08-26-2019, 03:11 PM
Roadtrek, Number 49, 40 amps, fuse is blowing in a 2003 Chevrolet express 3500
Hi
Seeking help
My 2003 Roadtrek 200, Chevrolet express 3500 has blown a fuse (3 times) making the vehicle impossible to start. There is no action when I turn the ignition switch except for the ordinary show of indicator lights.
Chevrolet Express - fuse box - engine compartment
The no 49 fuse, 40 amps, labelled « Ignition A ». Located in the engine compartment fuse box will blow making it impossible to start the engine. This fuse passes true a relay an is eventually connected to the solenoid of the starter motor.
First event was in October 2018, then 2 weeks ago, and last, this pass Sunday. Very unnerving not being sure your engine will start, makes using the vehicle very risk to take anywhere.
Thanks,
Michel Charlebois
Rigaud, QC
2003 Roadtrek 200, 2003 Chevrolet Express 3500
08-26-2019, 03:52 PM
Originally Posted by Chukwood
Hi
Seeking help
Thanks,
Michel Charlebois
Rigaud, QC
I think you really need to get an ammeter on it to see how much power is being used. I would guess you are over 40 amps but not huge because it lasts a while. Most likely suspect would be the coil of the starter solenoid which could be because of a bad solenoid, or sticky engagement mechanism that moves the starter gear into place (Bendix).
08-26-2019, 06:08 PM
Another possibility would be an intermittent short that is getting more prevalent from potentially rubbing against a ground, baring more wire.
09-18-2019, 09:53 PM
Update
Hi,
Finally resolve the burning no 49 fuse, after, 1 garage and 1 auto-electric shop had a look at it.
An impaled wire feeding the starter solenoid was intermittently making electrical contact with the chassis, under hood, right side, close to the starter.
After a month without my rig, kind of a relief, that the problem is solved.
Thanks for the help.
Michel Charlebois
Rigaud, QC
09-19-2019, 01:54 AM
Hi,
Michel Charlebois
Rigaud, QC
Michael, welcome to the forum!
And thanks for posting your resolution. Not everyone does this. It adds to the knowledge base of this forum.
Thread Tools |
Display Modes |
Linear Mode
