Old 06-18-2019, 08:33 PM   #1
fjc
Default Jump start chassis battery with house battery
Hi On my 2018 CS Adventurous, there is a house AGM battery in the driver side engine bay. Can I connect a jumper cable to start a dead chassis battery?
The house battery (with 400W Lithium) has over 13 volt.
fjc is offline   Reply With Quote
Old 06-18-2019, 09:28 PM   #2
On my 2013 I did that when the auxiliary battery negative was connected via (I think it was brow)n cable to the ground stud next to the battery. Since, my auxiliary one is wired differently. So, you need to connect auxiliary plus to engine battery plus connection stud under the hood, assuming 2018 has this stud.
Old 06-30-2019, 05:18 PM   #3
I've successfully jumped the chassis battery off my engine bay AGM house battery before, HOWEVER, I would caution you about trying a direct jumper cable between a lithium and AGM battery (Mercedes chassis battery)
The lithium battery is capable of far faster charge and discharge rates than AGM. You DID mention that the engine bay battery is an AGM. I assume that's there to reboot your ecotrek lithiums? It would probably be safe, but the wiring in Roadtreks can get complex. (I have a 2015 CS Adventurous with 8 AGM batteries in a hybrid 12/24 volt system)
A MUCH BETTER solution would be the TRIK-L-START charger from LSLProducts.net .
I now have one on my unit and it keeps the chassis battery fully topped up all the time, which will greatly extend its life. I just wired it directly from the engine bay house battery to the jumper terminals in the engine compartment. Easy peasy.
ProseMan is offline   Reply With Quote
Old 06-30-2019, 05:18 PM   #4
engnrsrule's Avatar
There are a number of factors. Coach batteries are typically deep cycle, designed for longer draws at lower amperage, while vehicle starting batteries are designed for short bursts at higher amperage. Using the wrong batter y risks damage. If the proximity allows the coach battery to reach the starting battery with one set of jumpers it may be ok, but I would recommend totally disconnecting the coach battery. The two systems are isolated from each other and jumping them together with the coach battery connected could damage battery monitor, charging or isolation devices.
Old 06-30-2019, 06:38 PM   #5
My intuition suggests exactly the opposite. I don't see how putting. a starter battery and a deep-cycle battery (or even a lithium) in parallel for a short period is going to risk damage in any way. This is especially true if you are using the house battery to "boost" a weak starter battery, as opposed to replacing a totally dead battery. Volts are volts and amps are amps. I don't see how it matters what chemistry is producing them, and you aren't going to be doing this long enough for the discharge profile to matter.
Most importantly, however, please note that you must never run the engine with no battery connected, even briefly. You will almost certainly destroy your alternator. So, if you were to completely disconnect your starting battery and then use the house battery to start the engine, how are you going to get the starting battery back in the system (so it will charge) without ever connecting them together??
P.S. -- I agree with ProseMan. Trik-L-Start is the best.
Old 06-30-2019, 06:42 PM   #6
DUTCH in Atlanta's Avatar
The Mercedes Sprinter has a button on the dash to give the chassis battery a boost from the coach battery, if needed.
Old 06-30-2019, 06:48 PM   #7
Yes. When I installed my second engine alternator, I recycled my isolation relay to install such a switch.
It is not a Mercedes thing, though. Your upfitter installed it. Usually, the wires they use aren't big enough to actually let you start the car that way if the chassis battery is completely dead, but for a "boost" or as a way to charge the chassis battery it is fine and very handy.
Old 06-30-2019, 07:58 PM   #8
engnrsrule's Avatar
Damage is not likely, but if the chassis battery is very flat and the coach battery is not sufficient it could just get sucked down too. It is also a good idea to carry a booster pack. They also add benefit of an air compressor, portable lighting, 110v inverter and USB charging ports.
Old 06-30-2019, 08:23 PM   #9
I agree, my 1999 Xplorer/Dodge has a button on the dash that actuates a starter type solenoid switch. it also has heavy enough cables that when the chassis battery is totally dead, it starts with the same gusto as normal (wasn't necessarily wanting to, but had an occasion to test this function a couple of years ago in the 'middle of nowhere', Yukon Territory).
I have not worried about depleting the chassis batteries (two deep cycle flooded) because if the chassis batteries were low, I could fire up the genny for a while, then jump start the engine.
Anyway, it is a very handy feature - much easier than getting out the jumper cables - if I didn't already have one, this is an upgrade I would definitely do.
Dave
D&J Phillips is offline   Reply With Quote
Old 07-01-2019, 02:20 AM   #10
Trik-L-Start charges the chassis battery at 5 amps max. Xantrex Echostart charges the chassis battery at 15 amps max.
Trik-L-Start is the easier install. Echo start is not environmentally sealed so I put it aft of the firewall. I have both on different vehicles and they both work very well.
When I had a dead chassis battery with the Echo Start I let it charge the chassis battery at 15 amps for 20 minutes and was able to start the engine. Not as good as shorting the two batteries together but it worked.
Old 07-01-2019, 02:32 AM   #11
The Trik-L-Start folks make a 15 amp version as well, called Amp-L-Start:
AMP-L-START Starting Battery Charger/Maintainer - Overview Page
Any of these devices combined with even a modest solar install will keep your van ready to go.
Old 07-01-2019, 02:45 AM   #12
We don't particularly worry about it, as we have never had close to an issue. We use a marine starting battery of about 85ah for a starter and have a manual separator so we can just push the button and connect 440ah of AGM coach batteries. If we ever though the starting battery was going low, we would just connect the separator and let the AGMs and solar charge the starter battery for a while, but I doubt we ever will need to do that. Our dual alternators are parallel, and not PCM controlled, so much easier to setup than a standalone.
Old 07-01-2019, 02:56 AM   #13
I think the biggest issue is long periods of storage without shore power. Modern vehicles (or at least the Sprinter) have so many parasitic draws that you just can't park one for more than a month or two without the starter battery's SOC getting down to unhealthy levels. Not everybody does this, but if you do the Trik-L-Start + solar avoid the need to disconnect the battery for storage.
Old 07-01-2019, 02:56 AM   #14
I'm always amazed at how much more you guys know than I do. Appreciate the info.
Old 07-01-2019, 05:09 AM   #15
Knit's Avatar
This is what the 2014 Roadtrek manual says about jump starting:
Knit is offline   Reply With Quote
Old 07-01-2019, 10:04 AM   #16
I'd do it that way if ever needed. Use the jump points under the hood as Knit noted. The lead acid starter battery won't accept as much current at say 13.4V vs 14.4V from an idling engine but it should be still be plenty to boost it enough to start your engine. I'd likely just connect the two for a short while then remove the cable prior to starting the Sprinter. If that wasn't enough then my 2nd choice would be to leave it connected and try starting the Sprinter.
It would be interesting to see what the current flow is between a lithium battery and a lead acid starter battery with a TRIK-L-START installed. With the lithium at 13.4V or so if recently fully charged I wouldn't be too surprised to see 1A or so flow from the lithium until it's nearly depleted. I'm assuming that RT took the low cost route and just paralleled that lead acid battery in with the lithium batteries. With solar, as Avanti mentioned, it might not be a problem provided that the setup gains more or at least equal to what it loses.
Thread Tools
Display Modes
