Old 07-07-2017, 03:00 PM   #21
that's a nice arrangement.
Old 07-07-2017, 04:41 PM   #22
Agree bbq, and I'm lazy, so I just ordered one.
Old 07-16-2017, 08:08 PM   #23
Thanks Mr. markopolo.
The switch is installed and working fine.
Old 07-17-2017, 12:11 AM   #24
They're useful units. I have a second one in the house basement used for battery backup on a sump pump.
'97 GMC Savana 6.5L Turbo Diesel Custom Camper Van: https://www.classbforum.com/forums/m...icture206.html & http://www.classbforum.com/forums/f6...vana-5864.html
Old 07-17-2017, 04:11 PM   #25
Don't overthink the exact resistance value for a couple of reasons: first, most inexpensive meters are not terribly accurate at low resistance values because of resistance in the probe wires and the possibility of a poor connection on what you are measuring. Secondly, there is some variation in the resistance of the element because of measurement temperature and manufacturing variations. If it shows open or something like, say, 10 ohms it is probably bad.
Old 09-07-2017, 06:51 PM   #26
jmai's Avatar
Follow-up
I recently returned from a three week trip to Canada. The refrigerator did what it is supposed to do. We didn't have any spoiled food and even made ice cubes.
Some observations in no particular order.
We used all three modes, AC, DC and propane. AC when in campgrounds with shore power, Propane when in campgrounds without shore power and when driving, Occasional DC use when driving, but it definitely raised the temperature. (I think it works, but not very efficiently).
I have a 2 wireless thermometers with a central receiver so I can monitor freezer and refrigerator temperatures. Definitely worthwhile because you absolutely know what the temps are and how much cooling capacity each mode is capable of generating.
I used one of the battery operated fans inside the refrigerator, blue cube-shaped fan that works on 2 D cell batteries. It ran continuously for three weeks and still did not drain the batteries. Impressive!
Temps varied-from -4 to 20 in freezer and 32 to 54 in refrigerator. Overnight with AC cooled very well.
Use basic principles to keep refrigerator cold.
Leave room for the air to circulate. Blue cube fan helps.
Try to put cold food in refrigerator when on the road-cold beer, frozen items etc. Large, room temperature items will noticeably warm up the refrigerator.
Minimize opening the door-think of what you need and get them all out at once.
When driving and running on propane, sometimes the flame would go out. Monitor the gauge and temperature.
Shut off propane when re-fueling and then drive away from pump before turning on propane valve and re-igniting the refrigerator.
Temperature setting is not easy to turn up and down. Probably better to leave it on one setting. I increased the temperature several times and froze the lettuce!
I used 4 blue ice packs (two small and two large) to help the refrigerator during the day when we were not connected to AC. I froze then at night and then put them in the refrigerator during the day. This worked pretty well to stabilize the temperature.
Check the tray under the freezer that catches the melted water from the freezer fins. During our trip, it was minimal, but there was some water to empty.
I use the expanding, spring-loaded bars to keep items on the shelves. Very simple and effective.
After the trip, clean out and wipe all surfaces of the fridge and air it out.
My latch has two positions, one to keep the door fully closed and one that keeps it open about 1/4 inch for airing out. (I use this position when we are not traveling and I also prop open the freezer door. Good air circulation when not is use is the key).
Make sure your gaskets are sealing properly and have no gaps.
After you load the fridge, make sure no items are keeping the door open. I noticed it was possible to close the latch and have gaps between the gasket and the front edge. I usually pushed in the expandable bars a bit or re-arranged items in the door.
When parking, try to keep the refrigerator side in the shade. This works and make a difference.
During the day when we start and stop and go in and out of the RV, the refrigerator knob needs to be adjusted for DC or propane. Its easy to forget and not have the refrigerator on. Make it part of the checklist items and check the temperature monitors.
The ammonia based refrigerators definitely need to be level to work. This is fairly easy to achieve when you are in a campground with leveling blocks. However, when you park and leave the unit for a hike or to go to see some sights, you may be on uneven ground. If it is really tilted, it is probably better to turn it off while you are gone. (This is where the blue ice packs are really helpful). The previous owner put bubble levels that I can see from the driver's seat. One over the rear view mirror for side to side leveling and one over the top of the passenger's door for front to back leveling. Simple, yet effective.
Get to know your refrigerator and how it works and how efficient it is when you are home. Try it out in the driveway for a few days. (My wireless monitor works from driveway to my house so I can see how it is cooling). The last thing you want is a surprise when you are out on a trip and notice the temperature won't go below 50 degrees.
Realize that these ammonia based refrigerators are basic. Be realistic. These are not units that you simply turn on and forget for a week. They need monitoring and leveling.
So, it is possible to use your refrigerator on all its modes in both campgrounds and boon- docking situations. Just be realistic and don't expect it to be like your home refrigerator. When we got home I was able to empty the refrigerator and use all the food we didn't use, especially the condiments. My test was the mayonnaise, still good after three weeks!
Joe
jmai is offline   Reply With Quote
Old 09-07-2017, 07:04 PM   #27
Interesting, I have been informed never to drive and use propane, am I missing something here?
David & Angela
2008 Pleasure Way Plateau TS
Porsche911 is offline   Reply With Quote
Old 09-07-2017, 07:14 PM   #28
wincrasher's Avatar
Part of your problem may be over-stuffing the refrigerator. A 3-way fridge needs air movement inside to work. You can't pack them in like your compressor fridge at home. Many people put battery operated circulation fans inside to help even out the cooling and making them work more efficiently.
FWIW, it's perfectly fine to drive with the refrigerator on LP. Only in certain tunnels are you required to turn your propane off.
2016 Winnebago Travato 59K, 2017 Tiffin Allegro 32SA, 2000 Xplorer 230 XLW
Old 09-07-2017, 07:28 PM   #29
jmai's Avatar
Some people do and some people don't. I've read comments both pro and con.
If my DC mode worked better, I wouldn't use propane when driving.
Joe
Old 09-07-2017, 08:08 PM   #30
"32 to 54 in refrigerator"
Hi Joe,
My experience was not much different than yours, Until I used fans outside the refer, less than 50 driving 70mph and 95 degrees. Many others experience the same with Roadtreks like mine 05/04 190P. Some manufacturers do a good job with the air Outside the refer and some don't, like mine. Some even install fans outside the refer.
Thread Tools
Display Modes
» Virginia Campgrounds
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
