Old 10-14-2019, 11:09 PM   #1
Default '97 Rialta RC, very low to the ground
Hi.
My Rialta has 215 tires all the way around, so changing tires won't help.
I can raise the back end up by increasing air in the rear air bags, but the front is still very low. The way it is, there is no way I would ever be able to go over a speed bump.
Are they all this way? I cannot believe they left the factory this way. There is maybe 3" between the bottom of the exhaust pipe (at the front of the RV) and the ground.
Suggestions?
Thanks!
DDay is offline   Reply With Quote
Old 10-20-2019, 09:47 PM   #2
mloganusda's Avatar
No, your Rialta should be about 6"-7" off the ground. You may have broken springs or bad shocks on the front. Remove one front tire and inspect for these conditions.
MLogan
Formerly 04 Rialta
Smyrna, TN
Old 10-20-2019, 10:17 PM   #3
Thank you! Monday,it's due to go to the only shop in town that services VW's. I'll ask him to check this.
Old 10-24-2019, 04:22 PM   #4
llemberg's Avatar
You may have a suspension problem if your Rialta is only three inches off the ground, but be sure your mechanic is aware that the front elevation can be changed by adjusting the front torsion bars. There is some good information about it here: https://www.gowesty.com/files/EV-LIF...evel%20Kit.pdf . You can ignore everything that GoWesty says about the rear suspension and their lift kit, since your Rialta is only a Eurovan in the front. The rear was built by Winnebago.
Lars
2002 EVC, GoWesty restored in 2014
llemberg is offline   Reply With Quote
Old 10-25-2019, 08:41 AM   #5
Originally Posted by DDay View Post
Hi.
Thanks!
This could be due to an incorrect installation of the exhaust pipe.
mikeebb is offline   Reply With Quote
