Old 10-29-2006, 01:46 PM   #1
Default Roadtrek / Home & Park Motorhomes - Recalls
Make / Models : Model/Build Years:
HOME AND PARK / ROADTREK 170 2005-2006
HOME AND PARK / ROADTREK 190 2005-2006
HOME AND PARK / ROADTREK 210 2005-2006
Manufacturer : HOME & PARK MOTORHOMES
NHTSA CAMPAIGN ID Number : 05V533000 Mfg's Report Date : OCT 27, 2005
Component: EQUIPMENT:RECREATIONAL VEHICLE:LPG LINES AND FITTINGS
Potential Number Of Units Affected : 381
Summary:
ON CERTAIN CLASS B MOTOR HOMES BUILT ON CHEVROLET CHASSIS AND EQUIPPED WITH PROPANE BBQ CONNECTION. A RUBBER HOSE IS CONNECTED TO THE PROPANE REGULATOR AT ONE END AND HAS A BRASS SHUTOFF VALVE CONNECTOR ON THE OTHER "FREE END." THE CLAMP USED FOR HOLDING THE BRASS BBQ SHUTOFF VALVE IS NOT INSERTED PROPERLY INTO ITS HOLDING CLAMP.
Consequence:
SINCE THE RESTRAINING CLAMP IS MISSING, THE HOSE CAN BOUNCE UP AND DOWN. AS THE VEHICLE IS DRIVEN, THE CONNECTOR CAN FALL TO THE GROUND DRAGGING ONTO THE PAVEMENT AND COULD WEAR A HOLE THROUGH THE HOSE. PROPANE CAN LEAK OUT CREATING THE POTENTIAL FOR A FIRE.
Remedy:
DEALERS WILL INSPECT THE BBQ HOSE CONNECTOR ASSEMBLY, CHECK FOR ANY WEAR, AND REPLACE UNITS. THE UNITS WILL BE RESTRAINED AND CLAMPS WILL BE ADDED TO LIMIT THE LENGTH OF THE FREE END OF THE HOSE. THE RECALL BEGAN ON NOVEMBER 28, 2005. OWNERS MAY CONTACT HOME AND PARK AT 888-762-3873.
Notes:
CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO http://WWW.SAFERCAR.GOV.
Old 10-29-2006, 01:50 PM   #2
HOME AND PARK / ROADTREK 2006
HOME AND PARK / ROADTREK 170 2007
HOME AND PARK / ROADTREK 190 2003-2006
HOME AND PARK / ROADTREK 210 2003-2006
NHTSA CAMPAIGN ID Number : 06V160000 Mfg's Report Date : MAY 03, 2006
Component: EQUIPMENT:OTHER:LABELS
Potential Number Of Units Affected : 736
Summary:
ON CERTAIN MOTOR HOMES BUILT ON CHEVROLET CHASSIS AND EQUIPPED WITH A DECORATIVE DASH TRIM KIT, THE ADHESIVE BACKED SYNTHETIC TRIM IS ATTACHED TO THE DASH, ENGINE COVER, DOOR PANEL AND THE CHEVROLET "BOW TIE" DECAL IS ATTACHED TO THE STEERING WHEEL (DIRECTLY OVER THE EXISTING BOW TIE IMPRESSION). THIS DECAL COULD AFFECT THE DEPLOYMENT OF THE AIR BAG SAFETY RESTRAINT BUILT INTO THE STEERING WHEEL.
Consequence:
IN THE EVENT OF A VEHICLE CRASH IN WHICH THE DRIVER SIDE AIR BAG IS DEPLOYED, THE RESULTING FUNCTIONALITY OF THE AIR BAG IS UNCERTAIN, WHICH CAN INCREASE THE RISK OF INJURY TO VEHICLE OCCUPANTS.
Remedy:
OWNERS WILL BE INSTRUCTED TO REMOVE THE STEERING WHEEL DECAL. THE RECALL BEGAN ON MAY 30, 2006. OWNERS MAY CONTACT HOME AND PARK AT 1-800-663-0066.
