Old 09-28-2013, 06:46 PM   #1
Default Hood protector gas mileage
Has anybody done any testing on if a hood protector reduces mileage much? I put one on our Chevy before our last trip, and it we did appear to get less mileage than in the past. It is hard to pin it on protector, though, because this was also the first long test of the van with the solar on it and the larger tires.
We did notice less air out of the vents with same fan speeds, and bug reduction was only moderate, nothing spectacular.
I think I may take it off on the next run and see if anything noticeable shows up.
Old 09-28-2013, 11:01 PM   #2
Default Re: Hood protector gas mileage
I would have your speedometer calibrated to accomadate the larger tires, I don't think the bug screen would change the milage noticeably but larger tires would.
sebtown is offline   Reply With Quote
Old 09-29-2013, 12:35 AM   #3
GM doesn't show that size in the tire size flash, so we are out of luck on that. We do have our Scangauge set to the exact speed and odometer, and that is what we do to check mileage.
Old 10-11-2013, 09:11 PM   #4
We just got back from a quick 3 day trip to southern Minnesota. Not a long trip at about 85miles each way, and quite (very?) windy both ways, headwind out, tailwind back, both with some crosswind. I took off the hood protector and put the tire pressure back up to 65/80 psi. We were pretty light as it was a short trip, but did have water and 3/4 tank of gas on board.
It was so windy, it was a bit hard to tell, but it sure looked like the mileage was pretty much back to where it was before the protector, lower pressure on big tires, and solar. It is very handy with the Scangauge to do relatively short segments to see what the mileage is under different conditions without doing fillups and such. The air out of the vents also came back to normal. I think we will leave the protector off and do a bit more testing at the different tire pressures. It is a bit smoother ride at 60/72, and handles about the same.
Old 10-12-2013, 12:09 AM   #5
AmCruiser's Avatar
Larger diameter tires will cause your odometer to indicate that you traveled fewer miles than you actually did, making it look like a reduction in mileage.
The odometer calculates the miles traveled by multiplying the number of tire revolutions by the circumference of the factory specified tires. If the factory recommended tire size was 225/75R16 which has a diameter of about 29", the circumference would be about 92". For every revolution of the tire, the vehicle would advance 92". The vehicle will advance 1 mile (63360 in) every 689 revolutions (63360/92).
If you increase to a tire size with a diameter of 31", the circumference will increase to about 98 inches, so now the vehicle will advance 98" per revolution, 6" more than with the factory recommended tire. For those same 689 revolutions the vehicle will advance 67522 in or about 1.07 mile. When the odometer indicates the vehicle has traveled 100 miles, the vehicle will have actually traveled 107 miles. If you calculate your gas mileage based on the odometer reading, you will be basing it on fewer miles than you actually traveled resulting in poorer mileage than what you actually achieving.
AmCruiser is offline   Reply With Quote
Old 10-12-2013, 01:15 AM   #6
As I mentioned earlier, since GM doesn't seem to offer an odometer flash for the bigger tires, we have our Scangauge set to read the correct miles. It was set based on a 50 mile gps and mile marker run, so it is very, very accurate. IIRC the tire diameters were 31.5 up to 32.7 or 3.8%. The odometer from the factory read almost 2% high, so no it reads about 2% low, but we never went by the odometer anyway, and always used the calibrated Scangauge. Our big concern with the no available flash for the bigger tires, was that the engine and transmission properties also are changed with the flash, and could affect things. We had some limited tests last year on the bigger tires, but not enough to know for sure what was up, that indicated no major change in mileage, and that was at the higher pressures like we used today. Things got harder to evaluate now because the solar went on the roof and the deflector on the hood because then with the bigger tires, and the bigger tires at lower pressure, we wound up with too many variables at the same time. We seemed to be seeing lower mileage on a previous trip so I decided to see if it was really less or not. This last test tried to get rid of some variables so we get better information. As of now, my guess is that the tire size is probably not much of an issue, but lower pressure may be. I think the deflector was probably a larger problem than any of the others. The solar probably is also not much of an issue.
I didn't mention it before, but we also did limited test trying to confirm some things we had noticed before, and that was mileage on rolling hills. I had always known that it got worse mileage in hills if it was on cruise control, especially if it would get into downshifts going up the hills, when you could keep it from downshifting if you were driving it yourself. What had appeared to be going on that I really wanted to test was that it seemed to get considerably better mileage in rolling hills than on the level. Many times we would see our average mileage jump a bunch going downhill, more than it lost going uphill. Couldn't understand that one. We tried it on this last time out on segments of a rolling two lane road. It looks like, based on this small test, we lose about 5-7% mileage when we go on the cruise control in the hills, which was expected. When we compared the mileage on the rolling hills compared to the level, it did almost 5% better in the hills, or about .5 to 1.0 mpg. We also found that we only got that gain if we let the van coast down the hills (in gear). If we just went over the hill and feathered the throttle to hold speed, or get a bit of extra speed to go up the next one without downshifting, the gain was very much smaller, or gone. Watching the instantaneous mileage on the Scangage showed it going to 999 when going downhill with the throttle closed, and in the 30-40mpg with it slightly open. When we watched the fuel delivery on the Scangauge, it was obvious why. They shut all the fuel off when coasting, and they unlock the converter, so you use no fuel at all and you coast better. So whenever you coast downhill, all the engine inefficiency of combustion is gone, and the wheels are mostly unlocked from the engine, letting it roll better. These things never happen on the level, so you have 100% of the time with the combustion inefficiency and drivetrain loss. Since the engine stays closed loop going up hill (from what we saw), it runs about the same efficiency as on the level, so all you do is store energy and get it back going down the other side (carb engines didn't work this way), which theoretically gives you the same mileage as on the level. Having it shut off completely some of the time gives you the extra mileage. Definitely not what one would expect, but it explains why the best mileage we ever got was on a very hilly road in northern Minnesota that you expect to kill the mileage, not help it.
