Old 04-12-2017, 03:09 PM   #1
Default Double sealing doors
In my quest of sound proofing the van to the max, I ran into a video from china showing the soundproofing service they provide. In one procedure they installed an extra seal around the doors. Has anyone tried this? Looks to be a "D" type seal.
Old 04-12-2017, 04:19 PM   #2
Most of the car manufacturers have adopted the double door seal.
As I recall, this has been the case for the past number of years.
Old 04-12-2017, 05:08 PM   #3
My honda has 2 seals and the 2018 model will be triple sealed. The Promaster has a second seal on the top of the doors only.
Old 04-15-2017, 07:15 PM   #4
Installed rubber seal on slider and passenger door, also in pic drip rail. Should be a little drier now and maybe quieter. it fills the gap perfect and no problem closing the doors.
Need 25' per side to do the 1passenger door and slider
Old 04-17-2017, 05:25 PM   #5
Been raining here and I notice the door jambs are dry and I don't get drips inside when I open the slider. I imagine it will help keep the jamb areas cleaner when driving through dusty areas.
Old 04-21-2017, 04:45 PM   #6
Default Rear door
I'm using a larger seal for the rear door. You cannot completely seal it off but I believe it will help keep dust and water out of the jambs.
Old 04-21-2017, 06:48 PM   #7
This larger seal works perfect on the bottom sill of the slider.
Old 06-05-2017, 07:43 PM   #8
Just camped out in a very dusty area for a few days, No dust in the door jambs and noticeably quieter while driving.
