Old 07-11-2018, 04:22 PM   #21
Great to hear a success story and that you finally found a shop that knew what they were doing, as it appears many don't have a clue what it takes to put in the big springs.
Thanks for sharing all of this and all of your expertise. I'm new to all of this and will be investigating my '08 210P and seeing if it has some of this done already. Thanks again and safe travels!
Jim
jimhands3 is offline   Reply With Quote
Old 07-14-2018, 01:43 PM   #22
I’ll add another thank you. I have a 2008 190P and will be installing Bilsteins in the next couple weeks. Airlift bags might be next on my list. I appreciate everyone sharing what has worked and the pitfalls the look for along the way.
Jim
2014 Roadtrek 210P
Dieps is offline   Reply With Quote
Old 07-26-2018, 12:26 PM   #23
Question for all the diy guys here regarding the Moog 81004 front springs.
Do these need to be compressed when installing?
I enjoy doing my own work but I really dislike compressing coil springs especially the big monsters on our vans. All the rest of the work is fine, just getting the coils in and out is my question. Thanks, Mike.
MikeK5117 is offline   Reply With Quote
Old 07-26-2018, 12:51 PM   #24
I did my springs. I used a floor jack to lower the control arm and remove the spring. Then used the jack to raise the control arm with the new spring installed. It was scary, though I have only done springs a couple times before. I would not do it again, I would try to find a shop that you trust to do it for a reasonable price.
I found the instructions below and have added some changes.
INSTALLATION INSTRUCTIONS (with Mods)
Note: Spring kits are to be installed on vehicles with stock suspensions only.
Installation images corresponding to numbered process steps on next page.
1. Jack the front of vehicle in accordance to manufacturer recommendation and support frame with jack stands, remove the front tires/wheels. Start on driver’s side
2. If equipped with front ABS brakes, disconnect ABS connecter [coil lead up against caliper], remove ABS lead and brake fluid line from where they mount to the upper control arm and spindle.
3. Remove tie rod nut and separate tie rod [this can be accomplished after nut has been removed by repeatedly striking the end of the steering knuckle with a hammer; do not strike the tie rod threads]. Use a gear puller to separate. Tap on knuckle with a hammer will applying gear puller pressure. If necessary, apply PBBlaster or similar to the joint to help it break free..
4. Remove bolts securing brake caliper assembly, slightly depress brake piston to make it easier to reinstall, remove caliper and tie up/support assembly to the side.
DO NOT ALLOW IT TO HANG UNSUPPORTED BY BRAKE LINE.
5. Remove brake rotor [remove and discard factory set/lock washers if present].
6. Remove the front sway bar end links, both L & R sides, where they connect to the lower control arms, this allows the bar to pivot if needed.
6a. Bolt an impact socket (I used 1-1/16") to the bottom of the control arm. This provides a "post" that protrudes below the control arm that will fit in the floor jack "dish" so the jack won't slip out from under the control arm when the control arm swings down past 45-degrees when removing or installing the spring.
7. Remove shock absorber upper and lower mounting nuts, drop and remove shock.
8. Position ample support under the lower control arm and lightly compress the coil spring.
8a. Loosen lower control arm bushing bolts
9. Loosen the upper ball joint nut and separate the ball joint from the spindle [this can be accomplished after nut has been loosened by repeatedly striking the side of the spindle adjacent to the ball joint with a hammer; do not strike the ball joint threads]. Use a gear puller to separate.
10. Slowly back off the support from below the lower control arm decompressing coil spring in a controlled manner, with tension released remove the ball joint nut.
10a. Use a cargo tie-down with hooks (or a bungee or some other means) between the steering knuckle and the upper control arm to keep the steering knuckle from flopping around. Or you can remove the brake disk to lighten the knuckle assembly, but this was more work.
11. To assist in the installation of the new spring, note the coil springs seated position and remove. Remove factory rubber spring isolator(s) and re-position onto new spring, match up old and new springs, look for unique features to identify the top vs. bottom.
12. Install new coil spring taking note to re-seat/index it the same way as was noted above.
13. In the opposite manner to its removal, now raise the lower control arm/coil spring to allow the upper ball joint to be reinstalled into the spindle. Clean ball joint post and hole surfaces.
14. Reinstall shock absorber, remount brake rotor. Reinstall caliper assembly; bolt it to spindle using a suitable thread locker. Reinstall tie rod to steering knuckle (Clean tie rod post and hole surfaces). Clamp knuckle to control arm to get the tapered post to seat; this holds the post in place so you can tighten the nut. Reattach ABS lead mounts and connector and reattach brake fluid line bracket mounting positions.
