Old 10-12-2015, 06:34 PM   #1
Default one too many batteries? mostly bored ramble
hi all,
anyone have a creative use for the (originaly placed) house battery that never gets used?
i have a 94 pleasure way that came with the usual rv/starter house battery charged from the alt or on shore power.
over the past year iv added 200 watts of solar with 2 6volt batteries.. this system is seperate from the stock sys right now and runs everything in the rv. and only recharges from the solar..which works fine.
the original house battery just sits there..charging from the alternator and waiting for me to think up a cool use for it.
i keep thinking ill pull it out to save weight etc. but thats not a big issue.
i had thought of using it as a spare emergency starting battery...but unhooking and replacing or running the big cable back up front killed that idea for now.
and i cant really combine it with the 2 6volts
anyone have a interesting idea for this odd man out? or should i just pull it and use the space for a safe or hideyhole?
enough rambling..thanks
ander
ander is offline   Reply With Quote
Old 10-12-2015, 10:34 PM   #2
If you keep the battery in place you can use a jumper across the isolator posts for emergency battery boost.
Old 10-12-2015, 11:13 PM   #3
its only 8 guage form isolator back to battery..about 18 foot...is that big enought to handle that? thats whats allways worried me.
thanks
Old 10-13-2015, 01:29 AM   #4
Bruceper's Avatar
Certified Booster Cables, 8-ft, 10 gauge | Canadian Tire
Eight foot only, but 10ga wire. Many cheap booster cables use 10 and 12ga wire. They work fine in normal (summer) conditions but when it's 40 below and you need to crank with some frozen oil you might as well just give up lol
Short answer. Yes it would work.
Old 10-13-2015, 01:36 AM   #5
if i ever find myself in -40 weather im setting the rv on fire to keep alive
Old 10-13-2015, 11:14 AM   #6
lol
Scottbaldassari is offline   Reply With Quote
Old 10-13-2015, 12:04 PM   #7
You could make a temporary connection to let the good battery "charge" the low battery then remove the jumper before cranking the engine.
Thread Tools
Display Modes
