Old 04-07-2018, 08:27 PM   #1
Default One battery or two
I'm in the process of pulling out the Onan and building in capacity for two lead acid batteries in it's place.
I tend not to use much power while boondocking though the new style Dometic fridge does not help in this regard. An average would be 20-25 amp hours, unless it's cold enough to run the jet engine, er, um the furnace quite a bit. I have no intention of running a Microwave/toaster oven or other heavy use from the house battery.
I have 150 watts of portable suitcase style solar collectors fed through a Renogy PWM controller.
My conundrum. Due to the slow finish charging of the batteries, I'm thinking I would be better off with one battery vs two. I would still be good for basically three days with no help from solar running one battery. I'm thinking cuz of the slower finish rate two batteries may have a much more difficult time getting to full charge versus just one, creating an environment where the batteries would spend several days to a couple of weeks not getting full.
I really don'r have the need or inclination to get more solar, though the controller is rated at either 20 or I think 30 amps.
If for some reason there was a lack of solar or extra demand I have no issue running my nice quiet Champion remote start inverter genny for a while.
Thoughts? Am I just being too anal and I should mount up 200 amp hours of batteries?
The RT is a 2000 Chevy 200 Versatile.
TIA.
Old 04-07-2018, 10:17 PM   #2
You are mostly right on the guess that two batteries will take longer to finish charge than one, but that only applies if the charging source is quite small like the solar is. The extra time won't really be spent in the final 20% of charge as much as in the bulk stage getting to that point because you won't be able to supply all the current the batteries will take.
You 150 watts of solar should get you back in the range of 30-40ah per day if the sun is very good, less than that if it is not, and way less in clouds, rain, shade, etc. If you get sun all day, you should have enough time to top off 200ah of batteries if they are down only 25ah. We routinely have done 40ah out of our 440ah of battery and recovered it all by 2:00 in the afternoon in good sun, with our 300 watts of rooftop.
I wouldn't even worry about carrying an extra generator unless you want to run the microwave or some other high load item. For recharging a 200ah bank, if it gets down a ways because of bad sun, you will be better off to use the van engine and alternator to take you to the 85% full point, and then let the solar finish it off. Your alternator charging from that era is likely about 50 amps, so just about the right rate for 200ah batteries.
You will likely be in good shape, unless of course you like to camp in the deep forest or where it is always raining
Old 04-07-2018, 10:30 PM   #3
TIA.
are there bigger alternators that can replace the standard alternator in this? maybe that would help?
Old 04-07-2018, 11:44 PM   #4
Thanks Jim.
The genny not going with is a non-starter. We need it for A/C. When in the heat, even only say 75-80*, it's nice to fire up the A/C for a half hour or so to pull the heat out of the coach after driving and the exhaust, trans and other stuff gives off a lot of heat that seems to rise up to the inside. And we do have both a microwave and a toaster oven that gets used, especially at breakfast, so there is a nice little kick to the battery in the morning. The charge control is Progressive Dynamics with a 45 amp converter.
I'm thinking I'm gonna go with a single with a provision to add another. Obviously looking at 12 volts.
The engine running for charging a dual battery setup is something for me to keep in mind. Thanks.
I have followed your setup, and I like it. I just don't wanna do that much work to go that route, and it is a bit of an investment, money better spent on gasoline.
Later, and thanks again.
Old 04-08-2018, 12:04 AM   #5
Yes there are but I'm thinking I wouldn't really benefit unless going with more than two batteries. I'm just debating whether the extra capacity is really such a good idea unless I really needed it for a couple of days usage while boondocking. More than 90% of our camping is boondocking and generally for a few days to a coupla weeks at a time. I do get pretty much a full recovery charge daily off of my solar.
Old 04-08-2018, 12:32 AM   #6
I'm not sure I am following the logic here. Obviously two empty batteries take longer to charge than one empty battery of the same size. But that's because you are putting twice the amps into it. But that is apples to oranges. For a given number of amps, isn't it true that two batteries will accept them FASTER than a single battery?
Now, it may be true that getting to 100% might take longer, but I don't see where that matters, as long as it happens once in awhile.
Or, am I confused?
Old 04-08-2018, 12:50 AM   #7
I think the missing information is how much usage and what charge rates you can get from the charging sources. If you have two batteries that are below the 70-80% SOC point where they start to taper on charge amps, and you have a charge source big enough to supply them with as much as they will take, or at least large amount of amps, then you will recover your used amperage twice as fast as with just one of them, give or take a bit.