15. Refrain from reattaching sway bar end link until steps 2-5 & 7-14 are repeated on the passenger side. Once completed, then reattach sway bar end links at both sides.
16. Install the front tires/wheels. With installation completed lower vehicle.
17. Ensure torque values of all nuts/ bolts affected by spring installation are per manufacturer recommendation.
Old 07-26-2018, 01:33 PM   #25
Yes, DIY with coil spring compressor. I think the coils can be removed from the outer or inner side of the suspension assembly. I think you have to use the spring compressor if doing the work from the inner side. Peteco's method above is from the outer side. I did it from the inner side.
- Vehicle front supported by stands.
- Removed sway bar link ends.
- Support the lower arm with a jack.
- Removed the shock absorber.
- Used an OTC 7045B Front Coil Spring Compressor to compress the coil.
- Dropped the lower arm by removing the pivot bolts.
- Removed the coil.
- Compressed new coil and put it in place leaving spring compressor on.
- Then the real fun part began trying to get the lower arm / pivot bolts to line up!
After that it was pretty much reversing the steps to finish up.
I'd tackle replacing coils again if I had someone helping otherwise I'd pay to have a shop do it.
Old 07-26-2018, 02:55 PM   #26
Thanks. I have only previously done this from the "outside" never occurred to me to try it the other way. If I undertook this then I would at the same time likely do shocks, ball joints, sway bar bushings, tie rod ends etc one of my main reasons for doing my own work is so I can spend money on good parts. This doesn't sound too horrible, I may give it a go.
Old 07-26-2018, 06:09 PM   #27
I think the need to compress the springs is year dependent. The pre 2003 models like Marko has would need the spring compressed to get it in, but after that a stock length (which a the 81004 is) spring can be put in with Petco's method.
It is very, very close to not going in though, and needs to be done from the outside. It is a bit scary when you start to lift the lower A arm to compress the spring as the spring is just barely engage in the A arm spring cup. You might even consider putting a strap on it to hold it in so it can't pop out. Certainly stand clear and leave room if it does come out.
Old 07-26-2018, 06:38 PM   #28
My C190 is a 2004 built on a 2003 chassis. Hopefully it would be able to change them out without compressing the spring. If it was just the springs I might consider paying somebody, local GM wants $300 to do the work. However, I look at as an opportunity to pull the whole front end apart and replace everything. That sort of labor charge I will not pay. I just hate those darn spring compressors had one slip on me once and have never liked them since. I have a nice long handle on my floor jack and can certainly stand way out of the way when starting to jack up the a-arm.
Old 07-27-2018, 01:54 AM   #29
Following!!!
Rockwood27 is offline   Reply With Quote
Old 09-13-2018, 03:24 PM   #30
Default 81004 springs vs GM equal and front sway bar?
Hi I am new here and appreciate all the tech tips. being a life long engine and car builder, this is my cup of tea. I have just purchased my 1st 2018 RT 210 and on the way home from the purchase across the US. I noticed immediately all these issues. I have owned a 2003 3500 cargo van for 15 years so I know how it could and should ride and handle. My question is has anyone ever tried the GM equal spring to the 81004? I see these are the Moog Duramax springs.
I have access to alot of new take off Gm parts, so thinking of trying the GM D max springs. Also wondering about running a little larger front sway/stabilizer bar. GM also shows 3 different rear leaf springs for the rear. 9600, 10, 000 and 11000. Curious if anyone had tried the 11,000? Once again I have access to alot of these parts and always like to dabble in the untested waters. At least based on this post I know what has worked. Thanks for all the great info. Shaun
valvegod is offline   Reply With Quote
Old 09-13-2018, 03:54 PM   #31
Welcome Shaun to the forum. You will be a great asset here with your access to GM parts information. I saw your post on the Chevy RT facebook page. Your RT 210 is a very nice looking B. I gather that RT is not making very many Chevy B's anymore. Do you plan to mod your RT soon?
Old 09-13-2018, 05:56 PM   #32
What's the chassis year of your 210? Did you opt for the aluminum wheels or did you stick with the factory steel wheels?
Can you describe the ride issues you've observed in more detail?
Old 09-13-2018, 08:02 PM   #33
.....................My question is has anyone ever tried the GM equal spring to the 81004? I see these are the Moog Duramax springs. I have access to alot of new take off Gm parts, so thinking of trying the GM D max springs. ....................
Do you know the part # for the Duramax coil springs? (maybe 19237856 ??)
I had previously found these interchange part numbers & adding a GM number to the list would be nice.
