Old 08-28-2019, 08:07 PM   #1
Default Roadtrek window repair
I am proceeding with repairing a Roadtrek window. I have it off, i have the lower glass separated from the top portion. I am trying to separate the hinge part from the glass. most of it is loose, but a small portion is still held fast to the hinge lower part.
How would someone (like me) break the adhesion, without damaging the glass or the lower portion of the hinge?
Any help will be appreciated.
Boyde is offline   Reply With Quote
Old 08-28-2019, 09:53 PM   #2
Try a little heat?
Old 08-28-2019, 10:02 PM   #3
Heat like with hair dryer, or heat from a propane torch?
Thanks, appreciate the help.
Old 08-28-2019, 11:36 PM   #4
Heat with a hair dryer or, cautiously, with a heat gun.
Old 08-28-2019, 11:48 PM   #5
Thanks, I tried using the hair dryer and with two full blades in a utility knife, I was able to separate the glass and the hinge. Now to clean off the residue.
Any tips?
On another piece of this repair, any thoughts on how much pressure to clamp the two together? I will be using 3M Windo Weld.
Thanks again.
Old 08-28-2019, 11:57 PM   #6
Residue should come off with a razor blade.
Not too much pressure, you want the adhesive to remain between glass and hinge.
Old 08-29-2019, 12:09 AM   #7
I have been using a utility knife and it does chip off, patience is the key word. Acetone does not seem to have an affect.
Not too much clamping pressure is what I was thinking, do not want to squeeze out all the glue. Thanks for giving me the confidence that i was thinking in the right direction.
Old 09-05-2019, 04:10 PM   #8
llemberg's Avatar
I have found Lacquer Thinner to be effective at cleaning many different types of adhesive residue.
Lars
2002 EVC, GoWesty restored in 2014
llemberg is offline   Reply With Quote
Old 09-05-2019, 04:48 PM   #9
Most of the better adhesives will give a recommended gap as well as minimum and maximum gaps with strengths at each of them. Especially on hard to bond smooth surfaces gaps can be critical and need to be followed.
Old 09-05-2019, 07:45 PM   #10
We use a product called "Goof Off" for removing adhesive. Works great when we removed decals and letters from our XPlorer
jimlongusa is offline   Reply With Quote
Old 09-05-2019, 10:34 PM   #11
I second the "Goof Off" product especially if given time to soak, like many hours...
