Old 04-14-2017, 01:59 AM   #21
Roadtrek probably programmed your controller during the build to match your AGM batteries which is fine. What's not clear is whether the controller can cope with the recommended liithium charging protocol which is to dispense with maintenance charging and shut off if it senses a fully charged battery. I couldn't find any battery choice in the manual that will implement this protocol.
Roadtrek uses 2 different tracers. there is one for lithium batteries also. it allows higher charging voltage. i think it tracer BN
Old 04-14-2017, 02:59 AM   #22
I can't find any reference in the BN manual to lithium batteries. There is an assigned mode called "user" but nothing to describe what this mode permits. For maximum lithium battery life, my understanding is that the charging voltage is less critical than a shutoff state that removes trickle charging when the battery is considered by the controller to be fully charged. I don't see any way of entering this parameter.
There doesn't seem to be any user customer or technical support contact in the CONUS and my Mandarin is a little rough.
http://www.epsolarpv.com/en/uploads/...4076227945.pdf
Old 04-14-2017, 03:19 AM   #23
be that as it may -they do use 2 different tracers. one for agm and one for lithium.
Thread Tools
Display Modes
