Old 09-21-2017, 08:24 PM   #21
Boxster1971's Avatar
The Sprinter automatic transmissions require a fluid change every 40,000 miles. They may have been longer in older models but were updated by Mercedes vans.
- - Mike
Old 09-22-2017, 11:12 AM   #22
The multiple drain & refill method can be a recommended OEM procedure depending on make & model.
It is a described method for my '09 Escape. There's a note to do it 3 times to clean the torque converter.
In order to completely clean the torque converter, this procedure needs to be carried out 3 times.
Thread Tools
Display Modes
