Old 07-09-2018, 07:01 PM   #1
Default Are highway miles easier on the system than city/local miles??
I would argue that long distance highway miles are far better than local city stop and go traffic....less wear on engine, transmission, brakes, etc....
Once you are up to cruising speed... it's just a constant RPMs of all systems....
Do you agree???
Old 07-09-2018, 07:43 PM   #2
This seems to make sense to me.
David & Angela
2008 Pleasure Way Plateau TS
Porsche911 is offline   Reply With Quote
Old 07-09-2018, 07:57 PM   #3
Agree. Among other things, from what I understand, wear on engine parts goes way down once the engine is up to operating temperature. Heat in the transmission also seems to increase when the transmission shifts more often. This happens less often on the highway.
WJones is offline   Reply With Quote
Old 07-09-2018, 08:47 PM   #4
Default Thank you....
Sorry I initially misread your reply on the spare tire.
Old 07-09-2018, 09:12 PM   #5
Default Great...I appreciate it
You know.... I have mixed feelings about running up miles... but, people tell me...diesels love to run ... keep lubricated, and seem to thrive on long distance highway miles..
I know that there's a lot of misconceptions about high mileage and people are many times fixated on wanting the lowest miles possible on their vehicles...
SO... while I really love the idea of a low mileage vehicle...it means that you didn't get the fullest use by keeping it as a museum piece.... And not driving it... doesn't make sense...
AND... highway mileage is MUCH less stress on the system... Just about everything from shifting to braking.. and everything in between..
That's probably why long distance trucks get 500,000 to 1,000,000 miles.. I know someone who drove a Subaru Outback..in 6 years went 300,000 miles... all highway ...
It's not just the miles.. it's the years...
I got it in May 2017 with only 26,000 miles.. now has 42,000... still pretty low mileage...
My vehicle is this below.
https://www.conejowholesaleauto.com/vehicle-details/f22d7e5afa634d388dbeffb59e9eb708
It's like an executive jet on wheels...😁😁😁
I could worry about mileage....but , then again.. it's taking us lots of places and adventures I would have not otherwise been able to go...
Might as well just get out and enjoy it...
Old 07-10-2018, 04:02 PM   #6
Not a problem, thanks anyway.
David & Angela
Old 07-11-2018, 01:51 PM   #7
Slow driving doesn't hurt them as much as it used to, as the newer engines have much better controls on them like electronic fuel injection and timing.
In the day, carbs constantly messed up the mixtures, either being lean and hurting valves, etc, or detonating or they were rich and washing the oil off the rings and diluting the oil (diesels still do this part).
It has always been said that most wear occurs at cold START UPS, with the % being anywhere from 50-90% depending on who you believe. IMO, the likelyhood is that the high end is probably closer for modern engines.
One of the major reasons, I think, that OTR trucks and other industrial diesels last so long is that very many of them have preoiling systems on them to prevent dry cold starts. I have had a couple of the systems that I put on past cars, and they are amazing. I could start a 200K mile Escort at -30*F with oil pressure before ever turning the key. When it started there was no lifter noise at all. That Escort had the preoiler the entire 18.5 years since new and the last oil change went 10K without adding any oil (I had quit changing the oil when I saw the rear suspension was going to fall off due to rust) before I drove it to the junkyard.
IMO, adding pre oiling is the biggest thing you can do to increase the useful life of any vehicle engine.
Old 07-12-2018, 05:25 AM   #8
Default Did you add this feature to your current RV....
Sounds EXPENSIVE..... especially don't know if you could add on the Sprinter..and what would Mercedes Benz think about that?
Old 07-17-2018, 07:49 PM   #9
Joe
Joe's Avatar
Send a message via AIM to Joe
I have always heard highway miles are better for a vehicle. I have a 1995 Dodge Class B Explorer with 56,000 on it. We have put most of the miles on it. It only had 23,000 when we bought it 10 years ago. I also have a 2005 Dodge truck with 279,000 miles on it. Mostly all highway and frequent oil changes.
Old 07-17-2018, 08:34 PM   #10
Default Thank you
I knew two people who drove many highway miles.... going 55 to 65 MPH for sustained hours... both had hundreds of thousands of miles.....less wear on the engine, transmission, brakes and tires... wheels turning that are going straight ahead are not wearing like cars or vehicles stopping and starting.....
Old 07-17-2018, 10:01 PM   #11
Not all that expensive compared to shortened engine life or repairs.
There are a couple of different types of pre-oilers, mainly they either use a passive accumulator to gather and hold oil at pressure for use at starting, or they use an electric pump to take oil from the pan and pump it into the engine before starting.
The accumulators require you to have quite a bit more oil in the system, maybe a gallon more in many cases, so I am not a big fan of them and prefer the electric pumps. Downside of the pumps is that you need to remove the pan to mount a pickup fitting to it. Most of the time, the oil goes back into the engine at the oil pressure sender port, but sometimes you need to get to an oil gallery plug.
Most of the systems can be had for 3-500 dollars plus installation.
I don't think MB would have any issue with one on their engines, as they would be very familiar with the concept from their OTR truck diesels.
Old 07-19-2018, 06:12 AM   #12
Miles IMO should be less of a concern than most make it out to be. I bought PW Chevy Express with 108k. Before I bought it, I went to Auto-Trader to see what the actual vehicle could handle. I did a sort by miles, highest to lowest, and there were at least 50 for sale with between 300 & 400k miles. That blew me away.
Also, you never know what to expect, for example, something major goes wrong at 95k, you buy it with 65k, vs. the person who bought it at 96,000 miles. Again, JMHO
Old 07-19-2018, 06:45 AM   #13
Default Agreed..
I agree with you 100 percent...
I think it's more about proper servicing and maintenance.
I've known people who went over 300,000 miles on their cars and met one person with a Sprinter who went almost 500,000 miles original engine.
So, there's a lot of factors here. Sure, anything can happen... even under 100,000 miles especially if not well maintained.
I think... highway miles running at a steady speed is easier since there's less shifting, braking etc.
How many miles are currently on your PW Chevy Express and what year is it?
Another key point.... the more miles you go ... over many years, the less per mile it takes to run the vehicle. In other words, traveling 500,000 miles divided by your total cost will be a lot less than going 100,000 miles divided by your total investment.
Old 07-19-2018, 03:38 PM   #14
I have around 112k on an 08 (Actually 09) I'm the 2nd owner. I just got it in March. I too have known people who blew past 300k.
I think age and miles are not all that important. Prior to picking up my RV, the consignment dealer discovered the AC was shot, refrigerator board blown, generator had never been used, so they needed to work on the board and carb, and grey water pipe leaking. All of these things were fixed. Nice new A/C. Point is, had I purchased it a year earlier, I would have been in for some cash, aggravation, and time wasted. The different Facebook forums I'm on, it sounds like the biggest issues are coming form the 2016-18 models. Nice to have all the new bells and whistles, but if they don't work, or keep breaking down, what good is it?
Old 07-19-2018, 04:13 PM   #15
Default My 2012 RS Adventurous is on the 2011 Sprinter 3500 dual wheels ....V6 turbo diesel
Tom,
Here's my rig......
https://www.conejowholesaleauto.com/...beffb59e9eb708
Old 07-19-2018, 05:58 PM   #16
Sweet! Very nice.
Thread Tools
Display Modes
