03-17-2019, 08:53 PM
Surging (?) Onan QG2800
I have an Onan gas 2800 generator purchased in mid 2017 that now has 44 hours on it. It's been run for a variety of times from a few minutes to hours, but less recently - only for exercise.
The last couple of times it has been run, it seems to be making a rhythmic noise that seems like the power is going up and down. Here is a video. It's under load (AC) and the sound oscillation doesn't seems to change even when the load is removed. Any ideas?
2018 Coachmen Crossfit/Beyond
03-17-2019, 10:47 PM
Yes "Surging", sounds classic.
The tiny little jets in the carb have varnish that has formed after the gas or gas/ethanol has dried up. Many use Seafoam in the gas to solve this IF not too bad. Or strong carb cleaner into the carb by disconnecting the carb fuel hose, access for the carb cleaner. Or replace the carb.
90% chance varnish, imo.
Most start with the Seafoam.
03-22-2019, 01:58 AM
Well, the update is that after about 4 hours using a gas/cleaner mix feeding directly into the Onan, most of the surging oscillation is gone. But it clearly likes to be under a heavy load. If we run everything there is to run, it doesn't surge, but if there's no load it will start to surge and will continue to do so indefinitely
03-22-2019, 02:48 PM
Disappointing, not good enough, sorry about that.
What did you use? What percentage....?
03-22-2019, 07:27 PM
Can you screw the float bowl off? By turning it, you can drop it down and after clening the bottom inside you may try again.. IF that doesnt work, you can even continue to remove the adjustable (high altitude/low altitude) adjustment. Do this by 'GENTLY' turning the set screw in and count the half (or quarter) revolutions until you hit bottom.. Write that down.
Then remove completely and clean the gunk out. clean thoroughly untill everything looks like new aluminum and brass. Put the adjustment screw/needle back in until bottoming out.. then back out again by the number of revolutions you had marked down. Assembly bowl and try to run again..
That did the trick for me. Good luck!
03-22-2019, 07:32 PM
Onan changed the carb with the newer models? I did not know about removing the bowl?
And gunk? 44 hours?
03-22-2019, 07:48 PM
And gunk? 44 hours?
Maybe the newer ones do not have the removable bowl.. mine is a 97 model.
I tried the seafoam too, but that varnish type of coating wouldnt dissappear even after running with seafoam for a while and letting it soak overnight.. Scrubbing with some cloth, was the only way to get that varnish off.
03-23-2019, 01:19 AM
And gunk? 44 hours?
Not how long it ran, but how long since it ran. Mine surges if it goes too long without running. But so far, its cleared itself after a half hour or so.
03-23-2019, 02:34 PM
Seafoam wasn't available locally so we used Chevron Techron as directed (I believe 1 oz/gallon but don't have the bottle handy).
And I have to correct my earlier post to say it was run 1.5 hours with this mixture going directly into the fuel line of the Onan.
The generator sat idle for nearly 4 months as we had a series of health issues this past winter. We know it needs to be exercised, just couldn't get there. Next winter we'll put some Sta-bil in the fuel before winter just in case.
03-23-2019, 03:25 PM
I have no idea if sta-bil will keep the fuel from drying out in the carb jets or not. If not, I also don't know if it will somehow keep the varnish from forming or not.
Some folks don't want to exercise the generator, so they have added a cutoff switch to the fuel line to run the engine out of fuel. The small Yamaha generator has that feature. Maybe Honda does also by now.
Just sitting with Seafoam in the fuel will assist some. In the worst cases folks have used Strong carb cleaner mixed with gas directly into the carb, start the engine and then kill it leaving the strong carb cleaner in the jets. Let it sit for awhile, then do it again start momentarily and kill the engine. There are discussions about potential carb damage, but if this is the only solution, why not. If it works, great, if not replace the carb.
I have only used Seafoam once with very mild surging for a few minutes about 8 years ago. I simply ended the trip with about 3/8 of a tank of fuel, added a full dose of Seafoam and ran the generator for a few minutes. I had little doubt it was the carb jets.
The generator is 14 years old, 12 with me. I exercise it for about 35 minutes every 35 days when not using the B. The generator/B is happy with me spending days in the B after 2 hurricanes with the generator running a Lot. The last hurricane forecast required no one do any preparations, 75 mph wind that would past right through the New Orleans area. That meant I only had about 3/8 of a tank, big problem. The 75-80 mph wind was correct, But lasted for days. When living in a city there is Lots of Rotor, so it is 75 mph this direction the opposite direction........... Took out most of the power with most folks without power for days Including Gas Stations with my gas! I could not siphon gas from my car. My neighbor was downtown in some fancy hotel with power. He had a full tank with his new truck. I was able to siphon his gas, victory which meant ac was available for a long time.
03-23-2019, 03:54 PM
Something that can help the carbbie for storage in adition to StaBil is put a little two stroke oil in the gas, about an ounce to four gallons. It tends to leave a helpful film on the gas circuits to help eliminate corrosion as the gas goes away or if you run the bas system empty. that dosage is small enough to not be concerned about how the engine runs and is not enough to make it smell like an outboard or string trimmer.
Picked that up from a tuning motorhead that knows and lives carburetion and now computer tuning.
03-23-2019, 09:42 PM
There is a screw at the base of the carburetor bowl that drains it. Use it!
03-28-2019, 04:42 PM
Seafoam worked for me
I purchased a 2008 210 with 21000 miles on it and 20 hours on the generator about 2 years ago. I expected to develop problems with the generator and it did result in a surging problem. I took the fuel line and ran a 50/50 mixture of Seafoam and gasoline through the generator and then let it sit and soak for a week or so, and then did it again. The surging went away and I still will run the coach down to just over a 1/4 of a tank and dump in a can of seafoam (enough to treat 16 gallons) and I exercise the generator with this mixture. Runs like a top and I never had to touch the carb, but it does take patience.
03-29-2019, 04:54 AM
The gasoline that is sold in CA and some similar emission focused states is not nearly as stable as it was in the past.
I have a similar problem in my honda lawn mower and it took a while to figure out.
Basically after about 3 weeks, it will start to polymerize in the carb / fuel system and coat everything over. It takes a major clean out to fix.
I tried all of the stabilizers on the market and every brand of fuel - doesn't help.
In the lawn mower, the fix was to switch to the quarts of gasoline sold in metal cans in hardware stores. Crazy expensive but still much cheaper than the repairs - even when I did them myself.
My belief is that there is something in the honda fuel system that is catalysing the reaction, but I have not figured it out.
Try to run the generator out of fuel to the greatest extent possible when not in active use.
Some experience with auxiliary power
03-29-2019, 05:47 PM
Most regular gas today (unless otherwise stated) contains Ehthanol which small engines of any kind do not like. To avoid the problem with our RV which is stored from Nov 1 to April 1. we (1) Installed a cutoff switch in the gas line to the Onan. This is always closed except when exercising or using the generator. Then we open it, start the gen and let the gen run. Then close the shutoff and let th gen run until it shuts down for lack of fuel.
(2) Before storage I put 2 cans of seafoam in the RV tank then fill the RV gas tank with Premium gas. Then start and run the generator under load as recommended for 20 minutes then shut the fuel cutoff switch to the gen and let it run until the gen shuts down. I have done this for 6 years and gen (and RV), have always started and run well when battery reconnected in April. Occasionally have had
some brief "surging" at start-up but passes very quickly.
Thread Tools |
Display Modes |
Linear Mode