Notes:
Old 10-29-2006, 02:09 PM   #3
HOME AND PARK / ROADTREK 210 2006
NHTSA CAMPAIGN ID Number : 06V070000 Mfg's Report Date : MAR 06, 2006
Component: SUSPENSION:REAR:AXLE:SPINDLE
Potential Number Of Units Affected : 51
Summary:
ON CERTAIN CLASS B MOTOR HOMES BUILT ON CHEVROLET CHASSIS, WHEN THE REAR AXLE LIFT KIT WAS INSTALLED, THE U-BOLT NUTS WERE NOT TIGHTENED PROPERLY.
Consequence:
A LOOSE REAR AXLE CAN CREATE A SLUGGISH DRIVING FEELING, REAR BOUNCING AND LOUD BANGING NOISE, INCREASING THE RISK OF A CRASH.
Remedy:
DEALERS WILL INSPECT AND RETIGHTEN THE U-BOLTS FREEE OF CHARGE. THE RECALL BEGAN ON MARCH 30, 2006. OWNERS MAY CONTACT ROADTREK AT 888-762-3873.
Notes:
Old 10-29-2006, 03:13 PM   #4
HOME AND PARK / ROADTREK 1998
NHTSA CAMPAIGN ID Number : 98V136000 Mfg's Report Date : JUN 22, 1998
Component: FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY:FILLER PIPE AND CAP
Potential Number Of Units Affected : 404
Summary:
VEHICLE DESCRIPTION: CLASS 'B' MOTOR HOMES BUILT ON DODGE 1500, 2500 AND 3500 VAN CHASSIS. THE FUELVENT HOSE FROM THE FUEL TANK TO THE FUEL FILL ENTRY MAY NOT BE VAPOR TIGHT DUE TO OVER TIGHTENING OF THE GEAR CLAMP AT THE CONNECTION OF THE PLASTIC VENT TANK OUTAGE TO THE RUBBER VENT HOSE. THIS CAN RESULT IN FUEL OR FUEL VAPOR LEAKING.
Consequence:
THIS CONDITION CAN CAUSE FUEL OR FUEL VAPOR LEAKING RESULTING IN A POTENTIAL FIRE HAZARD. ALSO THE ENGINE COULD STALL FROM LACK OF FUEL, RESULTING IN LOSS OF POWER BRAKING AND POWER STEERING CONTROL.
Remedy:
DEALERS WILL REMOVE THE GEAR CLAMP SECURING THE RUBBER VENT HOSE TO THE PLASTIC VENT TUBE, INSTALL A RIGID INSERT TUBE INTO THE PLASTIC VENT TUBE, AND REATTACH THE HOSE AND CLAMP. THE RIBERGLASS COVER IN THE RUNNING BOARD STORAGE COMPARTMENT MUST FIRST BE REMOVED FOR ACCESS.
Notes:
OWNER NOTIFICATION BEGAN JUNE 24, 1998. OWNERS WHO TAKE THEIR MOTOR HOMES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HOME & PARK AT 1-888-ROADTREK (1-888-762-3873). ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Old 10-29-2006, 04:00 PM   #5
HOME AND PARK / ROADTREK 1998-1999
NHTSA CAMPAIGN ID Number : 99V335000 Mfg's Report Date : NOV 24, 1999
Potential Number Of Units Affected : 606
Summary:
VEHICLE DESCRIPTION: CLASS B MOTOR HOMES BUILT ON DODGE 3500 OR 2500 VAN CHASSIS. THE GENERATOR FUEL PICKUP FITTING WAS SELF TAPPED INTO A DRILLED HOLE BESIDE THE FUEL SENDING UNIT ON TOP OF THE PLASTIC FUEL TANK. SEALANT WAS USED ON THE THREAD BEFORE THE FITTING WAS SCREWED INTO THE TANK. ON SOME VEHICLES, THE FUEL PICKUP FITTING WAS NOT SEALED PROPERLY AGAINST THE TANK WALL, AND WHEN THE TANK IS FULL, FUEL OR FUEL VAPORS CAN LEAK OUT.
Consequence:
IN A CRASH, FUEL OR FUEL VAPORS CAN LEAK WHEN THE TANK IS FULL, INCREASING THE RISK OF A FIRE.
Remedy:
DEALERS WILL REPLACE THE SELF TAPPING FUEL PICKUP WITH A NEW ONE WITH REGULAR THREAD FITTING SECURED TO THE TANK WITH A LOCK NUT INSIDE THE TANK.
