-   -   No spare tire (http://www.classbforum.com/forums/f5/no-spare-tire-3551.html)
mass59k 05-30-2015 07:04 PM
No spare tire
Our Winn Travato 59k has no spare..did get repair kit with compressor...haven't looked at it yet. Wondering what experieces some have had with flats...what service provider do you think is best???
avanti 05-30-2015 07:29 PM
Re: No spare tire
11 years of Sprinter ownership. Never had a tire issue of any kind. Carried a spare in our old rig. Never touched it. We have a spare for our current rig, but no carrier, so we normally leave it at home to save space. Lose no sleep whatsoever over it. I suppose when and if we head to Alaska, we will probably take it.
Best choices are pretty clearly Coachnet or Allstate RV Motor Club. AAA's RV service is expensive, mediocre, and not available nationwide. Good Sam is simply a reseller of Allstate. Allstate (which is what we currently have) was cheaper than Coachnet last time I checked, but I recently read that they have some good deals now. They apparently have a US-based call center, which is probably worth something. I may switch to them next time.
wincrasher 05-30-2015 10:33 PM
Re: No spare tire
I don't worry about a spare either. My van has a fairly common tire size for pickups, so I'm not concerned with getting one on the road.
If I were making the trek to Alaska, it would be a good idea to buy a bare tire and stash it somewhere - maybe on the roof.
If you really are concerned about having one always, Roadtrek is offering a continental kit for their Promaster based Zion. Surely it's simply a bolt-on to the rear door. So maybe you could order the parts from them and bolt it on your Winnie.
gerrym51 05-31-2015 12:42 AM
Re: No spare tire
it needs a hitch-roadtrek uses a side hitch behind the drive side door but you could put it behind your middle hitch. you could also use this-i've heard good things about it
http://www.tiregate.com/hg-series/
coachnet
bobojay 05-31-2015 12:51 AM
Re: No spare tire
Coachnet or Good Sam roadside. With Coachnet being the preferred. You have 1yr of Winnebago roadside with your new 59K
obgraham 05-31-2015 05:45 AM
Re: No spare tire
My Roadtrek CS has a full size spare carried underneath.
However, in case of a tire failure, my plan is to call CoachNet and have them send someone to change it out. I'm too old and fat to do that job now.
Viperml 05-31-2015 10:11 AM
Re: No spare tire
When I get my rig if it does not have a spare tire then I will do something like tiregate which gerrym51 posted.
Also, to make things easier I think I will carry the rapid jack.
http://www.amazon.com/Andersen-Manufact ... op?ie=UTF8
https://www.youtube.com/watch?v=15SseSKHNH0
mass59k 05-31-2015 10:12 AM
Re: No spare tire
Big thanks for the replies...will they bring a tire with the ....have Promaster chassis..think tire/rim is common
gerrym51 05-31-2015 12:53 PM
Re: No spare tire
i don't see how the rapidjack would work on the van. it appears you need 2 tires close together? i do know you have drw on cs but it seems this could only work using inside tire taking off outside tire in rear?
gerrym51 05-31-2015 12:56 PM
Re: No spare tire
it is a common tire-however the tire also has to get on a rim. if you depend on them to have a tire you are also depending on having a rim, or the ability to put tire on your rim.