The original question brought in the premise of having the batteries get full all or most of the time, and that changes everything. If you are down 15%, you will never get much acceptance, so you may be charging at well under your charging amps capacity. If that is the case, you will recover the amps you used faster with a second battery to help use the total amperage.
If you have only one battery and a smallish charge source, it will get the battery to the tapering section of the charge sooner than if it was trying to charge two batteries on the low charge rate, and the sooner you get to the nearly fixed time of the tapering charge, the sooner you get done. So in this case your need less total time.
There are so many variables when you put the tapering charge to full into the mix, that you can come up with just about any possibility.
The good is that on any system that has alternator charging of even very modest capacity, you can get a normal sized battery bank charged enough for a day or two of modest use quite quickly. You won't be full, but you don't have to be all the time, just every 7-10 cycles, so you catch that later when you get good sun or a long drive.
Those with absorption frigs regularly report 20ah per day use, so they can get that back very easily in a lot of ways. Add a compressor frig and that turns into closer to 50ah per day and starts to get you into starting to look at bigger systems. For those that also add coffee makers, induction cooktops, and microwave use, you can easily get to 100ah per day or lots more than that, and require substantially upsized systems.
Old 04-08-2018, 01:33 AM   #8
eric1514's Avatar
I'm not understanding why you would pull out your generator only to replace it with another. Sure, the inverter generator will be quieter but one large enough to run your A/C is heavy and where are you going to put it?
"Il Travato Rosso"
2015 Travato 59g
Old 04-08-2018, 02:58 AM   #9
I was done with the Onan. On two long trips, it broke down to the point that to get it running it would have to be removed. And it's loud and vibrates. And parts are not cheap. Now I have a Champion inverter genny with a remote start/stop fob, mounted on the trailer tongue of my motorcycle trailer. It is rated at 2.8 KW steady, 3.1 surge. It weighs less than the Onan. It has a three year warranty. If I need to work on it on a trip, I can. Cost was only slightly more than what I stuck into and what would have to be spent on the Onan, with me doing the labor. Voltage regulator, muffler, fuel pump, carburetor, then next??
Fueling is a bit of a hassle but I did retain the fuel pump and put on a hose that will reach the Champ's fuel tank. So not so bad unless the weather sucks when I need to fuel. It's on the trailer(which pretty much goes everywhere with me/us) so once camping I can unhook the trailer and leave it up to 75 feet from the RT, helping a bunch more with noise. And I have a fuel supply for off road vehicle playing out in the toolies.
Did I mention before how quiet the Champion is?
If for some reason I want to travel without the trailer(wow, like, without my motorcycle??!?), I can mount the genny on a receiver hitch luggage rack.
I thought quite a bit on the change over and it is/was the right decision for us. Had I made this decision a year earlier I would have purchased a compressor fridge at the time instead of a new absorption fridge and set up the RT along the lines of what Booster has done. But living in the south I still need that A/c option so a genny is mandatory. Have I mentioned how quiet it is?
Hopefully this explains clearly enough on my thoughts and thought processes.
Thanks to all for the input.
Old 04-08-2018, 04:04 AM   #10
BillsPaseo's Avatar
Totally makes sense to me and I've had thoughts along similar lines. We already had a Champion generator before we bought the Paseo (same wattage specs as yours but pull start only). We used it with the small toyhauler we had before the Paseo, and it worked great. Sips gas, could run either the AC or the microwave, just not both at the same time, and is very quiet. If all you were using it for was to top off batteries, you could barely even hear it from the next campsite.
I was shocked... and I really mean shocked... the first time I fired up the Onan in the Paseo. Unbelievably loud, and the vibrations from it can be felt throughout the entire vehicle. Love everything else about the Paseo, but not that generator.
2017 Winnebago Paseo
BillsPaseo is offline   Reply With Quote
Old 04-08-2018, 11:28 AM   #11
The genny I bought was $779 at Amazon yesterday.
I paid about $900 for mine. Post Maria, Irma and I forget the other name.
Just in case folks wanna know.
Old 04-08-2018, 11:32 AM   #12
eric1514's Avatar
It makes sense now that you mention you haul a trailer with you.