Notes:
OWNER NOTIFICATION BEGAN DECEMBER 19, 1999. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HOME & PARK AT 1-888-ROADTREK (1-888-762-3873). ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Old 10-29-2006, 04:02 PM   #6
HOME AND PARK / ROADTREK 170 1999-2000
HOME AND PARK / ROADTREK 190 1999-2000
HOME AND PARK / ROADTREK 200 1998-2000
NHTSA CAMPAIGN ID Number : 00V234000 Mfg's Report Date : AUG 21, 2000
Component: VISIBILITY:WINDSHIELD
Potential Number Of Units Affected : 711
Summary:
VEHICLE DESCRIPTION: MOTOR HOMES BUILT ON DODGE 2500/3500 VAN CHASSIS AND ON CHEVROLET G-CUT AWAY VAN CHASSIS. THESE MOTOR HOMES WERE BUILT USING FRAMELESS WINDOWS. SOME OF THESE WINDOWS MAY HAVE NOT BONDED CORRECTLY.
Consequence:
WHEN THE WINDOWS ARE OPENED/CLOSED, OR WHEN LITTLE PRESSURE IS APPLIED TO THE VENT GLASS, THE BONDING CAN GIVE UP PRODUCING A DELAMINATION BETWEEN VENT GLASS AND ALUMINUM.
Remedy:
DEALERS WILL REPLACE THE AFFECTED WINDOWS WITH NEW ONES.
Notes:
OWNER NOTIFICATION BEGAN SEPTEMBER 2000. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HOME & PARK AT 1-888-762-3873. ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Old 10-29-2006, 04:03 PM   #7
HOME AND PARK / ROADTREK 200 1997-2000
NHTSA CAMPAIGN ID Number : 00V333000 Mfg's Report Date : OCT 18, 2000
Component: FUEL SYSTEM, GASOLINEELIVERY:HOSES, LINES/PIPING, AND FITTINGS
Potential Number Of Units Affected : 813
Summary:
VEHICLE DESCRIPTION: CLASS B MOTOR HOMES BUILT ON CHEVROLET G-CUT AWAY VAN CHASSIS EQUIPPED WITH AN AFTER-MARKET GASOLINE TANK MANUFACTURED BY TRANSFER FLOW INC. OF CALIFORNIA. THE TANK INCORPORATES A ROLLOVER VALVE AND A 5/8" RUBBER VENT HOSE EXTENDING FROM THE TOP OF THE TANK. IT IS POSSIBLE, WITH THE MOUNTING OF THE FIBERGLASS BODY, THE VENT HOSE CAN BE CHAFFED FROM THE FIBERGLASS BODY UNDERSIDE.
Consequence:
THIS COULD CAUSE A FUEL VAPOR LEAK WHICH COULD LEAD TO A FIRE OR EXPLOSION.
Remedy:
DEALERS WILL LOWER THE GASOLINE TANK TO INSTALL A SPACER SHIM. THIS SPACER PROVIDES THE NECESSARY CLEARANCE FOR THE VENT HOSE FROM THE VEHICLE UNDERSIDE.
Notes:
HOME & PARK'S RECALL NUMBER IS 2000-02. OWNER NOTIFICATION BEGAN NOVEMBER 18, 2000. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HOME & PARK AT 1-888-762-3873. ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Old 10-29-2006, 04:06 PM   #8
HOME AND PARK / ROADTREK 2000-2002
NHTSA CAMPAIGN ID Number : 02V206000 Mfg's Report Date : JUL 26, 2002
Component: SEAT BELTS:FRONT:ANCHORAGE
Potential Number Of Units Affected : 249
Summary:
ON CERTAIN MOTOR HOMES BUILT ON CHEVROLET G-VAN CHASSIS, IT IS POSSIBLE, THAT ON SOME UNITS, THE PASSENGER SIDE SEAT BELT WAS NOT ASSEMBLED CORRECTLY TO THE STRUCTURAL MEMBER OF THE VEHICLE. THE SWIVEL PLATE MAY NOT BE ATTACHED TO THE BOLT HOLDING THE RETRACTOR ASSEMBLY.
Consequence:
IN THE EVENT OF A CRASH, THE SEAT OCCUPANT MAY NOT BE PROPERLY RESTRAINED INCREASING THE RISK OF PERSONAL INJURY.
