Old 06-01-2017, 09:33 PM   #1
Default Running fridge works on electric - won't light on gas
Ok...more newbie stuff here. Fridge works on Electric just fine, but unplugged the unit and tried to light the unit and won't light.
Does the generator need to be on to run the unit on gas? Does the car need to be on?
Any tips on how to get this thing lit?
I'll be plugged in at camps, but wanted to run LP on the road to keep stuff cold.
Mark
saenzm is offline   Reply With Quote
Old 06-01-2017, 09:36 PM   #2
By the way...stove works great.
Old 06-01-2017, 11:26 PM   #3
BBQ
You might need to clean out the burner
Old 06-02-2017, 01:50 AM   #4
The fridge needs to have electricity to run off of propane - the fridge controls need it, as does the ignition for the propane. So the battery disconnect switch needs to be turned on so the fridge has 12v power.
You shouldn't need to turn on the generator, though. The battery should be sufficient.
2003 Roadtrek 190 Popular
Gryphon is offline   Reply With Quote
Old 06-02-2017, 01:52 AM   #5
Ok, wasn't able to pull out the burner...it's way down in the compartment, but did vacuum everything out around it and lit it. It's kicking a nice blue flame as it should.
So is it possible the flame is lit but the fridge is not cooling? Keep in mind the fridge works perfectly when in electric mode.
Thoughts?
Old 06-02-2017, 02:01 AM   #6
BBQ
It takes time for the fridge to chill.
How long did you leave it to burn?
I would expect 10 hrs to feel the cold.
But once it gets going, it will stay very cold.
Old 06-02-2017, 02:03 AM   #7
So far, about 20 minutes. LOL I just cleaned it out...gonna let it run overnight and see if it's down in the 40s in the morning.
