09-23-2019, 02:24 PM
#21
Originally Posted by Davydd
I guess this is a technique to keep the weight down at the expense of inconvenience. No other Class B I am aware of needs to do this.
I think they are selling this as having the benefit of not having any external tanks.
I'm more interested in the all composite and aluminum construction. That's vastly superior to wood in my book.
09-23-2019, 04:01 PM
#22
Originally Posted by booster
I also wonder about the bladder tank being a good idea, but definitely clever.
Those of of us on private wells have dealt with bladder tanks for decades, and for the most part they are quite reliable, but do have a finite life that is shorter than the tank itself. 20 years is certainly not unheard of.
What I think would be the largest worry in an RV is that while driving there would be a constant sloshing of the contents of both sides of the bladder, so the bladder would constantly be getting flexed back and forth. It could also wind up with all the force on one side of it when one tank side is full and the other empty. 20 gallons of water with inertia from a 60 mph quick stop would be substantial force.
I wonder if there is any decent history on the bladders being used in this way to try to get a feel for durability, perhaps in some other applications.
sounds ingenious to me- i read at their site that it's a bottom top system. as the lower part empties-the gray part-top-fills up. the top might slosh but the lower fresh would always be compressed
09-23-2019, 08:58 PM
#23
I came across them as well when looking for a van.
There is this video
Sent them an email about pricing for the PSL option and their reply was "pricing would start at approximately $85,000 up to $134,000"
09-23-2019, 10:24 PM
#24
There is this video
I watched this video. It answers most questions. I never knew that boats used bladder water tanks. These tanks are from a boating manufacture supplier.
11-18-2019, 03:21 AM
#25
I'm taking a closer look at the Embassy RV line. They will do semi-custom work on Promasters, Transits and Sprinters. They are the only B-Van builder that makes the layout I'm looking for. Toilet and shower in the back end, small galley. Bench seats facing inward up front that make into twin beds.
Recent article about their product in Motorhome magazine.
https://www.motorhome.com/top-storie...v-prl-class-b/
They are displaying again at the Tampa RV Super Show in January.
It looks like an interesting B-van as it has many of the things we have often discussed. Light weight Aluminum framing of all interior cabinets, enclosed with marine HDPE. All electric using a Lithionics Lithium-ion Batteries and Xantrex 3000W Inverter/Charger. Second alternator optional. Espar Hydronic heat and hot water systems. ProAir 12V DC air conditioner. Cassette toilet with macerator pump out option.
Need to see it in person to judge the quality of their builds.
11-18-2019, 03:53 AM
#26
This is the first commercial RV shop to my knowledge using a cassette, CNC-ed HDPE and aluminum framing combo which I selected for my conversion 6 years ago. Black HDPE wouldn’t be my favored but it is easy to change. Check if they are using Seaboard from Vycom or Starboard from Kings Plastic HDPE, looks like Starboard. I used Seaboard, it is less prone to scratches and it is not as shiny as Starboard.
11-18-2019, 03:29 PM
#27
Thanks George - I’ve looked at Seaboard, but not Starboard. I’ll add that to my long list of questions that I plan to ask them in Tampa next year.
I’ve already asked them some questions by email. They do use other colors of HDPE. Their web site has some photos of other colors. I agree that black would not be my choice.
https://www.embassyrv.com/embassy-cl...rv-photos.html
They build the B-vans to order only. A $3,000 deposit gets you a production slot for standard base van. If you want to custom order the base van the deposit is $12,000. Once you make a deposit they send a package to make color and option choices for your build. But they appear to only build one basic floor plan. That is ok with me as this is the plan I want.
11-18-2019, 05:32 PM
#28
Another question opportunity. Most likely they did cassette venting correctly, but you could ask if it is venting on the roof which would be preferable. Cassette’s vent is on the bottom of its housing and opens up to cassette after its insertion. See my pictures.
Looking at the Embassy HDPE pictures it seems it is Starboard due to its shiny finish. See the picture of the top of my electrical cabinet, surface finish is not shiny.
11-20-2019, 06:14 PM
#29
Another question opportunity. Most likely they did cassette venting correctly, but you could ask if it is venting on the roof which would be preferable. Cassette’s vent is on the bottom of its housing and opens up to cassette after its insertion. See my pictures. . .
Thanks George. I've researched cassette toilets and venting is definitely a potential issue.
