were sent interim notices on January 8, 2016. Owners will receive a second notice when remedy parts become available. Owners may contact Chrysler customer service at 1-800-853-1403. Chrysler's number for this recall is R64.
NOTES:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to Home | Safercar -- National Highway Traffic Safety Administration (NHTSA).
Old 02-09-2016, 03:07 PM   #6
Just out of interest, have there been prior recalls too?
sheral is offline   Reply With Quote
Old 02-09-2016, 05:02 PM   #7
There could be other recalls on all makes & models etc. I post recalls when I see them so I'm sure I've missed some.
Check for recalls here: Keeping You Safe | Safercar | National Highway Traffic Safety Administration (NHTSA)
and here: Motor Vehicle Safety Recalls Database
Old 10-22-2016, 01:50 AM   #8
Default Winnebago Travato 59k diesel recall
I just received a recall notice from Winnebago concerning an improperly tightened connection on the 120v automatic transfer switch. This covers 'certain 2015-2017 Winnebago Era, Travato, Fuse, Aspect and Vista and Itasca Cambria and Sunstar motorhomes.
My question is does anyone know where this switch is on a Winnebago Travato 59k. I will get mine into the dealer but that involves a 2 day trip so I'd like to check it before I go. Thanks
emare is offline   Reply With Quote
Old 10-22-2016, 02:32 AM   #9
On Wincrasher's website blog about installing a surge protector he has info and pictures of it.
http://wincrasher.blogspot.com/2016/...stall.html?m=1
JamesM is offline   Reply With Quote
Old 10-22-2016, 07:34 PM   #10
Wincrasher's blog and pics were very helpful. The terminals did need tightening, all a quarter turn and some more. Glad I got the heads up. Will get the dealer to check them when I'm in the neighbourhood.