Moog 81004
ACDelco 45H0340
Napa 277-3435
Husky SC20468
Raybestos 585-1340
Part Number..Inside Dia..Bar Dia..Spring Rate..Load..Install Height..Free Height
81004........ 4.068...... 1.031 .... 1570 .... 5934 ..... 14 ......... 17.78
Old 09-13-2018, 08:34 PM   #34
When we were doing all the original searching for springs that would raise up the front of the Chevies, I tried everything and every trick I know to find out what the specs were on the various GM springs. Nobody I found had ever seen one that was bigger than 1.0 inch diameter wire, either.
The 81004 is 17.75" tall and 1.03" diameter wire with about 8 turns of wind. The number of turns of wind might make it so there won't be an actual GM spring that is the same, as all the ones I have seen use lower turns, in the 6 to 7 range. This saves them material and gives them more spring rate at any given wire diameter. It usually also reduces longevity.
If the OP has actual access to the parts themselves, he may be able to find something by measuring everything he can find. Springs are quite easy to measure quickly.
Concerning the sway bar, I would say don't increase the front bar diameter as that will increase understeer which you already have too much of in loaded Chevy van. What you need is a rear swaybar to reduce understeer and rocking.
On the rear springs, some folks have changed to different springs, some at higher rate, some at similar max rate but without a designated overload leaf. Personally, I am not a big fan of a spring change, but it can be better for ride if you get a standard style spring pack that doesn't use an overload leaf. You don't need the overload leaf as a class b is relatively constant weight so the springs can be made to match that weight. Your 210 will have 2" lift blocks in it to address sag, which IMO is not a great way to go. The most common rear spring change is to add airbags which can lift the van to get the monster overload leaf not hitting the rest of the spring back. This can reduce pitching and noise from the rear. On our 190P, we are currently running an experiment where I removed the overload leafs and used Airlift bags that have internal beehive bump stops in them. We have been very happy with the change so far, as it is smoother and quieter in the rear by an noticeable amount. We have about half the rear weight on the now smaller Chevy springs and half on the airbags.
Old 01-28-2020, 12:08 AM   #35
Ron, what shop did this for you in NC? We also need it done to our 2007 210p. Ruth
Melovetobake is offline   Reply With Quote
Old 01-28-2020, 02:17 AM   #36
The firm that did my complete installation was: All In One Automotive, 618 Julian R. Allsbrook Rd, Roanoke Rapids, NC - PH: (252)537-7150, www.allinonestyling.com.
They are a small firm, recommended to me by the local Chevy Dealer. I will pass on that they are totally great...will not bring you in until they are definitely ready to do the job, I was impressed "we will call you when we are ready to do it." Then the call came on Friday afternoon to bring it in first thing Monday, it was ready Tuesday afternoon, and I have not had a problem since then. Ron
Ron J. Moore
'15 RT210P
Old 01-28-2020, 04:31 PM   #37
Thank you Ron.
Old 01-30-2020, 06:52 PM   #38
Ron, I’m thinking about updating my 2014 RT 210P (2013 chassis) with the Moog 81004 front springs and Airlift bags on the back. I talked to my shop this morning. Their only concern was if the approximate 2” lift would cause the shocks to top out. Have you had and such issues with your 210? Jim
Old 01-30-2020, 07:05 PM   #39
2" of lift will not top out the shocks unless they are shorter than stock ones. 2" up for most Roadtreks give just the right ride height to match the factory spec for ride desired ride height, so right where it should be for best steering and suspension geometry.
You should be aware, however, that recent installs of the 81004 have come out substantially higher than 2" of lift, or about 35.5" at the front wheel lip. We don't know why this is and haven't gotten an answer on it to this point. Previous installs were right in the 1.75-2.0" range, so something in the springs changed, it would appear.
Perhaps it would be worth a call to Moog from the shop, to ask that question to see what they say, but as it stands right now, I think you should count on 3+" of lift, which would be on the edge of shock topping and also for best range of steering geometry and adjustability.
Also, be aware that the Chevy shocks do top out regularly, even at lower heights, in large down travel situations as there are no built in bump stops in the system. As long as the shocks are not too long to allow too much downtravel and frame contact of the upper A arm, this is perfectly normal. Of course, if the van gets too high, downtravel will be so short they will top on much smaller bumps and that is not good.
Old 01-31-2020, 04:26 PM   #40
First, thanks for the great recap. I will take your info to the tech and see if he can get some feedback from Moog. Getting it right is more important than doing it fast. I’ll pass along any information I get. Jim
2014 Roadtrek 210P
