Old 10-24-2018, 12:18 AM   #21
Originally Posted by GallenH View Post
bwolfsohn: Which Ryobi model do you have? They have a few. Is it the P737? Thanks!
Yes, that's it...
bwolfsohn is offline   Reply With Quote
Old 10-24-2018, 12:19 AM   #22
Cool. Thanks.
Old 10-24-2018, 11:29 PM   #23
Originally Posted by bwolfsohn View Post
I use the Ryobi 18v system for many of my power tolls. They have a very nice handheld compressor a little bit taller than a drill, but only 3 inches or so wide. I've used it to add up to 10 lbs of air to both fronts and rears. (60 in front 80 in the rear).
The hose gets warm, but not uncomfortably so..
brentwood home
Takes up very little space, and the battery is interchangeable with my ryobi drill and hand vac.
Please can you answer me ?
Nickel020 is offline   Reply With Quote
Old 10-25-2018, 12:22 AM   #24
You didn't ask me a question.. You asked user Mike a question.
Old 10-25-2018, 12:02 PM   #25
Time does zip by. I'm still using that cheap inflator (post #9) 5 years later. It has been handy for inflating bike tires and the van air bags. I do carry a better compressor for inflating tires though. It is easier and quicker to use the small inflator for the bikes.
I'd add a tire plug tool kit as item worth bringing along. It's a good temporary fix. I've had to use my kit once. Make sure that the tool is strong as it takes a fair bit of effort to get the plug inserted. A cheap tool would probably end up bending.
For levels, Booster idea here - http://www.classbforum.com/forums/f8...tall-3264.html works great.
