Old 09-19-2019, 04:21 PM   #1
Default Replacing Macerator Hose for 2016 Roadtrek
Really appreciate this Forum since Roadtrek went AWOL with our Parts & Warranty. It’s forced me onto this Forum and I am a better man because of it!
Have 2016 Roadtrek Etrek with cracked green Kanaflex hose and need to replace
Would like to try another brand since the Kanaflex seems to stiff for retractable small sized storage bin - so the hose eventually cracks.
I have some confusion on whether the previous posts for Roadtrek hoses have the same macerator set up as mine (retractable) so not sure we are comparing apples to apples.
I have a Shurflo 3200-200. I believe hose is 1” & about 8-9ft. Wondering whether Sani-con hose from Thetford company is too ‘soft’ to push back into Shurflo Macerator?
Buy 21’ and cut the hose?
Also would appreciate some reviews on Sani-con compared to other hoses?
Flip is offline   Reply With Quote
Old 09-30-2019, 10:11 AM   #2
Dogman's Avatar
Welcome to this Forum
2021 Mercedes-Benz 3500XD, Galleria, Li3
2005 Winnebago Tour, Cummins ISL 8.9L 450HP turbocharged
2003 Forest River, Reflections, Freightliner Chassis
Dogman is offline   Reply With Quote
Old 09-30-2019, 11:19 AM   #3
We have had a Sani-con for many years in our 07C190P Roadtrek. It works great, fits in the storage much better.
I found it best to use a heavier, radiator hose type, rubber hose from the macerator to the storage compartment for the macerator hose. I put a bulkhead barbed fitting in the storage area and hooked the rubber hose to the outside and Sani-con to the inside.
Old 10-01-2019, 11:20 PM   #4
I have a '15 210, and just changed out that hose. I got the Thetford 7' which expands to 21' on Amazon;. It comes with a connection piece. That green/yellow hose is really thick, and since the section leading from the macerator wasn't bending or kinking, I cut it off at the drawer, used a heatgun to soften, lightly greased the connection and joined them together. i had this hose on another RT, and it lasted forever. Ron
Ron J. Moore
'15 RT210P
Old 10-01-2019, 11:58 PM   #5
Good fix. Wonder why they'd use any other hose?
Old 11-07-2019, 09:59 PM   #6
Dogman's Avatar
Welcome to the IRV2.com FORUM(S).
When you first enter this group, a new Member may feel a bit overwhelmed by all the forums you can find here. First, you need to set up your USER CP
Once you open and start a menu will open on the left side just take it all in the step-by-step top to bottom.
NEXT, you will find this forum is made up of 14-Forums broken into four-part forums.
First is the HOME, top left above the member's menu. This forum is very helpful to new members to learn and become more familiar with overtime.
NEXT TO HOME is FORUMS on the top left covering Community, RV Lifestyles, Regional and RV Camping. and to the right of this is RV Forums.
RV FORUMS on the top left covers a lot about TRUCKS, Conversations, MVT's, HDT's, Travel Trailers/5th Wheel Chassis & TECH stuff, Chassis CLUB, RV SYSTEMS, Powertrain Garage.
NOW when you Post a new Tread take some time to think in which forum it should read best. Next after completing your TEXT on the bottom are TAGS, so make sure you have a few tag EXAMPLES: dog, RV, rving, campfire So try for about five if you can.
Then you have the OWNERS FORUMS Covering Registry, A-M, and N-Z.
Now if you pan down to the bottom of the page you will find other FORUMS and if you know or have a Class B, you can direct or join the CLASS B FORUMS at Class B Forums And if you get down to Florida this link may be very HELPFUL http://www.CampFlorida.com
So, welcome you again, I hope you join in the fun and share your knowledge by helping new members find their way in this forum as you would in, any RV Park. Again, make sure to set up your USER CP as this is helpful to you and other members. Again if you enjoy or think of starting your own RV Blog you can do that here as well above on menu bar is BLOGS
Enjoy and safe TRAVELS. You can also find RV PARKS above in CAMPGROUNDS. Wal-Mart Parking locator & Bed & Briefest
http://www.allstays.com/c/wal-mart-locations.htm
Welcome to our FORUM, may you be blessed with Happy Travels and safe Trails on all your Road Trips.
