Old 01-21-2019, 09:23 PM   #81
They certainly don't look like they have been moved recently, from the pix.
In an ideal world, yes, whatever cam was the pinch point limiting factor of alignment would be at the end of the slot. But the world of wheel alignment is a bit of alternate universe where they don't seem to believe that. The limiting one on our looks similar in the slot the closest to the end of your, and it has been aligned 3 times where they said the used all the adjustment there was, so that is an ongoing issue, I think. For most, if the machine shows green, they are good to go and say that is all you paid for. Getting aligned to spec can be quite difficult sometimes.
Old 01-22-2019, 02:11 PM   #82
Booster,
This has probably has been discussed at length but can you refresh my memory.
Looking at coil spring fitments for my 2003 chevy express 3500 based RT on moog website, I end up with 81006, who is shorter and less spring rate that 81006.
Was that the whole idea of the lift project.
Sorry for asking if it's a silly question, I'm just tired.
lejeep is offline   Reply With Quote
Old 01-24-2019, 08:33 PM   #83
Booster,
Delete that last post.
I was erring with the specs.
My installer should recieve original 81004 from Moog next week.
We will get to the bottom of this...
Old 02-07-2019, 01:09 AM   #84
Mat Mobile's Avatar
Bonjour lejeep!
Per our brief discussion by PM, I also had work done at the same installer (here's the suspension part of my thread).
Since my van is another suspension type, I used a different spring and had other suspension mods done, it's hard for me to make technical comparisons between our vans.
One thing I can say is that my alignement was not completed properly. They had a really hard time "completing" the initial alignement (I'm guessing I was their guinea pig before your installation). They did manage to get things "within spec." and with a little getting used to, I manage to complete my trip to "Les îles de la Madeleine".
Upon my return, I brought it back for a bolt check and had to insist on them test driving it as something felt wrong. Especially since I had driven a Chevy Express U-Haul the week before that surprisingly, drove better.
They agreed something was wrong but wanted me to come back with the necessary specs. to complete the alignement. I realized at this point they probably went around the block once after completing the $10k job. I do not wish to bring the van back to this installer.
I think we (lejeep and myself) should tag-team to find a better garage for the alignement once the correct springs are installed.
Just to clarify, are lejeep and myself the only people having trouble getting a final alignement? That is my current understanding.
I'll update my thread ASAP with this story. To be honest, I was so disappointed with this situation that I put this event away in my mind. Plus I was also the middle of a work transition and about to put the van was in storage so...
Old 02-07-2019, 01:25 AM   #85
The proliferation of the fancier alignment machines has actually made it harder to get a decent alignment. They can't just dial in settings as they check the results, as they have to totally rescan the entire vehicle after every little change. It takes forever and the younger techs that are on most of them now don't know how much to move a setting to the right amount of change. Especially on rear drive vans.
The last 3 alignments on our Chevy I was told they could not get more caster on the right front because it was out of travel. I could look at the cam in question and see it still had travel left, they just didn't want to and the machine was "in the green". Just had similar with my old Buick Roadmaster. Changes between original and final scan were physically impossible from the spacer changes they made, so they messed up at least one of the readings and never got to the specs I wanted.
I have started playing with parts to do DIY alignment at home, which is looking promising so far, but I have to wait for warm weather so I can use the much more level section of the driveway instead of the shop floor which is sloped to drains. I can't possibly do a worse job than most shops, I think.
Old 02-07-2019, 04:28 PM   #86
Agreed. I have also been sent back on our car with the comment they could not adjust the front camber due to being out of possible travel.. And they didnt want to adjust the rear toe-in because they couldnt adjust that camber.
Long story short: I did it myself with a tape-measure, and the angle-meter in my I-phone. With a little bit of time and patience, and some technical inclination, you can nowadays do a very good if not better job at home than in the alignment shop.. Sad actually.
Since that episode, I have ever since done my own alignments on the RV also... once you get a feel for it, you can dial it in to your likings.