Old 10-12-2013, 12:21 PM   #7
Interesting observations re: hills. Different motor in my van but I've noticed the "freewheeling" down hills and the 999 mpg. My van really picks up speed on some downhills - more than the vehicles in front of me - and I have to brake more than than the traffic ahead even though I keep a very large gap in between my van and the other vehicles in front. Weight and gravity I guess.
Three fill-ups ago it was up hill as soon as we left the service station and up and down for a couple of hours. Some steep climbs too. 4 and 6 mpg on the ScanGauge uphill climbs. At the time I commented to my wife that the mpg for this tank would be very poor. It turned out that for that tank of fuel the MPG (16.26mpg) was average for the trip and slightly better than average for this years (16.05mpg) travel.
Old 10-12-2013, 03:44 PM   #8
I guess it does make sense, and is also confirmed, I think, by the way they drive the vehicles in the hyper-mileage competitions. In those competitions, they accelerate at wide open throttle (less pumping loss), leanest mixture (obvious), to a predetermined speed, then they shut it off and coast to another predetermined speed before repeating the procedure. The only time they are putting in any energy is at full output, so the basic inefficiencies are a smaller % of the total load and fuel use, and the rest of the time they use no fuel.
I have watched our air fuel mixture on the 6.0 gasser, and you have to push it very hard to get it to go off of the leaner setting, so climbing moderate hills doesn't richen it up and use more fuel, like a carb engine would. Don't know how that applies to a diesel, which probably is even better, as they always run with excess air, I think.
Old 10-12-2013, 11:37 PM   #9
Sorry but I'm having a lot of trouble warming up to the logic/math/physics that doing hills (at least any sort of significant hills vs. just minor rolling hills) can benefit fuel mileage, especially if as Markopolo says you have to brake a bit (or a lot) on the downhills, which I also have to do (a lot). Bear in mind that it is very difficult especially on the Chevy Roadtreks to fill the tank all the way and to do it with any consistency, and hence "mileage on the last tankful" results can be deceiving. And then there are the variables of wind, and starting vs. finishing elevations; eek! We've had gas mileages all over the place, but very consistently it suffers badly in hilly terrain. But as the big folks say YMMV!
Disclaimer: My 09/10C190P Roadtrek has a mousey 4.8l motor, and just a 4 speed tranny.
Regards, Dick
Old 10-12-2013, 11:49 PM   #10
Regards, Dick
I totally agree, if you have to brake, it all goes out the window. And it only works if you totally close the throttle going down the hills. It is pretty hard to do with traffic around because of the speed variations. It also doesn't work if you are to the point of getting downshifts on the (as you say, significant) uphills. Coasting down the other side will help, but not enough to make you break even with what you would get on the level sections. Your 4.8 probably has to downshift, or go to power mixture, considerably more often than the 6.0 does, so that would hurt you.
We do all our mileage checks off of the "current trip" on the Scangauge, because as you say, you can't go by the tank fill method and be anywhere near accurate. The "current trip" is nice because you can reset it at any time, so you can do as many tests as you want without filling the tank. Going across Michigan a while ago, we did the tests at different speeds from 50 to 75 in 25 mile segments just to see how it looked. It was as radical as you would expect, varying from 17.6 down to 13.5mpg.
Old 10-13-2013, 12:33 AM   #11
The three tanks with average MPG that tie into the three "hilliest" travel days this year were all sightseeing days. Slow roads, 50 to 55 mph maybe 60. Lots of stopping though at viewpoints. Definitely not 65 or 70 mph days though. Not much traffic either. Maybe that also helps explain it for my van. The 110 kph / 70 mph highway days are not good mpg days.
I can top my fuel off to the point where I see it in the filler hose so that's pretty consistent. The odd fill-up at a full serve pump would skew things a bit.
Time to learn how to use more features on my ScanGauge - I've had it for more than 5 years............
