Old 08-01-2017, 03:28 AM   #381
Originally Posted by WingedRyno View Post
Not sure. I'm in the former.
Dale, the owner, is usually very good about taking care of the customers and a very nice guy besides. His new operations manager, who I met a while ago while there to get some stuff, not so much, I think. Seemed like a typical RV sales type to me. If Dale isn't involved, you may want to get him to intervene. Lake Regions has a very good reputation, and should have some experience with the lithium stuff by now.
It is also where Mumkin got her, used to be lithium, now AGM, unit that was so much trouble for her. They did grant her request to go to the AGMs though, to solve the issues she had.
Old 08-01-2017, 03:37 AM   #382
If the Balmar is in a tough to see spot, it will be hard to program in place, and you would be better to program it before putting it in, I think, like Nations does.
Concerning the programming, how the absorption time was set would be really weird if the use the AGM setting for lithium, as lithium needs essentially zero absorption time if the voltage is set right. With the 14.4v of the AGM setting, you would really want zero absorption time as you are already past what many would want for state of charge for lithium.
A current model PW owner can clarify this but as far as I know, although their lithium batteries may be charged by a lithium charger I think they still use an OEM alternator and conventional single stage constant voltage (aka absorption) regulator.
cruising7388 is online now   Reply With Quote
Old 08-01-2017, 04:14 AM   #383
Let's start with your original observation that all charging sources (alternator, converter/charger and solar are in parallel and are connected to the common side of the disconnect switch and continue to address the batteries regardless of the position of this switch.
OK, I got that with regard to the alternator and solar inputs. But with your description, I don't get how shore side power functions with the battery switch "off". You indicate that the battery charger is on the common side of the disconnect switch and the inveter is on the load side.. With a stand alone charger that works. But with the RT, for the charger to operate, the inverter must be on, but as you describe it, the inverter is hardwired to the load port of the batteries. If that's the case, it won't operate if the main disconnect switch is activated and without inverter operation, the charger won't operate.
But here's the punch line. With the battery switch off and shore power connected, the inverter will still power up with the disconnect switch "off".
If your description is accurate, when the battery switch is "off", where is the inverter getting power from?
When you are plugged into shore power the inverter gets its power from the shore connection to charge the batteries that are hardwired to the inverter. It also passes the shore power through the inverter to the coach 120v circuits. When you are not connected to shore power the inverter gets its power from the Ecotrek batteries to provide inverted 120v to the coach unless they are all offline in which case the inverter is dead no matter if you have it in or off. Each Ecotrek has a relay on both positive terminals (charge and load) that are controlled by the BMS and both relays are open when the Ecotrek is offline. The GU, solar, and AGM are typically connected to the charge terminals, the inverter and the 12v distribution are connected to the load terminals.
Old 08-01-2017, 04:38 AM   #384
LOL! Aren't we going in circles here? How can the shore power convetrer/charger power up the inverter if the inverter has to be already powered up in order to enable the shore side battery charger? Isn't it pretty well settled that the inverter has to be on for the converter to come to life?
Old 08-01-2017, 05:07 AM   #385
He said they confirmed the GU is putting out good voltage but plugging in some wire into the Balmar caused sparks, which is why they think the Balmar is bad (from what I gather on the phone).
After thinking about this, their description of alternator "good voltage" may be valid. What they may have done is bypass the regulator and temporarily full field the alternator to verify that the alternator was working properly.
Old 08-01-2017, 10:26 AM   #386
Think of the unit as what it is, an inverter/charger.
A fundamental difference between an inverter/charger and a converter/charger is that a converter can function as a 12V power supply. Batteries do not need to be in the system to be able to use 12V DC from a converter plugged into the grid.
With inverter/chargers, 12V DC is supplied by the batteries. If no batteries then no 12V DC available.
Two bikes on sliding cargo box: https://www.classbforum.com/forums/m...icture206.html & 1997 GMC Savana 6.5L Turbo Diesel Custom Camper Van Specifications: https://www.classbforum.com/forums/f...vana-5864.html
Old 08-01-2017, 12:30 PM   #387
I'm still trying to understand how it is that despite all batteries being offline after the BMS shut them each down around 20% SOC or so, one came back online overnight on shore power with the inverter switch on but the inverter actually off and 7 of the batteries switch on (but offline with no blue lights).
I'm guessing it's very unlikely the inverter was converting AC to DC without showing on. So it seems most likely that the BMS simply recalculated as the ambient temps dropped over night and one battery (only one of 7 as the 8th was off) popped back online.
WingedRyno is offline   Reply With Quote
Old 08-01-2017, 12:32 PM   #388
FWIW, they said "mine" is the first EcoTrek they have seen. I haven't heard of Dale, but they did say the owner's name was Scott I think.
Old 08-01-2017, 12:34 PM   #389
Well, one of us is going in circles and the other is getting dizzy...
As markopolo said, an inverter/charger is different than a standalone inverter (12v DC in and 120v AC out), a standalone charger (120v AC in and a battery charge voltage profile out when connected to a battery), or a standalone converter (120v DC in and regulated 12v DC out with no battery connected).
The inverter/charger has three connections, 120v in, 120v out, and a 12v DC connection to the battery that is an input when not connected to shore power on the 120v input and an output when there is shore power on the 120v input. The RT inverter is different in that the switch must be on for any function to operate including the pass through of 120v shore power from the 120v input to the 120v output. The inverter can get power and be turned on when there is shore power on the 120v input or from the battery connection when not on shore power. If all Ecotrek batteries are offline and you are plugged into shore power the 12v output is unregulated and reported to be very unstable when connected to the coach through the battery relay.
Old 08-01-2017, 12:34 PM   #390
Only an RT tech can tell you what happened.
(but they won't)
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