Remedy:
DEALERS WILL REMOVE AND REINSTALL THE SWIVEL PLATE CORRECTLY. OWNER NOTIFICATION BEGAN JULY 25, 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HOME & PARK AT 1-888-762-3873.
Notes:
ALSO, CUSTOMERS CAN CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Old 10-29-2006, 04:08 PM   #9
HOME AND PARK / CONTINENTAL KIT 9999
NHTSA CAMPAIGN ID Number : 04E075000 Mfg's Report Date : SEP 16, 2004
Potential Number Of Units Affected : 150
Summary:
AFTERMARKET CONTINENTAL KIT SPARE TIRE CARRIERS H&P P/N 02010001/02044500 AND ARE DESIGNED TO BE USED ON CLASS B MOTORHOMES ROADTREK 170, 190 AND 210 MODELS, BUILT ON CHEVROLET 2500/3500 VAN CHASSIS. DUE TO THE DESIGN OF THE SPARE TIRE CARRIER, VIBRATION/STRESS CAN FATIGUE THE BRACKET AND LEAD TO FRACTURE.
Consequence:
IF THE BRAKET BREAKS, CONTINUOUS VIBRATION MAY CAUSE THE CARRIER TO SLOWLY SLIDE OUT OF THE TRAILER HITCH CROSSTUBE AND FALL ON THE ROAD, POSSIBLY RESULTING IN A VEHICLE CRASH.
Remedy:
HOME & PARK WILL NOTIFY ITS CUSTOMERS AND REPAIR THE CARRIES BY SOLIDLY WELDING THEM TO THE CROSSTUBE.
Notes:
ALSO, CUSTOMERS CAN CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Old 10-29-2006, 04:14 PM   #10
HOME AND PARK / ROADTREK 170 2003-2004
HOME AND PARK / ROADTREK 190 2003-2004
HOME AND PARK / ROADTREK 210 2003-2004
NHTSA CAMPAIGN ID Number : 04V546000 Mfg's Report Date : NOV 11, 2004
Component: TIRES:VALVE
Potential Number Of Units Affected : 660
Summary:
ON CERTAIN MOTOR HOMES BUILT ON CHEVROLET 2500/3500 VAN CHASSIS, WHILE REPLACING THE STEEL RIMS WITH ALUMINUM RIMS, INCORRECT VALVE STEMS WITH INCORRECT PRESSURE RATING LOWER THAN THE MAXIMUM PRESSURE ALLOWED FOR THE TIRES WERE INSTALLED.
Consequence:
SOME VALVES MAY LEAK AIR INCREASING THE RISK OF A TIRE FAILURE. THIS COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL REPLACE THE VALVE STEMS. THE RECALL BEGAN IN NOVEMBER 2004. OWNERS SHOULD CONTACT HOME & PARK AT 1-888-762-3873.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Old 10-29-2006, 04:24 PM   #11
HOME AND PARK / ROADTREK 170 2000
HOME AND PARK / ROADTREK 190 2000
NHTSA CAMPAIGN ID Number : 00V273009 Mfg's Report Date : OCT 18, 2000
Component: SEAT BELTS:FRONT:BUCKLE ASSEMBLY
Potential Number Of Units Affected : 230
Summary:
VEHICLE DESCRIPTION: CERTAIN CLASS B MOTOR HOMES BUILT ON DODGE VAN CHASSIS AND EQUIPPED WITH SAFETY BELT ASSEMBLIES PRODUCED BY AM-SAFE BETWEEN JANUARY 28 AND AUGUST 15, 2000. ON SOME SEAT BELTS, THE BUCKLE AND CONNECTOR MAY UNLATCH DURING A COLLISION.
Consequence:
SERIOUS INJURY OR DEATH COULD OCCUR IF THE VEHICLE OCCUPANT IS NOT PROPERLY RESTRAINED.
Remedy:
AM-SAFE NOTIFIED HOME & PARK CUSTOMERS TO RETURN THEIR VEHICLE TO AN AUTHORIZED DEALER TO HAVE THE SEAT BELTS REPAIRED FREE OF CHARGE.
