08-03-2017, 08:26 PM
#481
Originally Posted by booster
Could it be the solar holding the module full by covering the parasitic, even when the main disconnect is off?
The AGM won't hold that high of a voltage for long as it would be all surface charge. It will drop to about 12.8v very quickly.
What I'm thinking is AGM could be providing power to the BMS instead of Lithium, therefore Lithium voltage stays intact. When Ecotrek is connected to the load side, it has no choice but to power itself including BMS.
08-03-2017, 08:29 PM
#482
Originally Posted by vsandlk
Refrigerator selector switch was at 0 setting, I checked.
Is the inverter on?
08-03-2017, 08:31 PM
#483
Hard to tell, I think. We have all assumed that the parasitic from the modules when turned on was from the connecting relays, so whenever it was on active they would be connected to as far as the coach power switch. How new is your unit?
08-03-2017, 08:32 PM
#484
Originally Posted by cruising7388
Is the inverter on?
No inverter was off as well. When battery disconnect is OFF, this all doesn't matter since no power connected to the load side.
When I initially turn Ecotrek module on, it's disconnected from the load side by default. I have to press "Reset" button for it go online. In both cases I hear relays clicking but with different sounds.
08-03-2017, 08:34 PM
#485
The unit is only couple weeks old.
08-03-2017, 08:37 PM
#486
The other thing I noticed is when Ecotrek is on but disconnected from the coach, the solar charging is very fast as it does not have to go against parasitic load. Also, I noticed that voltage showing up in this case is 14.10 volts or even higher, while when Ecotrek is connected to the load side, it rarely goes above 13.5.
08-03-2017, 08:44 PM
#487
Originally Posted by Davydd
It's not so simple. The optional second alternator MB brackets used for the Nations don't work for the Delco-Remy alternator. Advanced RV had to design and manufacture a costume bracket and pulley system among other things to accommodate the Delco.
I don't think ARV is motivated to just sell Delco alternators equipped with their custom torque converter. Without that feature, a basic Delco would be considerably noisier and I wonder if it could impact engine main bearings. Beyond that, for an aftermarket installation, the bottom line cost of materials and labor could cost upwards of $3,000 which begs entertaining whether it's worth the return on the investment if you're not insistent on running an AC off grid all night.
#488
There must be something here as the whole purpose of AGM I believe is to provide power to BMS and wake up a dead Lithium module should it go offline due to low voltage, etc.
08-03-2017, 08:49 PM
#489
Speaking about alternators, I noticed that on my Agile the second alternator is located very low, just behind the front bumper. On Zions built on Promaster chassis the location is even lower. It probably has to do with cooling. At the same time it's exposed to the elements or debris which is not good I believe. I already hit a crow on my first trip but the alternator held well
08-03-2017, 10:07 PM
#490
Sorry I haven't posted more today, it's just that I was busy driving my new RoadTrek Adventurous
Third Balmar fixed the issue and they showed me before I signed the paperwork, gave me a check for my lodging costs, and I split. I'm very happy in the end.
GU is charging them up driving too, so I'm at a campground on a lake now doing some testing after a couple hours of driving.
I'll be particularly interested in testing out the air conditioning because I suspect it's not working properly at high temp but jury is still out. Then testing out the dumping stuff. Then the Alde which I hear has many issues for many folks. Fingers crossed I'm not one of them.
Good to be an official Class B guy Thanks to all you old heads for the help along the way. Much appreciated!
08-03-2017, 10:27 PM
#491
Congratulations!!
I thought the title "Warp Core" was a joke until I searched and found out that is what Roadtrek calls the big battery setup is their brochure.
Warp Core Package – EcoTrek 1600 & 600W solar
http://www.roadtrek.com/wp-content/u...re-08-2016.pdf
Happy travels.
#492
Excellent news, congratulations!
08-03-2017, 10:56 PM
#493
The MB optional second alternator bracket itself will not work for the Delco. They did custom develop their torque converter too as you say which only means you could not simply swap out a Nations with a Delco without a lot of knowledge and know how as assumed by BBQ.
There are more reasons for a second alternator than just air conditioning. My understanding is a single alternator allows only 60 amps of charging for functions other than the chassis. That is not much for my 800ah battery bank. The Nations when throttled down for heat at about the mentioned 150 amps proved to create a death spiral of not keeping up with all the other electrical demands along with air conditioning. My Delco steadily charges at 220ah plus when idling. The Nations inadequacy was proven by Advanced RV customers in constant 90 degree plus temperatures mainly in the southwest. For me it was not critical. This and I don't think Advanced RV's system that there is the parasitic loss of battery amp hours as the Roadtrek's.
