Old 05-12-2019, 02:40 AM   #1
Unhappy Installing headlights on 94 dodge jayco
How do I find info on how to replace headlight assemblies on a 94 dodge Jayco conversion camper?
lwahls is offline   Reply With Quote
Old 05-12-2019, 02:01 PM   #2
Bruceper's Avatar
Headlight should be able to be removed by removing 6 screws on the bezel around the headlight and then 4 screws to remove the holder.
shows a truck, but should be the same as your van.
Old 05-20-2019, 12:02 AM   #3
I think a 1994 van has composite headlights, rather than sealed beams.
ThroatwarblerMangrov is offline   Reply With Quote
Old 05-20-2019, 11:31 AM   #4
If it has a plastic lens that is just dulled and yellowed then sanding/buffing with a restoration kit does seem to work. I got a 3M 39008 kit for around $10 on Amazon a did the headlights on my Class A yesterday. They look really good now!
I had previously tried a sand and wipe on clear coat type kit which looked great at first but didn't last a year before looking old again so I can't recommend that type of kit.
Left: sanded & buffed & rinsed off - 4 step kit
Right: previous 2 step wipe-on kit yellowed & dull after less that a year
Old 05-27-2019, 06:05 AM   #5
Knit's Avatar
If it’s just the bulbs look up the parts at https://www.sylvania-automotive.com/apps/vlrg-us/Vlrg/
If you need to replace the whole assembly, try http://www.autolightsbulbs.com/1994-.../K1108894.aspx
Knit is offline   Reply With Quote
