Old 04-07-2015, 09:05 PM   #41
Default Re: Believe it or not, I bought a new van!
Wincrasher, Thank you very much for your quick reply. It's a long shot project, so no need to rush to get the info you have. My guess is that it can be found somewhere in the Fiamma manuals you received. I wrote to Fiamma USA, and i'll post their reply.
My 200 lbs already tested the PM roof, and it seems strong enough if you stay on the sides
Enjoy the good life in the Travato!
Old 04-08-2015, 03:11 AM   #42
Wincrasher,
I have an Oru Kayak as well. Can you fit it diagonally under the bed and still fold down the bed?
JP
eurovanman is offline   Reply With Quote
Old 04-10-2015, 04:54 AM   #43
Sweet rig!!
I was looking at putting suck rack on my promaster.
Can you easily 2 bikes on it with clearance with the rear door? It seem tight if the bikes are mountain bikes.
Also, can there be contact with the side of the van if opened too much with or without the bikes or they modded the hindge to stop before?
Thanks!
Sampep is offline   Reply With Quote
Old 04-10-2015, 11:44 AM   #44
20 minutes to get the water hot enough for a nice shower? Is this true?
meagain is offline   Reply With Quote
Old 04-10-2015, 01:02 PM   #45
wincrasher's Avatar
I have not timed it with a stopwatch.
Most RV hot water heaters take 15 to 20 mins to get fully hot from a cold start. This one is no better or worse than any others on 110v.
The couple full timing in their Travato posted that they would run the generator for 10 mins and get the water medium hot, and then shower with the spigot on full hot instead of trying to mix hot and cold.
If you want instant hot water, then you probably need to look at the Pleasureway Lexor which has a tankless water heater setup.
2019 Winnebago Travato GL
Old 04-10-2015, 01:23 PM   #46
Originally Posted by Sampep
Sweet rig!!
Thanks!
I believe Winnebago limits the door swing with a steel cable stop to keep it from swinging all the way around to the van side with this bike rack. The Fit RV video showed that. It only makes sense to do that. If you were facing downhill opening a door with that weight could easily get away from you and slam the side otherwise.
Old 04-10-2015, 01:36 PM   #47
The typical 6 gallon Suburban propane water heater in a lot of Bs produced hot water in 15 to 20 minutes for us.
The Espar setup in Advanced RVs and Great West Vans utilize a diesel fired glycol heat exchanger for both heat and hot water and is practically instantaneous and continuous, meaning limited to your fresh water tank size or unlimited if hooked up to city water.
Old 04-10-2015, 04:11 PM   #48
wincrasher's Avatar
Sweet rig!!
Thanks!
Correct, I show it in my video.
Old 04-10-2015, 04:34 PM   #49
sounds like 'watched pot syndrome;.
Old 04-13-2015, 08:48 AM   #50
What made you choose between the 59K and 59G. The fridge is smaller although not sure how much smaller. I'm liking the 59K better becaus eof the new features such as solar panels, water heater etc. I also thought the 59K look roomier. I would buy the gas version only.
tbirdman is offline   Reply With Quote
