Old 12-30-2016, 12:04 AM   #1
JerrMan's Avatar
Default Dodge Xplorer Battery location
I wonder if anyone has a picture of the batteries under the hood. I can't for the life of me figure out how in the world did they get 2 batteries under the hood. Unless they were tiny little not good for much size. Mostly cause I wanted to see an original setup.
I'm thinking of relocating the camper battery to the rear compartment.
I'm just a lot concerned about it being in the same compartment as the converter.
There is just enough room for a large 12V . or possibly 2 small 6V.
Which is a better way to go?
We don't boondock so mostly it would be used to run the lights , fridge, and possibly the furnace for a short rest stay like at a Walmart over night.
Would it have to be an AGM battery? Because of gas build up?
My Dodge is a 1988 Xtra Van 222
360 motor
1988 Dodge Xplorer Van
JerrMan is offline   Reply With Quote
Old 12-30-2016, 12:25 AM   #2
If you keep the battery in the van,
you should use AGM battery.
Because it does not gass.
However you can use flooded type battery
if you have a battery box and a vent that goes outside.
Old 12-30-2016, 12:49 AM   #3
JerrMan's Avatar
Humm so some of the battery boxes I looked at have a tube connector or a vent line connector on them and alls I would have to do is run a tube to the outside.? Sounds easy.
I already bought heavy wire to run to the rear of the camper.
I think I got 10 gauge wire and solder battery connector ends.
thanks
Old 12-30-2016, 02:01 AM   #4
If it's lead acid and in the coach interior I think it has to be vented.
Old 12-30-2016, 01:32 PM   #5
JerrMan's Avatar
I think I'll start shopping for an 12v AGM and a battery box to put it in.
Old 01-01-2017, 12:03 AM   #6
Hi Jerrman I have the same 1988 Dodge xplorer 360 engine . I have the two batt. under the hood on the drivers side . one is small thats near the fire wall , the other one is bigger that is right in front of it . I will take some pics. in the morning and send them to you .
John
machado11 is offline   Reply With Quote
Old 01-01-2017, 03:26 PM   #7
Hi JerrMan , here are some pics. that mind look like I have the same 1988 Dodge Xplorer just a little different model The Bosch battery is the one in front , that one starts the engine and Generator. The small one in the back turns on the 12 volt lights and things, i guess thats what they call the house battery . Hope this will help.
Old 01-01-2017, 03:52 PM   #8
JerrMan's Avatar
Thank You . Yes Identical to mine. Thanks for posting them , Yes that does help.
I see now they did use a small starting battery, turned straight across. My over sized batt only fits length wise. That's why there's no room left.
In this case bigger is not better.
It seems I have created my own problem. As usual. I bought the biggest battery I could fit in the original spot. Now there's not enough room for a house/camper battery. For a time I did have a 20Ah lighting battery in there , tight fit and It didn't last long. Lasted 1 year then no good. It would run the interior lights all night.
Right now I'm looking at a 12V. 100Ah AGM. I might get it to fit. Otherwise I was going to relocate it to the rear compartment.
Thanks and Happy New Year.
Old 01-01-2017, 07:53 PM   #9
Your welcome, Happy New Year to you and all, Being that we have the same type almost , if you have any questions Just ask. Take care.
John
Old 10-26-2017, 04:59 AM   #10
My 88 Colored has the battery next to the converter, no problems. Recommend 12V deep cycle, hard to find 6v, plus even a large 12v is smaller than 2 6s. I plan to move my converter to under the bed, where the water pump is, move the battery to the main compartment and install a 4000watt generator in that space ( shoehorn needed) but I can be done, I'll putt it in thru the top by removing the bed plywood
Ericv is offline   Reply With Quote
Old 11-29-2017, 11:13 AM   #11
John
Can the smaller battery be a deep cycle type battery?
Richard E is offline   Reply With Quote
Old 11-29-2017, 12:21 PM   #12
I can't see why not as long as it fits , I think my is i have to check and get back to you , Because the bigger one in front of that is the one that starts up the engine and the little one is the house battery.
Old 11-29-2017, 12:26 PM   #13
Richard, I checked and it is not a deep cycle but i think you can use one if you like . Make sure first.
Old 08-01-2018, 05:35 PM   #14
Default Have same 88 with same problem 4000 onan
I was gonna take out back door install bugger door never thought to go from top
Are you buildng a box for it ? How your gonna slide it out for service?
Chuck is offline   Reply With Quote
Old 03-20-2019, 02:20 AM   #15
What model battery did you use for the smaller one? I just replaced the big car battery but mine came with no house battery so I’m really looking to see what should go In there
Carlosocsc is offline   Reply With Quote
Thread Tools
Display Modes