Notes:
OWNER NOTIFICATION BEGAN AUGUST 31, 2000. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT AM-SAFE COMMERCIAL PRODUCTS AT 219-266-8330 OR HOME & PARK AT 1-888-762-3873. ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Old 10-29-2006, 04:32 PM   #12
DODGE / B350 1994
DODGE / MAXIVAN 1994
HOME AND PARK / ROADTREK 1994
NHTSA CAMPAIGN ID Number : 94V163000 Mfg's Report Date : SEP 02, 1994
Component: PARKING BRAKE:CONVENTIONAL:MECHANICAL:LINKAGE AND CABLE
Potential Number Of Units Affected : 271
Summary:
THE PARKING BRAKE CABLE IS ROUTED TO THE RIGHT REAR WHEEL CAUSING IT TO CROSS AND CONTACT THE STEEL BRAKE LINE. THIS CAN CAUSE THE ABRASION AND RUPTURE OF THE STEEL BRAKE LINE RESULTING IN A LOSS OF BRAKE FLUID.
Consequence:
LOSS OF BRAKE FLUID DUE TO THE RUPTURE OF THE STEEL BRAKE LINE CAUSES LOSS OF REAR BRAKING CAPABILITY WHICH CAN RESULT IN EXTENDED STOPPING DISTANCES AND CAN CAUSE AN ACCIDENT.
Remedy:
DEALERS WILL REROUTE THE PARKING BRAKE CABLE AWAY FROM THE STEEL BRAKE LINE. THE STEEL BRAKE LINE WILL BE REPLACED IF ABRASION OR WEAR IS EVIDENT.
Notes:
SYSTEM: PARKING BRAKE; MECHANICAL; LINKAGES AND CABLES. VEHICLE DESCRIPTION: CLASS B MOTORHOMES BUILT ON DODGE B350 MAXIVAN CHASSIS. NOTE: IF THE VEHICLE IS PRESENTED TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND THE REMEDY IS NOT PROVIDED FREE OF CHARGE WITHIN A REASONABLE TIME OR THE REMEDY DOES NOT CORRECT THE DEFECT, PLEASE CONTACT HOME AND PARK AT 1-800-663-0066. ALSO, CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-800-424-9393.
Old 10-29-2006, 04:37 PM   #13
NHTSA CAMPAIGN ID Number : 03V100000 Mfg's Report Date : MAR 17, 2003
Potential Number Of Units Affected : 125
Summary:
ON CERTAIN MOTOR HOMES BUILT ON CHEVROLET G-VAN CHASSIS, THE CHASSIS FUEL RETURN LINE, WHICH IS TAPPED TO SUPPLY FUEL TO THE GENERATOR, HAS BEEN FOUND TO HAVE PRESSURES THAT EXCEED THE MAXIMUM ALLOWED BY THE GENERATOR MANUFACTURER. AS A RESULT, IF THE GENERATOR IS OPERATED AT THE SAME TIME THE CHASSIS ENGINE IS RUNNING, EXCESS FUEL COULD BE DELIVERED TO THE GENERATOR, CREATING A POTENTIAL FOR A GENERATOR STALL AND POSSIBLE FUEL SPILL.
Consequence:
IN THE EVENT OF A FUEL SPILL, A FIRE COULD OCCUR.
Remedy:
DEALERS WILL INSTALL AN APPROVED KIT THAT DRAWS THE GENERATOR FUEL SUPPLY DIRECTLY FROM THE FUEL TANK. OWNER NOTIFICATION IS EXPECTED TO BEGIN DURING MARCH OR APRIL 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HOME & PARK AT 1-888-762-3873.
Notes:
HOME & PARK RECALL NO. 2003-01. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Old 10-29-2006, 04:38 PM   #14
NHTSA CAMPAIGN ID Number : 98V261000 Mfg's Report Date : JUN 22, 1998
Summary:
VEHICLE DESCRIPTION: CLASS 'B' MOTOR HOMES BUILT ON DODGE 1500, 2500 AND 3500 VAN CHASSIS. THE FUEL LINE FROM THE FUEL TANK TO THE ENGINE MAY NOT BE PROPERLY SECURED TO THE CHASSIS. THE FUEL LINE CAN CONTACT THE ENGINE EXHAUST MANIFOLD CREATING A FUEL LEAK.