"Il Travato Rosso"
2015 Travato 59g
Old 04-08-2018, 05:26 PM   #13
Any generator, quiet or not, has restrictions in a campground be it totally banned in use over all the campground or in certain areas. Those area where acceptable are generally where big rigs park and everyone runs them. If allowed, then there are restricted use from not overnight down to a couple of hours in the morning and evening. They are not good for stealth. I knew that as early as the 70's when my parents parked out on the street and ran their generator. My neighbors were all up in arms. They intrude on nature's peace and quiet in off-grid forested areas. I don't have a generator now. My previous B had only about 20 hours on the Onan over 65,000 miles of travel and the majority of those hours were "exercising" hours over winter storage. I had not much use for it and managed do do without with two lead-acid batteries.
I guess the point I am making is if you grow dependent on generator use then you restrict where you can camp.
Old 04-08-2018, 05:42 PM   #14
TIA.
You're a Spartan road warrior so stay light. Given your user profile one battery will be twice as reliable than two during the five year life of the batteries. If you want a little more capacity, one high capacity battery is much more reliable than two. If you had two would they be
1) strapped them in parallel so the weaker battery always drains the good one?
2) issolate each battery with a schottky diode and let the 0.5v drop inder heavy load waste 4% of the battery's energy.
3) swap cables so you use one at a time and miss the fun.
Buy one and size it to your application.
ContinuousImprovement is offline   Reply With Quote
Old 04-08-2018, 09:42 PM   #15
There were comments in this thread on charging two batteries using the regular engine alternator. There is a 50 Amp breaker on each end of the 12v line between the alternator and the house battery.
I would imagine that if both house batteries are quite low, the alternator might have to supply 50 Amps, or maybe more for brief periods before one of the breakers interrupt the circuit temporarily. The alternator will also be supplying current to the engine battery and coach systems at the same time. Can this put a stress on the alternator, or is it designed accordingly?
WJones is offline   Reply With Quote
Old 04-08-2018, 09:56 PM   #16
50 amps plus maybe 15 to run the van shouldn't be too much for the alternator, depending on how big it is. It would likely be over 100 amps and it wouldn't be running at 50 amps for long. If the OP were going to charge that way a lot, and newer, larger alternator might be in order, but probably not needed.
Old 04-09-2018, 12:04 PM   #17
Good perspective.
I was really bummed that I had to replace my old style mechanical fridge with the new stuff with a circuit board and it's accompanying current draw. I was able to get by with a group 24 battery just fine.
The single battery I have is a "maintenance free"Ever Start Maxx flooded rated at 78 amp hours. Your typical Walmart cheapy though it states it's good for 30% more charge cycles. It's about two years old and still functions as new. Since adding the new fridge, it drops down to about 50% or lower if I have to run the furnace quite a bit, hence the desire for more battery.
Most of my camping is out west so solar is pretty decent.
I do not have a Tri-metric but do use current/power monitors.
https:/amazon.com/gp/product/B01JOUZELG/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
The battery that I was leaning toward is a group 27 flooded "maintenance free" Exide that Rural King sells for $69 or 79 depending if on sale when purchased. They carry three allegedly different group 27 marine/RV batteries, start, start/deep cycle and deep cycle. The deep cycle is rated at 105 amp hours. All three do have different specs/ratings.
I'm thinking this will likely work as it will give about 20 more amp hours of usable power than I have now, 78 vs 105. 58.5 vs 78.75 amp hours when discharged to 75%. Assuming a plumb full battery.
My current thinking is to roll with that battery and see what happens. I do like the low $$ buy in and if it goes for two years at that price I'm a happy camper. More, which is likely, is a bonus.
That being said, I will design the new battery holder to accommodate a larger battery.
Background info. My retirement funds are not unlimited. Hence the now 18 year old RT. I do try to keep expenditures to a minimum but still keep things workable. I do stay after preventative maintenance using a good brand for parts(Gates, Delphi, Wix, etc). It tends to cost more not to do it. And it's a lot more inconvenient not to. I intensely dislike having a breakdown when traveling, hence the disappearance of the Onan from my life. I recently sold a motorcycle with 234,xxx miles on it. Due to preventative maintenance and a bit of good luck, it never left me stranded on the side of the road.
I would like to thank all that have participated. It's always good to get different ideas and perspectives.
Now to go pack it for an upcoming four month trip out west.
