Old 11-02-2019, 08:12 PM   #1
Default Roadtrek antifreeze won't recirculate
I have a 2000 Roadtrek and have put 3/4 C. antifreeze in the water port behind the seat per the manual. I can not get the pink stuff to circulate and come out the water faucet. Should I add more anitfreeze??
Suggestions?
I drained the lines as the manual directed.
Thanks!
lisalmarshall is offline   Reply With Quote
Old 11-02-2019, 08:21 PM   #2
3/4 cup in the fresh water tank? Likely not enough. Try 1/2 gallon. It might take even more than that.
Old 11-11-2019, 07:49 PM   #3
The instructions I have say: Pour 1/2 gallon antifreeze into the main fresh water tank. Turn on the pump and open the sink faucet and let run until it runs pink. Do the same with the bathroom faucet, the shower and the outside shower. Then pour 1/2 cup down each drain and the toilet. You should also do the city water line by sticking a finger into the outlet to open the check valve. Keep pushing until it runs pink.
Blue Note is offline   Reply With Quote
antifreeze, roadtrek 200 popular