Consequence:
Remedy:
DEALERS WILL INSPECT THE FUEL LINE FOR HEAT EXPOSURE DAMAGE, REPLACE IF NECESSARY, AND INSTALL THE FUEL LINE INTO EXISTING PLASTIC CLAMPS. A NYLON CABLE TIE WILL BE ADDED TO SECURE THE FUEL LINE TO AN ADJACENT WIRING HARNESS.
Notes:
Old 09-26-2007, 04:34 AM   #15
HOME AND PARK / ROADTREK 210 2006-2007
NHTSA CAMPAIGN ID Number : 07V036000 Mfr's Report Date : JAN 31, 2007
Component: EQUIPMENT:RECREATIONAL VEHICLE:LPG TANK ASSEMBLY
Potential Number Of Units Affected : 131
Summary:
ON CERTAIN CLASS B MOTOR HOMES BUILT ON CHEVROLET CHASSIS, A BRASS CONNECTOR COUPLING FITTING USED TO CONNECT THE COPPER PIPING FROM THE MOTOR HOME PROPANE STORAGE CONTAINER TO THE BRASS FITTING ASSEMBLY BEHIND THE REFRIGERATOR.
Consequence:
THE CONNECTION CAN LEAK WITH VEHICLE USAGE RESULTING IN A POSSIBLE FIRE HAZARD.
Remedy:
DEALERS WILL INSPECT THE BRASS CONNECTOR FITTING AND REPLACE IT IF NECESSARY. THE RECALL BEGAN ON FEBRUARY 20, 2007. OWNERS MAY CONTACT HOME AND PARK AT 1-888-762-3873.
Notes:
CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO http://WWW.SAFERCAR.GOV.
Old 12-09-2008, 03:09 AM   #16
Default Re: Home & Park Motorhomes - Roadtrek
Vehicle Make / Model: Model Year(s):
ROADTREK / SS AGILE 2007-2008
Manufacturer: ROADTREK MOTORHOMES INC. Mfr's Report Date: NOV 28, 2008
NHTSA CAMPAIGN ID Number: 08V628000 N/A
NHTSA Action Number: N/A
Component: EXTERIOR LIGHTING:TAIL LIGHTS
Potential Number of Units Affected: 110
Summary:
ROADTREK IS RECALLING 110 MY 2007-2008 SS AGILE CLASS "B" MOTOR HOMES BUILT ON DODGE AND FREIGHTLINER SPRINTER 2500 VAN CHASSIS. THESE MOTOR HOMES FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, "LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT." THE REAR HITCH MOUNTED SPARE TIRE CARRIER (CONTINENTAL SPARE TIRE KIT), IMPEDES THE FULL VISIBILITY OF THE LEFT TAIL LIGHT. THE DRIVERS OF FOLLOWING VEHICLES MAY NOT HAVE FULL VISIBILITY OF THE LEFT TAIL LIGHTS.
Consequence:
THIS LACK OF VISIBILITY COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL INSTALL A SUPPLEMENTARY TAIL LIGHT ON THE FIBERGLASS COVER OF THE SPARE TIRE FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING DECEMBER 2008. OWNERS MAY CONTACT ROADTREK AT 1-888-762-3873.
Notes:
CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO http://WWW.SAFERCAR.GOV.
Old 07-15-2009, 01:13 PM   #17
ROADTREK / CHEVROLET 2500 2009
Manufacturer: ROADTREK MOTORHOMES INC. Mfr's Report Date: JUL 09, 2009
NHTSA CAMPAIGN ID Number: 09V264000 N/A
Potential Number of Units Affected: 23
Summary:
ROADTREK IS RECALLING 23 MY 2009 CLASS B MOTOR HOMES BUILT ON CHEVROLET 2500 VAN CHASSIS. THE PROPANE DISTRIBUTION SYSTEMS INSTALLED ON THESE VEHICLES MAY CONTAIN A DEFECTIVE BRASS TEE FITTING THAT HAS TOO SHORT OF A THREAD SUCH THAT, WHEN CONNECTED TO ANOTHER FITTING, THE CONNECTION BETWEEN THE TWO FITTINGS IS NOT COMPLETELY SEALED.
Consequence:
AN UNSEALED CONNECTION COULD RESULT IN A PROPANE LEAK, RESULTING IN A POSSIBLE FIRE HAZARD.
