Old 08-15-2019, 05:29 PM   #1
Default Stove/Cook-top Replacement
I'm looking to replace the stovetop in my 2005 Roadtrek 190 V. One burner is down and can't be repaired. The stove is no longer in production. I imagine that there are a number of other replacements available, but I thought I'd ask if there is any experience/guidance with this before I delve into the research.
alaskasail is offline   Reply With Quote
Old 08-15-2019, 05:46 PM   #2
I don't know which stove you have but these folks carry a broad portfolio of RV staff.
https://pantherrvproducts.com/cooking/cooktops/
Old 10-27-2019, 11:42 PM   #3
Lou
Something to check out first for your unit. We decided to just live with one burner working in our 2008 Pleasureway Excel after we found out the both a repair or a replacement would entail removing all of the nearby cabinets. Since we seldom use more than one burner, it was too expensive to be worth the trouble and money.
Lou is offline   Reply With Quote
Old 12-06-2020, 12:59 AM   #4
What did you end up doing? We have a 2 burner Dometic propane cooktop which apparently is no longer made. We are trying to find a replacement to drop into the same home. I believe it is a Dometic HBG2335. One burner works but the other won't stay lit.
Boondocker is offline   Reply With Quote
Old 12-06-2020, 01:01 AM   #5
I like Panther Products but they not longer carry the stovetop I have in my RT 2014 SS Agile. It is a Dometic HBG2335. We checked on eBay or Amazon. Any thoughts on where to find something the same dimensions? Cutting a new hole is way beyond my pay grade.
Old 12-06-2020, 01:14 AM   #6
These stoves should be repairable, I am certain they share common parts.
Old 12-06-2020, 01:46 PM   #7
I put in on the back burner We've been living with one burner, but i'm still looking at several different replacements.
Old 12-06-2020, 06:45 PM   #8
Great pun! Neither of ours are working now so we have to keep it on the front burner. I'm calling Dometic and maybe Panther Parts tomorrow. I can report back what I learn.
Old 12-07-2020, 12:36 AM   #9
https://highskyrvparts.com/rv-parts/...-parts/dometic
Cooktop & Range Replacement Parts: nwrvsupply.com
and I wonder - 2BR-1066050. www.caravansplus.com.au/spare-parts-diagram-cramer-2-burner-hob-p-15284.html
cooktop, stove, stovetop
