Old 10-22-2018, 06:16 PM   #1
Default Ground clearance of the Travato KL?
The Travato KL looks like a very nice rig (although expensive.) Does anyone know what the ground clearance is? I may find myself on less-than well-paved roads.
With Gratitude,
David
Davidy52 is offline   Reply With Quote
Old 10-22-2018, 07:52 PM   #2
I don't do Facebook.
With Gratitude,
David
Old 10-22-2018, 08:24 PM   #3
Thank you Gail for your helpfulness. I may consider this.
With Gratitude,
David
Old 10-22-2018, 08:27 PM   #4
It's about 6 and a half inches. skip facebook
wrightstuf is offline   Reply With Quote
Old 10-22-2018, 08:30 PM   #5
Thank you wrightstuf.
With Gratitude,
David
Old 10-28-2018, 08:28 PM   #6
Default Travado KL
Asking what would the suggestion be for a senior 77 lady with pets get to travel part time. I want a permanent bed, real bathroom, Inverter 2500, solar 270, and like volt start. I want to use it all the time when not traveling. I like the Zion but the beds do not look comfortable. I like the Trend D but that I can no use all the time. I do not want diesel since it is hard to work on, I like the Dodge 3500 Promaster. Any suggestions all are welcome. Thanks, Suzan
Suzrabbit is offline   Reply With Quote
Old 10-29-2018, 03:51 AM   #7
Hello Suzan,
When you say you want to use it all the time when not traveling, do you mean that you will have it parked somewhere and you will use it as your home? If so, will you be able to plug the coach into "shore" power and/or water where you park, or will you be completely independent of hook-ups?
With Gratitude,
David
Old 10-29-2018, 03:21 PM   #8
I'd be most concerned about the very low mounted 2nd alternator they add on. Between road wear, and water, I wonder? The shield basically does little.
talktodean is offline   Reply With Quote
Old 10-29-2018, 08:55 PM   #9
Default Class B's don't generally have great ground clearance....
OK... average clearance is 6 inches??? My Subaru Outback has 8.7 .....
An RV is NOT designed for any off road even light off road.....
Be very careful..yes, the generator is usually one of the lowest points....
Old 10-29-2018, 08:56 PM   #10
Pleasure Way Lexor maybe?
teck13 is offline   Reply With Quote
Old 10-29-2018, 08:57 PM   #11
Default My advice is skip unpaved roads
As I stated in the last post....if you want to go off road.... take a Subaru Outback...not your RV......
Old 10-31-2018, 05:40 PM   #12
Thanks, no I will be using it part time but it will be my transportation full time.
