Old 07-17-2019, 01:40 AM   #1
Default Class B with hitch hauler?
Hi all! I’ve been hanging out & learning for a while here. I’ve learned a ton & appreciate the quality of this forum.
The wife & I sold our toy hauler this spring. We think we would like to try a B van.
My question is, are there any Class B’s that can realistically handle a 600 lbs motorcycle on a rear rack of some sort?
My initial thought would be, to install a receiver tube on each frame rail with a channel across them for the wheels to set in. I would not trust a single receiver in the middle.
It looks like an E450 or C4500 based van would be the best option but am unsure if this is correct. I am also unsure what, if any Class B’s are built on these chassis.
Thanks for your help!
Murf
Murf is offline   Reply With Quote
Old 07-22-2019, 05:09 PM   #2
Murf,
I'm thinking that 600 lbs is too much to have hanging off the back of most Class B's, Class B+'s and smaller Class C's. Too much stress on the rear AND then there is the "see-saw dynamic" of making the front end lighter due to the weight on the back. I would think that handling would be adversely affected.
I would recommend pulling your 600 lb. motorcycle with a Motorcycle Trailer. Just my thoughts.
Dave
David
Now: 1998 Coachmen Starflyte FRB 21' Class B+
Formerly: 1996 Coachmen M19-RD GMC 19' Class B
TatraDog is offline   Reply With Quote
Old 07-23-2019, 12:34 PM   #3
Originally Posted by TatraDog View Post
Murf,
Dave
Thanks for the reply, Dave.
I’m afraid you are probably right. I know it is the best way to do it. Pulling a trailer kinda defeats one of the main advantages of a Class B. I started out with a truck & toy hauler. I quickly grew tired of that setup. I don’t really want to give up the bike but I guess I will have to consider it.
Thanks again,
Murf
Old 07-23-2019, 05:52 PM   #4
I'm in the same boat, have a 800 lb motorcycle. Most class b have a tongue weight of 200-500 lbs. I'm looking for a light weight, easy load motorcycle trailer now.
Good luck with yours.
MotoBill is offline   Reply With Quote
Old 07-23-2019, 06:06 PM   #5
Thanks Bill. Good luck with your search, too!
A trailer just limits parking so much. I was trying to find a way around it.
Thanks again,
Murf
Old 07-23-2019, 07:36 PM   #6
Murf,
There is an item that only extends about four feet. Its called a dolly trailer and will hold up to 1000 lbs. What I don't like about it is the small wheels it has to carry the weight.
And it cost a nice penny.
I like the enclosed trailer to carry additional supplies and the motorcycle is out of sight.
Light weight fiberglass is the way to go, but also big bucks.
Bill
Old 07-30-2019, 03:01 PM   #7
if the tongue weight is rated at 600#, would it work having a 300# trail bike plus the ramp, say 400# total? want to use the train bike for both adventure riding the trails and running to a store for supplies.
boutdone is offline   Reply With Quote
Old 07-30-2019, 05:52 PM   #8
Yes, that would work.
Old 07-30-2019, 05:53 PM   #9
thank you sir, that makes my day!
