05-12-2018, 01:45 PM
Help needed: Cabin battery not charging on shore power
Hi All,
1996 Roadtrek 190 issue:
I thought I had a bad battery until I bought a new one and the same thing was happening. When parked overnight on shore power, I would wake to find my battery wasn't charged.
I put a voltmeter on the battery and it read 12.3. I plugged the RV into shore power and it still read 12.3. I start the engine and it bumps up to 13.5 or so.
It seems as though the battery is not charging while on shore power.
Does anyone have any thoughts on something simple it might be?
-Pete
05-12-2018, 02:48 PM
Have you checked the breaker the converter is on? The one in the van and the one on the shore power cord?
"Il Travato Rosso"
2015 Travato 59g
05-12-2018, 06:53 PM
Yes, it was the first thing I checked. Sorry, I should have mentioned that.
Update: It started charging again. Then later it stopped. "What?!?! What am I doing?"
Here's what I think is going on: On my road-trek, there is a battery disconnect switch and an LED indicating its status. I think that it disconnects the battery. (Go ahead, laughing is ok.)
What's confusing is that the light indicating the battery is connected comes on when I connect to 110v *regardless of whether the battery is actually connected or not*.
What I believe this means is that in order to charge my battery, it is not sufficient to simply plug into 110v. I also have to flip the switch to "connect" the battery and begin charging. To make things more confusing, when the switch is off and I hit "test", the LEDs show the charging light lit... but I don't think it is unless the battery is connected. I think it's simply responding to a higher voltage in the system, like 14v.
Something new is now happening... a fan just came on from the area on the floor where the power system is! I hoping that means that the system is actually working to charge the battery now?
-Pete
05-12-2018, 06:54 PM
What is the name of your charger?
model #?
Is it one of the combo units?
Do you know if it is a single stage charger? or multi-stage?
Do you have a pix?
05-12-2018, 07:17 PM
Well, it seems to be what I would consider a combo unit since the 110 and 12 volt systems are managed by one black box.
I took some photos.
It's the MagneTek Series 6300 A model 6332.
It really feels like there's a big honkin' relay connected to the battery (Sorry, neglected to take a photo of this.) It has a nice ~kerchunk~ noise when you use the cabin battery disconnect switch. I believe it is completely removing the battery from all the circuits regardless of the charger status, etc.
model #?
Do you have a pix?
05-12-2018, 08:14 PM
On my 2001 Roadtrek Popular 190 (Dodge chassis) the manual states that I have to turn on the battery switch before I plug into shore power in order for the batteries to charge.
Joe
05-12-2018, 08:52 PM
Thanks! The 1996 manual is definitely confusing as it says things like the battery will charge while plugged into shore power and while driving. It later talks about the battery disconnect switch.
If I think of the battery disconnect switch as simply disconnecting my battery, I can wrap my head around it. However, I don't think it's that simple as I have a suspicion the battery charges from the van's alternator while driving down the road regardless of position.
I'm considering making my own panel connected to an arduino that monitors the battery voltage constantly and updates LEDs with true states for charging and battery level. Would be simple to do!
-Pete
05-12-2018, 09:06 PM
My batteries will charge by alternator (obviously while driving), generator, with my solar panel and shore power (but I have to turn on the battery switch before plugging into the 110V outlet).
Joe
05-12-2018, 09:12 PM
-Pete
The fan could be for your furnace. Check the heat thermostat to see if it is on and what temperature it is set at.
Joe
05-12-2018, 09:26 PM
Nope, the furnace is on the other side. This is coming straight from the base of the charging unit (and power distribution.) There are vents on the bottom. -Pete
05-12-2018, 09:27 PM
Joe, do you have to turn on the battery switch for those other sources to charge the battery? And, if you did NOT turn on the battery switch and plugged into the 110V outlet, could you turn on the battery switch afterward and get charging?
-Pete
05-12-2018, 09:44 PM
I only have to turn on the battery switch before I connect to shore power. As far as I know, the other three charging sources are automatic.
-Pete
I'm not sure whether it will charge or not. I don't have an obvious way to check it.
My solar panel, 215watt, really keeps things charged up when I'm parked at home. I also have two batteries, AMG 150amp/hr. When I boondock, which is not that frequent, the lowest I have seen my battery go down is 95%. I have full LED lighting in my coach and really don't consume much energy when we camp.
Joe
05-13-2018, 02:05 AM
Your suspicion is correct. However, shore side charging does require the switch to be on.
05-18-2018, 05:10 PM
I suggest you check to see if the charger is getting power.
The batteries in my 2011 RT Simplicity also stopped charging while plugged into shore power. Upon investigation I discovered that the charger is plugged into a conventional 120 V outlet inside the RV using a standard three prong plug. The plug had fallen out of the outlet, most likely due to vibrations from driving. I gave the two flat prongs a slight twist to create a bit more friction . I plugged it in again and have not had a recurrence since.
05-19-2018, 01:25 AM
Take a look at the instruction label from the factory right next to the control panel on my Roadtrek. The battery connect switch must be on prior to plugging in to shore power. AND, the connect switch (at least on yours and mine) makes that loud "kerplunk" and that is normal. Both of my Roadtreks (1996 RT 190 and 2007 RT 210) had the "kerplunk" and instruction label.
Paul
05-22-2018, 02:07 PM
Paul, thanks! Mine doesn't have such a sticker, but I think I'm going to make one up!
I've also started creating a little battery monitor that will tell me what is happening at the terminals.
I've also started to leave the "porch light" on the side of my Roadtrek on at all times now. It's a great way of knowing if I accidentally left the battery on.
05-22-2018, 02:21 PM
Someone probably removed the sticker earlier in the life of your RT.
05-22-2018, 02:28 PM
Our 07 C190P Roadtrek had the sticker, but it was wrong. At least on the 190s, when they went to separators instead of isolators, they moved the shore charger to the battery side of the 12v relay, from the load side of the relay. With it on the battery side, the switch does not have to be on to charge from shore power. I think all the newer stuff, post 2007/2008? time frame are like ours, but with Roadtrek you never know.
05-22-2018, 03:04 PM
I think it's now clear to me that I have to connect the cabin battery with the switch before I plug into shore power in order to charge the battery. What is unclear is what happens if I first plug into shore power and then flip the switch.
I'll do that test soon and report back... understanding things changed later than my '96. It's just a bit of a hassle to unscrew the cover to the battery box to measure the readings at the battery terminals. The next time I open the box, I'll be connecting my own (fused) voltmeter testing unit. The one I bought also has a little buzzer where you can set your high and low voltage warning values.
Won't be done until Friday though...
-Pete
05-22-2018, 03:37 PM
"I think it's now clear to me that I have to connect the cabin battery with the switch before I plug into shore power in order to charge the battery."
Yes.
"What is unclear is what happens if I first plug into shore power and then flip the switch."
You simply won't charge, but the battery will power stuff as usual.
Thread Tools |
Display Modes |
Linear Mode