I don't even understand having a warp core 1600ah system if there are 8 modules you have to control and monitor separately especially without the suspenders of Voltstart. And I thought Voltstart was a standard not an option. I don't believe it can answer air conditioning needs in any practical manner. With my experience I've determined a 400ah lithium battery bank with some attendance can make me independent of shore power without air conditioning in the equation. My 800ah battery bank makes it a no-brainer worry.
Weight, space and charging considerations take effect in battery systems greater than 400ah and lithium is the practical way to go.
The second alternator makes economic sense when you can eliminate a more costly and maintenance headache of an Onan generator and its necessary attendant propane system in Sprinters.
Advanced RV may have moved past first Nations and maybe the Delco with the 48V Volta adaption. I hope to know more soon.
BTW, an aside, you know Mike Wendland traded in his beta Roadtrek after 2.5 years for a standard 800ah lithium battery system, their standard 470w solar array and conventional roof top air conditioner. He didn't opt for Warp Core. I guess his experiment is over. Campskunk had the other one.
08-03-2017, 11:01 PM
#494
Your observation is correct but I don't think it's for the reason that you suggest. If the battery is on,(blue light) it is experiencing the parasitic BMS loss and this will be the case whether or not the battery disconnect switch is on or off. But when your disconnect switch is on, because of the unexplained additional load drain you are experiencing, the solar panel has to support that in addition to addressing the BMS parasitic loss. Between the battery parasitic and the mysterious coach load, it probably can't meet the total discarge level which accounts for battery depletion.
The lithium parasitic load is a fact of life for which there is no practical remedy other than shutting the battery itself off but this will shut down an operating fridge. So, the next step is identifying this mysterious load downstream of the main battery switch. It isn't the switch itself because unlike the lithium relays, the main disconnect relay is a bi-stable design and is powered only momentarily when this switch is toggled on and off. Whatever this load is, it most likely being delivered through a fused circuit. What I would do is to determine which 12V fused circuit is pulling current. A nifty tool for that is a fuse with an ammeter that will display any current draw when inserted into a fuse receptacle. Harbor Freight sells them. BTW, if you do roll by a Harbor Freight, and you don't have one, buy one of their digital meters. The cost is chump change compared to the invaluable assistance it provides in electrical troubleshooting.
08-03-2017, 11:22 PM
#495
As usual, you do an excellent job of peeling the onion. Thanks!
ARV will provide 1600ah if the customer demands it but ;they don't recommend it. I think they have only built one unit this way.
The Volta system could produce a whole new playing field. If you think about it, there's something bizarre about living with the constraints that low DC voltage delivery creates. As far back as WWII the jeeps were already running at 24 volts. It took a couple of subsequent decades for the industry to move from 6V to 12V. I imagine the frame size requirements for the Volta are appreciably smaller than the Delco.
If you upgrade to a new coach, would you consider including the leveling system that ARV can provide on the Sprinter? I had a small Class A with HWH levelers that I loved. Until now, Mercedes wouldn't authorize levelers of any kind even when HWH offered levels requiring no chassis drilling. When boondocking, those levelers gave me a myriad of choices in where to set down for the night that would be unusable in our 210.
08-03-2017, 11:36 PM
#496
It is highly unlikely you got two bad regulators.
Umm..er..... uh.... sir, what is it you don't understand about black swans?
Both Nations and Balmar are good companies and I think they will get to the bottom of this in short order. Hopefully, it won't involve an entire production run.
08-03-2017, 11:54 PM
#497
I do still think it is highly unlikely. Of course anything can and does happen sometimes. I think it is also just as likely, or more, there was something else that was wrong, either wiring or how set that contributed, but we will never here about that if it was.
08-04-2017, 12:59 AM
#498
Congratulations.
Have fun.
08-04-2017, 01:37 AM
#499
I believe ARV installed 1200ah battery systems but not 1600ah. One installation was because of medical needs of the customer.
I'm on the fence about levelers. I need to level about 1 in 10 times so don't feel I need them for that task. The VB Air Suspension takes out a lot of leveling needs where maybe one lego block would do. However, my wife is deathly afraid of parking on a sand beach. Up and down the Gulf Coast of Texas I couldn't convince her. So, a 4 x 4 with the added levelers to get out of a hole might persuade her. I hope to never need it as James for TheFitRV intimated for changing a tire.
08-04-2017, 07:27 AM
#500
………………………… Then the Alde which I hear has many issues for many folks. Fingers crossed I'm not one of them. …………………
Congratulation and have fun. Is your Alde diesel or LPG power?
Thread Tools |
Display Modes |
Linear Mode
