Old 01-12-2019, 03:29 PM   #11
Phoebe3's Avatar
We had to file a claim a while back (different issue). State Farm told us at the time that there was a dollar threshold for payout, under which there would be no increase in premiums. The amount to fix the car was about $200 over that threshold, which would have increased the premiums by about $100 per year so we worked out a deal with the repair facility to split the bill into two parts and we paid the overage out of pocket. You might want to check with your company.
2018 Coachmen Crossfit/Beyond
Old 03-12-2019, 08:08 PM   #12
So I ordered a window from dkhardware.com (Item #: FW904RS) and it turned out to be the wrong size but I was able to replace the lower portion which was all I needed as that part was the same on each. The one I bought was about 5 inches short in height. (I know I should have measured but having gotten the reference from another post on this forum and seeing as how this was the only model available I assumed it would fit.) So if you need to replace the rear side window on your 2004 Roadtrek... Good luck!
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