Remedy:
DEALERS WILL INSPECT AND REPLACE THE DEFECTIVE BRASS TEE CONNECTOR FITTING FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING JULY 2009. OWNERS MAY CONTACT ROADTREK AT 1-888-762-3873.
Notes:
OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO http://WWW.SAFERCAR.GOV .
Old 11-13-2009, 11:21 AM   #18
NHTSA CAMPAIGN ID Number: 09V437000
ROADTREK / RSAD 2007-2009
ROADTREK / RSAF 2007-2009
ROADTREK / SSAD 2007-2009
ROADTREK / SSAF 2007-2009
Manufacturer: ROADTREK MOTORHOMES INC. Mfr's Report Date: NOV 03, 2009
N/A
Component: ELECTRICAL SYSTEM:BATTERY
Potential Number of Units Affected: 520
Summary:
ROADTREK IS RECALLING CERTAIN MODEL YEAR 2007-2009 CLASS B ROADTREK RSAD, SSAD, RSAF AND SSAF MOTORHOMES BUILT ON CHRYSLER SPRINTER VAN CHASSIS. THE BRAKE LINE COMES IN CLOSE PROXIMITY TO THE BATTERY AND BATTERY TRAY AND CAN RUB AGAINST THEM. THIS SITUATION CAN DAMAGE THE COATING ON THE BRAKE LINE AND EXPOSE THE BARE STEEL. ALSO, BATTERY ACID CAN DRIP ON THE BRAKE LINE.
Consequence:
EITHER OF THESE DEFECTS COULD RESULT IN A BRAKE FLUID LEAK WHICH COULD CAUSE PARTIAL BRAKE FAILURE. THIS COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL INSPECT THE BRAKE LINE AND REPLACE IT WITH ADEQUATE CLEARANCE BETWEEN THE LINE AND THE BATTERY AND BATTERY TRAY. THE REMEDY WILL BE PERFORMED FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING NOVEMBER 2009. OWNERS MAY CONTACT ROADTREK AT 1-888-762-3872.
Notes:
rule
Old 12-04-2009, 11:00 PM   #19
arrveedogz's Avatar
I just received notice of the battery tray/brake line conflict. My Dodge service guy is gonna love this one!
Dan F.
arrveedogz is offline   Reply With Quote
Old 07-27-2010, 02:46 PM   #20
ROADTREK / 17PC 2008-2010
ROADTREK / 17VC 2008-2010
ROADTREK / 19PC 2008-2010
ROADTREK / 19VC 2008-2010
ROADTREK / 21PC 2008-2010
ROADTREK / 21VC 2008-2010
Manufacturer: ROADTREK MOTORHOMES INC. Mfr's Report Date: JUL 22, 2010
NHTSA CAMPAIGN ID Number: 10V333000
N/A
Component: SEATS
Potential Number of Units Affected: 644
Summary:
ROADTREK IS RECALLING CERTAIN MODEL YEAR 2008 THROUGH 2010 ROADTREK 17PC, 17VC, 19PC, 19VC, 21PC, AND 21VC MODEL CLASS "B" MOTORHOMES BUILT ON GM EXPRESS VAN CHASSIS FROM JANUARY 1, 2008 THROUGH JANUARY 1, 2010. ON SOME MOTORHOMES, THE LUMBAR SUPPORT WIRE HARNESS WHICH IS BETWEEN THE SWITCH AND THE LUMBAR MOTOR MAY HAVE INSULATION THAT IS NOT RATED AGAINST RISK OF FIRE AS PER SPECIFICATION.
Consequence:
IF THERE WAS A SHORT IN THE 12V WIRE HARNESS, THE INSULATION COULD THEN MELT OR BURN CREATING A SOURCE OF IGNITION WHICH COULD RESULT IN A FIRE.
Remedy:
ROADTREK WILL NOTIFY OWNERS AND DEALERS WILL REPLACE THE WIRE HARNESS IN BOTH THE DRIVER SIDE AND PASSENGER SIDE FRONT SEATS AS REQUIRED FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN DURING AUGUST 2010. OWNERS MAY CONTACT ROADTREK SERVICE DEPARTMENT AT 1-888-ROADTREK (762-3873) OR 1-519-745-1169.
Notes:
rule
