Old 11-27-2018, 03:43 PM   #1
Default Roadtek Window
The rear quarter widow pane fell out. 2001 Roadtrek 200 Versatile. Anyone know who can supply a replacement? thanks
Shelly is offline   Reply With Quote
Old 11-27-2018, 08:10 PM   #2
michaelingp's Avatar
This thread might be about the same problem.
Old 12-06-2018, 04:57 PM   #3
I made one out of plexiglass and installed it with stainless steel hinge.
joeski is offline   Reply With Quote
Old 12-06-2018, 07:22 PM   #4
Mine fell out also and this is what I bought and replaced myself
Hector
hecbom is offline   Reply With Quote
Old 01-09-2019, 09:27 PM   #5
may i ask where you got the plexiglass? (i need to do the same thing)
Old 01-09-2019, 11:22 PM   #6
I recently read about Skilflex Sealant, mentioned on FB. I looked at it on Amazon, and one Reviewer talks about it holding a window in....made me immediately think of that crank out window. Ron
Ron J. Moore
'15 RT210P
Old 01-10-2019, 09:52 PM   #7
I just googled a replacement glass store and had them order a sheet of plexiglass for me. I used the remaining one that wasn't broken as a pattern and they cut it out for me. I was in Daytona Beach on vacation at the time and installed it in the home Depot parking lot.
Old 01-11-2019, 12:16 PM   #8
I want to try doing what you did. I wonder how did you attach the plexiglass to the brackets? Did you use glue?
Old 01-12-2019, 02:48 AM   #9
No I used stainless steel nuts and bolts and hinges and screwed them together.
Old 01-12-2019, 12:54 PM   #10
Thanks! I had thought using hardware for attaching would be the way to go.
On a related note, friends have asked why not just file an insurance claim? Some say it wouldn't affect my rates due it being glass replacement. Anyone wanna chime in on this?
Old 01-12-2019, 03:29 PM   #11
Phoebe3's Avatar
We had to file a claim a while back (different issue). State Farm told us at the time that there was a dollar threshold for payout, under which there would be no increase in premiums. The amount to fix the car was about $200 over that threshold, which would have increased the premiums by about $100 per year so we worked out a deal with the repair facility to split the bill into two parts and we paid the overage out of pocket. You might want to check with your company.
2018 Coachmen Crossfit/Beyond
Old 03-12-2019, 08:08 PM   #12
So I ordered a window from dkhardware.com (Item #: FW904RS) and it turned out to be the wrong size but I was able to replace the lower portion which was all I needed as that part was the same on each. The one I bought was about 5 inches short in height. (I know I should have measured but having gotten the reference from another post on this forum and seeing as how this was the only model available I assumed it would fit.) So if you need to replace the rear side window on your 2004 Roadtrek... Good luck!