Booster suspects his hood protector ............. I've been wondering about those two antennas I added to my van. All these things that increase resistance add up. The 2014 Sprinter has improved MPG http://www.classbforum.com/phpBB2/vi...&t=2733#p16348 - they achieved it with maybe 5 different features / improvements some only giving a 0.2 l/100 km gain but all those little gains add up. I'm doing the opposite by adding weight and antennas and cargo boxes. Each of those has a negative effect. Maybe as much as 1 mpg on my van all combined.
Old 10-13-2013, 01:57 AM   #12
I first noticed what I thought was the better mileage in hills about 4 years ago, and just assumed it was calculation error or setting error on the Scangauge. We go 21 mpg on a very hilly stretch of northern Minnesota (big tailwind, too). As soon as we hit the level the mileage dropped to under 20 (average) in a short time. It always stuck with me as odd, so I would watch the Scangauge as we drove different areas, and it did seem to repeat, although we didn't do anything specific to prove or disprove it as I didn't know how to use the "current trip" properly until recently. I surely agree that it does not pass the logical test, especially for those of us that grew up tuning carburetors. I never mentioned it much because I knew it would not make sense to folks, because it didn't make sense to me, either. I just kept watching.
Now I am even more curious, so I did a quick Google of it to see if there was any information out there. The hypermilers seem to be all over it, calling it automatic drive and coast, and many say they get better mileage in hills. It gets hazy when there are a mix of folks with hybrids, diesels, and normal cars, though.
Here are a couple of sites that talk about it:
http://ecomodder.com/forum/showthrea...mpg-24493.html
http://physics.stackexchange.com/que...ing-over-hills
As always, this is internet information, so take it for whatever you think it is worth!!
Marko--I think you will like the whole range trip data available in the Scangauge. We use ours quite differently than they describe to in the instructions, but it works better for us as it eliminates trying to make sure the tank is topped off all the time, and eliminates a lot of calculating. Here is how we use some of the trip data collections.
If you go to the trip section you can get "tank" "today" "yesterday" " current"
The tank trip is intended to be reset when you fill up, and you also put in how much gas you got so the unit will calibrate to the vehicle. We found that using it this way never worked because of the inconsistency of the Chevy fillups. We got it set to what we thought was the right calibration, and then checked it for accuracy over entire 2-3000 mile trips, so there was only one fillup inconsistency possible. It is now tweaked in very closely, and we never change the correction.
We use the "tank" setting to keep track of our entire trip, or big segments of it. Nothing says you have to reset it when you fill, or partially fill, the tank, and we don't. We just keep adding gas, and it keeps on compiling the average mileage, some mins and maxes, and the number of gallons used. We fill at the end of the trip and compare the gallons used (we keep a total of what we bought) against the Scangauge gallons as a doublecheck. It gives a very, very easy way of knowing your entire trip, or segment, mileage. It also allows us to do a partial fill without losing any information. Our last "tank" was for 2600 miles.
"today" is pretty obvious. It is the mileage data for the day.
"yesterday", never guess that it is yesterdays data.
"current" is the one we use a lot. It is the mileage since the last engine start, or the last "reset" of the current trip. You can reset it by pushing a button at any time, while driving, to start a mileage average for however long you want, and then reset again if you want. With smaller amounts of mileage in the average, the average reacts to changes in instantaneous mileage more quickly, so you can tell what terrain, speed, or driving style are doing to the mileage. I used to try to use the instantaneous mileage for this, but it changes too quickly to be able tell anything useful. If you have only about 50 miles on the "current" trip, and you get in rolling hills, you can watch the average go up and down .1 mpg or more on every uphill and downhill. Then you can see if the overall is increasing or decreasing as it oscillates, which tells you if the hills are helping or hurting, based on how you are driving.
A confusing thing is that the "tank" and the "current" trips are reset in totally different areas of the Scangauge, so you don't really relate them to each other unless you think about it and find them.
Old 10-13-2013, 03:12 AM   #13
Facinating stuff about the Scanguage Booster; I'd like to know more. Can I suggest that we take this to a new thread (maybe Markopolo can just make it happen by copying the pertinent posts to a new thread), as the current subject line is way off (actually, the other way around).
Back to Booster's last post: How do you adjust for generator fuel useage?
Thanks, Dick
Old 10-13-2013, 12:28 PM   #14
I'm not sure how to split this topic up. It covers a lot
Accessories that reduce MPG
Excellent info on tire diameter and MPG
Hills and their effect or lack of effect on MPG
Utilizing your ScanGauge
I don't mind continuing as is or someone could start a "Getting the most out of your ScanGauge" or "How do you use your ScanGauge" or similar topic.
Old 10-13-2013, 02:32 PM   #15
I like the idea of a Scangauge thread. The more I have messed with it, the more I figure I don't totally understand some of the way it works, or why they did things the way they did. We may not even be using it right, so it is always good to have others try things and compare.
Marko-would you prefer me to start a new topic or could you move the Scangauge stuff out of here, which might be the easiest (at least for me!)?
Old 10-13-2013, 03:16 PM   #16
new ScanGauge topic here: http://www.classbforum.com/phpBB2/vi...php?f=9&t=2808