11-20-2019, 06:38 PM
#30
Boxster,
I've designed my next B for the eventuality of possibly a cassette toilet since I am behind the rear axle of a 2500 short Sprinter; however, I don't want the cassette to have to be accessed on the outside of the van steel skin with a door hatch. I could access it from inside by opening the back doors. Sue Valentine's B is close to your desires with the sofa up front to make into bed, but she has a compost toilet in the back which I could redesign to a cassette accessible by opening the rear door. I think the van George Mauro (Humble Road) just built is similar to your desires.
Right now, I plan to raise the bathroom floor enough to run the waste pipe above the van floor over the top of the back axle to get a normal flush toilet in. My 5'-8" would allow me to do that. Not recommending it for a taller person. I could do it with a macerator toilet too without raising the floor, but I am leery of that.
11-20-2019, 09:39 PM
#31
Boxster,
Davydd - thanks for the info. I'm familiar with your next B - looking forward to seeing more details when the build starts. Yes - Sue V's B is close to what I'm looking for with a smaller galley area. I was focused on doing an ARV build until I found this Embassy layout. Not making any commitments on which way I'll go until late next year, likely on a 2021 Sprinter. I'd be OK with the new Transit with 4-clyinder diesel and 10-speed transmission. But DW insists on a Sprinter as the cab area is easier to get around in than a Transit or Promaster.
02-11-2020, 10:10 PM
#32
Met Terry Minix at the Florida RV Supershow...
for anyone interested:
For what it's worth, I'm impressed a VP of a company would come out to the show after the death of their President and stay just to talk to anyone interested, even though the state of Florida would not allow them to bring their RV's (company had an automatic ownership transfer, which apparently messed up the state paperwork).
If the roads of life were a straight path, we'd all fall asleep at the wheel!
-- Roads of Life
02-12-2020, 01:03 AM
#33
. . . For what it's worth, I'm impressed a VP of a company would come out to the show after the death of their President and stay just to talk to anyone interested, even though the state of Florida would not allow them to bring their RV's (company had an automatic ownership transfer, which apparently messed up the state paperwork).
Thanks for sharing this - just a bit more info on Embassy RV. They seem to be a mostly stealth RV company.
I was really disappointed that they couldn't make the Tampa show. I adjusted my Florida travel plan to be at the show and see an Embassy RV van in person. I could not get there in time for Terry Minix's meet up. Oh well - just have to visit them in Elkhart this summer.
02-12-2020, 01:28 AM
#34
I was disappointed as well, but impressed with him being there, so we're thinking of going up to Elkhart either in March or sometime this summer as well.
From what I can gather, Embassy has a lot of ideas about the RV, but haven't really started their advertising campaign. They seem to be used to corporate work and designing for companies (at least I think so!) and are just getting their feet wet with a broader clientele.
We shall see where it goes, but I do hope it's a positive journey!
-- Roads of Life
02-12-2020, 07:43 PM
#35
Originally Posted by Smith101
I always thought awnings on a class b were silly since you have no storage to carry outdoor pads and furniture. But Embassy offers Flamma options.
I always keep two folding camping chairs and a folding all-metal table in the "trunk" of my ERA 170M.
It seems the sun is always too low or at the wrong angle for the awning to really help... but it's also very helpful in a heavy rain... extend it a foot or so and it helps keep the big cargo door opening from getting drenched.
-RV's, Firearms, and Bourbon
-Weekend warrior
02-25-2020, 03:39 PM
#36
I did a little more research on HDPE options and found that Vycom had a new HDPE product called TimberLine.
https://www.vycomplastics.com/produc...in-hdpe-sheet/
It is an HDPE sheet product that now offers an interesting wood look for RV and Marine applications.
02-25-2020, 04:36 PM
#37
Thank you for sharing. This woodgrain finish can break the monotony of a single color. Lack of ¼” is likely a matter of time, in my conversion I used about 60% ¼”, 30% ½” and 10%” ¾” - just for galley's countertop. Dark colors and HDPE are not the best combination for outdoor if a Sun heated HDPE sheet is not allowed to float. Coefficient of HDPE thermal expansion is very high.
05-07-2020, 10:36 PM
#38
Can't remember if I already posted this, so if I had... my bad!
We took a trip to Elkhart Indiana to see the Embassy RV facility, and it was amazing! Terry Minix, the owner, actually took us on a personal tour of the entire place. I have some videos on YouTube if anyone is interested...
-- Roads of Life
11-13-2020, 04:27 PM
#40
Embassy Traveler Duo
For anyone interested, Embassy has just posted their long awaited Embassy Traveler Duo
https://www.embassyrv.com/models-traveler-duo-features
Has two sleeping areas (hence the name Duo) and looks like a larger sink and faucet.
-- Roads of Life