I suppose it is easier for the average consumer and because they pull the alignement specifications form the database for standard cars and vans, it does a decent job and takes the guess work out for most people.. but special RV adjustments and custom alignments and OCD-type adjustments (like i want ) are difficult to achieve with most alignment places...
henknoordermeer is offline   Reply With Quote
Old 02-07-2019, 04:39 PM   #87
Absolutely true.
The sad part is that a shop with an old school rack, with turntables that can give the turn angle accurately, and bubble gauges can do the recheck of a wheel in 30 seconds. If they know what they are doing for adjusting, and a Chevy with cams (although the front cams are hard to retighten), take only a couple of minutes per move. They can be done, and on your or my OCD specs, in half and hour tops. The last guy spent 1.5 hours with machine and made it worse than it was.
Did you make DIY turn plates, EG a couple of vinyl floor tiles with grease in between them? 20* turn lines on the floor? Formula to calc off angle measures for caster? Did you have a spot that was perfectly level or did you have to shim the tires to get the vehicle level? Very interesting stuff, I think.
Old 02-07-2019, 06:49 PM   #88
Booster, henknoordermeer,
If you guys can put together a detailed description of doing an alignment that would be great. I did the tapemeasure toe check a few years ago and got that pretty good, but don't know how to do caster & camber. There is only one local shop with an alignment rack big enough, and they are expensive and they are aligning to factory specs. I think booster has talked about alternate specs that should be better for the Chevy B.
Old 02-10-2019, 10:21 PM   #89
Default Coil springs replaced
Ok everyone I hope this won't be too long,
To follow up on my suspension project, I finally got an appointment with the installer to replace the whatever springs he had installed previously. When I called to make the appointment, I asked and was confirmed that this time they measured 17 3/4" instead of the 18 1/4" I had noticed by chance during the first install. This time, when they saw I had a camera, I was strongly reminded that I was not allowed in the shop for insurance bla bla bla... I still managed to take a few pics anyway.
So after 3 hours instead of the 5ish needed the first time, the new coils are installed and he tells me (again) that he cannot align the vehicule because steering components are loose bla bla bla... I have to say that in the meantime, I had another garage inspect the whole steering system and results were negative, nothing needs replacing.
No problem since I have an appointment with another alignement outfit on that same day I tell them.
This next appointment (the other outfit) goes very smoothly. I talked to the mechanic who did the job and told him about possible steering parts needed to be replaced. I am answered that the play is not excessive to the point of having to replace anything, otherwise, his machine would not have done the alignement. 50 minutes tops from the time I leave them my keys to when I swipe (again) my credit card and we are off.
The van has good suspension now even with original shocks. Hit a hole or bump and it's a one/two thing back to normal, very comfortable and even ride. Also very predictable. On my way back home we hit wind gusts between 50 and 80 km/hr passing trucks and the likes. One hand on the steering is all it took, very pleasant indeed. Also, the clearance has increased to a respectable 36" from ground to wheelwell, the main reason for this project.
Now the funny stuff;
Back home after the dust had setteled, I look at my pics and notice something odd. First, one pic shows me the springs are 17 1/2" instead of 17 3/4". I repeat, the installer over the phone confirmed they were 17 3/4", where did he get his measurements ? Also another pic shows me that one end is tangential while the other is squared. If I go on this website;www.fme-cat.com
the Moog 81004 have both ends tangential and are 17 3/4" in length. I swear that I saw on the box MOOG 81004 (like the first time he had a wrong in the box).
Questions:
1- Is it possible there is such a tolerance in spring manufacturing to allow 1/4" difference and have ends sometimes squared and other times tangential ?
2- Has any one that has gone the Moog 81004 way measured / inspected their springs before install to confirm question no. 1 ?
More funny stuff;
As I said, the van drives well but upon looking at the alignement results (see pic), I noticed that:
1- the mechanic used alignement specs for a chevy express/van 4X2 :1996 to 2002. My van is a 2003.
2- upon looking more closely to the alignement printout, it looks like the alignement is pretty well out of wack to me. For comparison purpose, I used his alignement results also with the 2003-2004 chevy express/van 4X2 2500 heavy vehicule /3500
More questions:
1-Could the van drive so well and have such a bad alignement ? It is not pulling or anything.
