Old 02-28-2019, 06:08 PM   #1
Default GWV Titan Power Converter Location
I have a 2012 GWV Titan. Can anyone tell me where I will find the power converter?
I suspect it is bad as I am only getting about 12.4 volts across the batteries when plugged into shore power.
Canoebear is offline   Reply With Quote
Old 02-28-2019, 06:33 PM   #2
Can you locate the fuse panel? Generally, power centers are located close to one another to cut down on the size and length of wiring. Since yours is not visible, then it should be behind a wall near the fuse panel (perhaps accessible under a seat or bed).
Old 02-28-2019, 09:51 PM   #3
Yes. Many GWV Legends had converters directly behind the fuse/breaker panel. I wouldn't be surprised if Titans were the same.
Old 03-01-2019, 04:16 AM   #4
Thanks Rowiebowie. I had checked that area and couldn't find it but with your comment I went back and noticed a back panel was not as deep as on the equivalent other side. Yes, the converter was behind the panel.
Gotta now isolate the batteries and charge them to see if they hold the charge.
