Old 05-16-2018, 03:36 PM   #1
Question No roof room for satellite dome - help
I'm taking delivery on a Roadtrek CS Adventurous XL with 470W of solar panels. It has arrived at the dealer and they tell me there is not enough room on the roof for a Winegard Roadtrip T4 dome (or any satellite TV dome for that matter.) I'd rather not use a carryout (interior space consumer, may walk off, may drive off and forget etc.) Does anyone have any creative ideas for mounting the T4?
There is no ladder and the semi truck mounts I have seen all use the vertical flat space on the back of the cab - I don't have any vertical flat spaces high enough other than the back doors (window actually) and the vehicle sides (probably not a good idea.) I'd hang it off the back over the backup camera if I could find a mount that worked but haven't found anything yet.
Hoping someone else has solved this problem??
Any help appreciated.
B Living is offline   Reply With Quote
Old 05-16-2018, 05:24 PM   #2
Does your RV come with roof mounted TV antenna? You can remove it and place satellite instead. If your entire roof is taken by solar, maybe you would need to remove one of the panels to free up space.
netscorer is offline   Reply With Quote
Old 05-16-2018, 08:47 PM   #3
Good thought. I may need to go that route. I asked Roadtrek support and they suggested I move the rear solar panel to the top of the AC unit and then use the space that freed up at the back of the RV for the dome. I'm checking with the dealer to see if they can make that happen.
Has anyone had experience with a solar panel on top of their AC unit?
Old 05-16-2018, 08:50 PM   #4
RT has done that on their Agile RV, which is based on the short wheelbase Sprinter. When a customer requests additional solar panels, there is no room except on top of the AC unit.
Old 05-16-2018, 08:58 PM   #5
Not that you asked, but:
Satellite dishes are so 20th century. Unless you routinely camp where there is no cellular service, you might want to consider investing in a good MiMo LTE antenna connected to a MiFI hotspot. Virtually everything you can get on satellite can now be streamed using your existing satellite subscription. A good antenna setup can get good service even in very marginal signal zones.
Old 05-16-2018, 09:18 PM   #6
warpig's Avatar
I agree with Avanti. I'd also invest in an unlimited data plan and use the phone to stream the video to the TV.
Wannabee (hopefully someday one of following):
SC XL21 Plus (dream)| WBO 59G| Aktiv 1.0| Axion
warpig is offline   Reply With Quote
Old 05-21-2018, 08:11 PM   #7
Please no smart remarks, but have you thought of mounting it off the 2" bumper hitch? All you would have to do is weld an L shaped piece of 2" tubing, then whatever would be needed to mount the dish at the top.
RUFFNIT is offline   Reply With Quote
Old 05-21-2018, 09:14 PM   #8
warpig's Avatar
My guess is the body of the van would block the signal of the satellite.
Old 05-21-2018, 09:43 PM   #9
warpig's Avatar
This is from the Roadtrek & Hymer Owners Group FB group. It is closed so I took a screenshot. This is a cool idea similar to what RUFFNIT suggested.
Old 05-21-2018, 10:39 PM   #10
My thought was to make the vertical part as high as the roof line. You could make the vertical part telescoping so that it could be removed and stored during transport.
Old 05-22-2018, 12:51 AM   #11
Winegard sells a permanent bracket you can attach to the vehicle to mount the antenna to the vehicle when parked. Put the bracket just below the roof line and the dome will be above the roof and should be able to acquire the signal. Uses the same mounting as the window mount shown above, I believe.
Old 05-23-2018, 02:38 PM   #12
How about mounting the dome on top of the A/C unit? It might need a bit of reinforcement.
Old 05-23-2018, 05:20 PM   #13
I don't know why,
somehow i found that funny.
No offense.
Old 05-23-2018, 06:01 PM   #14
I don't know why,
No offense.
Not going to look pretty IMHO. I think a portable unit might be a better choice if storage is not a factor, you can move it around to acquire a better sat. signal.
Roadtrek Agile SS: Roadtrek Mods.
https://i42.tinypic.com/dwrjpi.gif
RT.SS is offline   Reply With Quote
Old 05-23-2018, 08:27 PM   #15
Boxster1971's Avatar
I don't know why,
No offense.
Yes - a dome on top of the A/C would look unusual and be very high. I mounted a flat TV antenna on top of the A/C unit to make room for more solar panels. Here is photo.
Old 05-23-2018, 08:46 PM   #16
You have a reversed MaxxAir
Old 05-23-2018, 09:56 PM   #17
thus MaxxAir
Old 05-23-2018, 09:59 PM   #18
Yes I do. Needed room for solar panels. Not recommended by MaxxAir. Been that way since 2014 and over 60,000 miles. Can't leave it open when driving and did have it pop open one time last year because the gear mechanism was well worn. Replaced the gear box and added a sunroof wind faring shown as in attached photo to reduce wind load on fan cover.
- - Mike
Old 05-23-2018, 10:37 PM   #19
Thanks. All good thoughts. I think initially were going to try cell modems (AT&T and Verizon) and available wifi (if places have it) and see how that works. If we find ourselves missing too many Cubs games (the real reason we need satellite) we'll probably either use a carryout (if we have space to store it) or may opt to move the solar panel on the AC unit and use that space for a more permanent mount.
Old 05-23-2018, 11:31 PM   #20
As I said, do not underestimate how much of an improvement you would get from a proper MiMo antenna on the roof. Much, much easier than a sat dish.
installation, roof space, satellite dome