2- Is it possible that one bad adjustment was compensated by another bad adjustment so the van would still drive ok ?
3- Maybe I did not get the last printout but the time stamp was pretty accurate to me.
Comments anyone as I am about to return to the alignement guy to get this straightened out and I want to be more knowledgeable before going there. Also contemplating with the idea of going to the original installer and have him replace (again) the springs for the real 81004, but hopefully not.
I thank everyone who can give info on their spring replacement projects.
Old 02-10-2019, 11:14 PM   #90
Questions:
More funny stuff;
More questions:
It is very hard to measure spring length in a hurry, especially if they have some bow to them or one of the ends is closed up tighter than the other. The big thing is what it came out for height, and you are still a bit high, but it likely will go down some in a while, and when you load the van fully. If it is even side to side, or even a bit high on the right, which is kind of common, I wouldn't worry to much about it. You could settle in at about 35.5" like most have, but 36" should not be an issue if it stayed there.
I am having a bit of struggle figuring out you charts, so I am just going to assume the second one where it says actual is what you got today?
I think the plus camber is way high. I like .12 to .25 and no higher or you will start to see tire wear on the outside edges, but it will handle nice because it is always on the outside edges. No negative on either side and no cross camber is good.
The van probably goes pretty straight on a right lane crown as the cross caster is on the higher end and caster itself is high enough. It would likely lead left on a left crown, which is typical. You were in a lot of wind, so pull and tracking are very hard to check well under those conditions. So good on caster.
Toe is ridiculous to be so far off because it is easy to set compared to the other adjustments. If I did my math right that is over 3/8" toe out and will take off the inside of the tires very quickly. It should have made the van get a bit funny in steering response, but the correct caster and the too high camber may helped hide it. Toe out should make the steering have a soft middle and then quick dart once turned a bit. You turn the wheel a little and not much happens so you turn it a bit more and too much happens. With that much toe out you would get a larger soft spot before it darted. Of course you are used to driving the van as it was before, so it may not be as noticeable to you as it would be for someone who had a much better handling unit before hand.
All that said, especially for toe, worn parts could be contributing, although worn parts would usually make a rear drive toe out more driving than when sitting, so backwards. If he had set more toe in, I would say he was compensating for worn tie rod ends.
I would do a quick check at home of the tightness of the toe. Just put a chalk mark or a hunk of tape with a line on it anywhere on the tread of the front of the tires, about the same height up from the ground on both sides. Push the front tires in as far as they will go from each side without straining too hard. Measure the distance between you lines with a tape measure. Now pull the tires out as far as you can and measure again. Tight parts will not really move much, so if you see anything much more than 1/16-1/8 inch, you have worm parts. No change would be good.
It is also possible that the number he gave you are wrong, as I am certain I got one set of bad readings on my last alignment. You should be able to see the front wheels tilting out at the amount of camber listed, so that could be an indicator. The need to rescan every change they make, but often at the end of their allotted time the skip the rescan and just print what is on the screen.
I fear you are running into the same thing many of us have been lately with alignments, that being that with the new machines and poor help it is nearly impossible to get a decent alignment. The last 5 I have gotten have all been less than stellar.
If you can find an old school mechanic or even better truck shop, that uses mechanical gauges or the electronic version that just reads like manual gauges on the front only, I think you will be much more likely to get decent results on the van.
Good luck, and keep us posted how it turns out.
Old 02-11-2019, 11:18 AM   #91
I'll just add that lejeep's control arm etc. does not look like what in the '97 to '02 series van. There's some photos of my '97 in this topic: http://www.classbforum.com/forums/f8...ings-4136.html
1996 was the changeover year so I always refer to the series as 1997 - 2002. Some 1996 vans would be like the 1997 vans.
NEW FOR 1997:
* Vehicle completely re-engineered with body-on-frame construction (became available as a 1996 model in the latter part of '96 model year)
Something similar may have occurred in the latter part of 2002.
lejeep's van is most likely the newer 2003 style van and is a 2003 model year even if manufactured in late 2002.
Old 02-11-2019, 03:26 PM   #92
Thanks for the explanation on how the steering should feel with these numbers.
