Old 05-22-2017, 02:41 AM   #1
Default Oil Light comes on and drops pressure when I turn
I noticed lately when I make a right turn my oil gauge drops to L and the red light comes on, but only for a split second.
No leaks though...weirdest thing.
Has anyone else had this happen?
1997 Dodge 3500 Pleasure Way.
Thanks,
Mark
saenzm is offline   Reply With Quote
Old 05-22-2017, 06:11 PM   #2
Bruceper's Avatar
1) You need to add oil
2) Your pickup or pump is failing, take it to a shop.
Old 05-22-2017, 08:06 PM   #3
Probably the pickup/sender unit. I had an erratic old pressure reading once in the middle of a long trip and, with each bounce on the dial, the pressure reading dropped a little. Pulled into a Dodge/Chrysler dealership in Idaho Falls. Mechanic said immediately "oil pumps in these engines are built really tough and never fail". He checked and it was the sender. Replacement was about $100. No problems since. Or, as Bruceper says, maybe just low oil level.
Les
1995 Dodge 350 Pleasure Way, 318 cid engine.
LesM is offline   Reply With Quote
Old 05-22-2017, 08:21 PM   #4
Hopefully just a sending unit. I have seen the small block Chrysler engines where the bracket that supports the oil pump pickup breaks and allows the pickup to come lose or move a cause a leak. It is not a common problem however.