I did have the time to look at the new springs and take pics. It was after that I was told I was not welcome in the shop. There is no bow to the new springs and I measured 17 1/2", that I am sure of. So my question still stands about manufacturing length tolerances of +/- 1/4". Has the industry become so loose on quality control in the name of cost cutting ? But as you say, it's the end results that count and I am happy with whatever is in there.
Sorry for the confusion about the chart, you are right, actual is the numbers the mechanic gave me but everything was in french and I wanted you guys to comment. Both charts have the same actual numbers. Difference is the top one is written with the mechanics machine printout with specs for 96 to 02 vans. Bottom one I pulled the specs from a past alignement done for 03 to 04 vans to see difference in tolerances. Also aim represents the center of the tolerance specs, meaning a perfect alignement IMO. So if the numbers he gave me are right here are my comments.
About camber; Tolerance sweet spot (aim) for 96-02 is +0.50deg. For 03-04 it is +0,25deg. Something in the geometry logically has changed to lower camber. Maybe stiffer suspension so the 03-04 van does not squat as much as before from load so you can have the same tire contact with the road with less camber. I will do a visual check as proposed. Good thing everything is frozen here it will make it easy to move the wheels around. Any comments?
About caster; I will take the van back for a test drive now that it's calm, but it seems to drive just as before I started the project, meaning real nice. Also the specs for 03-04 vans (aim) ask for +1,0deg more caster than the 96-02. Any comments?
About toe; Again, it drives so nice I have a hard time believing those nombers are my van's. I will do a check for toe tightness for sure. I cannot believe a mechanic who has a class 3 certificate AND an alignement certificate hung in the waiting room would let a vehicule leave with one wheel in and the other one out as per the printout.
One last thing, when I asked if he used the cams to adjust, I was told that if he had to change that setting it would be because something was off and he would cheat the geometry if those were moved.
I will post back once I get more answers. TBC
Old 02-11-2019, 04:46 PM   #93
Thanks for the input. Looking at the bump stop, I see they are different than mine(sorry no pic). My bumpstops are beehive shaped and placed further inboard on the c/arm. I would need to inspect carefully but is seems the arms are also shaped differently.
On another note, I am now almost certain that I was given another set of whatever instead of 81004.
I looked at your pics and noticed both your spring (81006) ends were tangential(open ended) and this website confirms it;
https://www.fme-cat.com/PartSpecific...G%20ATTRIBUTES
That same website specifies mine (81004) should be also tangential on both ends. I clearly see that I have one tangential and one squared end on mine.(see pics)
They are also 17 1/2" free length instead of the 17 3/4" specified on that site. I also count 9,2 coils instead of the 8,7ish I was told on the phone by Federal Mogul.
Did you take free length on yours before install ?
About build, I did have a chat with chevy USA a while ago, (more like a machine spitting out generic answers to your query) and was confirmed that while it was built in late 2002, I had a 2003 chassis. Also looking at your pics again, I can say we have the same passenger style footsteps but different front grille and bumper.
I will keep posting until I run out of interest or money.
Old 02-11-2019, 05:44 PM   #94
I know for sure that I measured the old OEM coil springs. I had two carpenters squares with me for that and used them like a big caliper. I'm fairly certain I also measured the new 81008 coils (1997 van) and they must have been what I expected else I would have noted it in the post. One end was a bit flatter than the other but not like what your latest photos show.
Old 02-11-2019, 06:04 PM   #95
Originally Posted by Mat Mobile View Post
Just to clarify, are lejeep and myself the only people having trouble getting a final alignement? .............
Matt - You probably already know about the camber/caster knock-outs on our series van. I just thought I'd mention it in case you didn't. After I installed the longer and stiffer coils on my van, the alignment place said they had to punch-out the camber/caster knock-outs to allow greater adjustment.
Old 02-11-2019, 06:35 PM   #96
My understanding is that the previous generation van had a larger engine compartment so it could fit the big blocks in, and that leaves less room for suspension. It is very likely the previous generation had shorter A arms and a different geometry in general. The extra camber in the callout could be that the suspension in the older ones goes more negative than the new ones in compression. Staying at the 1/8 to 1/4 degree is where it should be, I think, to prevent excess tire wear.
Each generation of vehicle, especially the rear drives, seem to go higher in caster, probably because everything now has power steering so no need to worry about too high of effort. The vehicles almost all will track better with high caster.
I agree on the toe, and why I mentioned it might be a printout error. Nobody in the business should let it out the door with those readings.
I will requote this again as it is pretty unbelievable.
This has to be the single silliest excuse I have ever heard. This a body on frame 5 ton truck and anyone who has been around any body on frame vehicles knows that the alignments go out over time. It is a way of life and not unusual at all. If this were a unibody car, I might agree with him, as I have not seen many that ever needed an adjustment other than toe. They didn't put the cams on their for good looks, they are meant to be adjusted.
It sounds like he put it on the rack and went to lunch, then came back and said he was done. If the cams haven't been touched there was no change to the caster or camber, and the toe is so bad he is either totally incompetent or didn't touch that either.
Sad to say this is getting to be the norm these days for alignments.
Old 02-11-2019, 08:32 PM   #97
Mat Mobile's Avatar
I was not aware of these. I looked it up and now understand how these could be useful. I will add this information to my mental encyclopedia for future reference for my next visit to the alignement shop!
Old 02-11-2019, 09:53 PM   #98
Thanks Marcopolo,
Now I'm sure that for the second time I do not have the springs I ordered and the installer insists on getting them himself. After the first wrong in the box I suggested I get the new ones, but nooooo. Now he had to get new ones probably in order to get reimbursed the first wrong in the box.
So if I ask again for a replacement, I will have to deal with him again.
Like Booster said, what matters after all is the end result. If I get the lift I want, I will probably let him go.
Old 02-11-2019, 10:39 PM   #99
(Stuff about cam not to be used except for cheating)
I did a toe tightness test as suggested. There was at the most 1/8" play from in to out(more like 1/16" really). The wheels were on the ground but on ice, so easy to move if any play.(see pics)
I have to say that while the wheels were off the ground while replacing the springs, the mechanic showed me the play on the pitman and idler arms. I would guestimate a total of 3/16" at the most from what he showed me. I suppose that when the van is on the ground the linkage tightens as the suspension squats down. This would explain why the last alignement outfit told me there was no excessive play or else the machine would not have being able to align the van properly.
Since it was a nice day with dry roads, I did another road test with no wind this time. Sad to say but the wind fooled me good. The steering wheel is straight but the van pulls to the left. Only slightly at first but as soon as I am out of the ruts and start to embark on the crown it noticeably pulls more to the left. No matter what lane I use it constantly pulls in the same fashion. Sooo, the printout might be right after all.
Would this pulling explain the numbers I posted ?
As for the cam explanation, what can I say. It was probably a friday afternoon answer. I just hope they will have forgotten that explanation when I go back there, or else they will not be able to use the cams if need be.
Also if you look closely at the pics, it looks like there is a lot of camber and uneven from left and right side. I'm no alignement expert but it looks odd to me. Strange since the numbers show even but high camber. Any comments ?
I took another appointment at the alignement outfit this friday. The service man seems to be openminded and did not try to weasel his way out. Can't wait to see what he has to say about his printout since half of his numbers are in the red. I will also strongly suggest he uses the 03-04 specs this time.TBC
Old 02-11-2019, 10:54 PM   #100
If toed in 1/8" you would be OK with that looseness, I think.
The cross caster should make it pull left, the question is just how much. I know that at .3 or .4 higher on the right, our van just about holds straight on a right crown, and you have near double that so it may be contributing. Really hard to tell for sure if also have mismatched and way to much plus camber and toe. I would not get very concerned about most driving issues until you get the numbers reading right.
If they said they shouldn't move the cams, then your alignment changes from lifting over 2" weren't taken care of, and they do change. Do the cams even look like they were touched? How about the tie rod adjuster sleeves?
Checking for looseness with the wheels off the ground won't tell you much except for the ball joints, and even then it is not real accurate.
Thread Tools
Display Modes
