-   Practice your forum skills here (http://www.classbforum.com/forums/f21/)
-   -   test my pic (http://www.classbforum.com/forums/f21/test-my-pic-7696.html)
Picasso_taco 05-19-2018 03:13 AM
test my pic
1 Attachment(s)
Anyone have any experience replacing a rear side window in a 2003 Roadtrek 190.
Thanks
Bob
604eholston@charter.net 06-01-2018 03:28 PM
Bob, your picture is fine. I have no idea how to replace the window, though.
TC8 06-01-2018 05:06 PM
Rear window removed
1 Attachment(s)
I had to repair the lower wing window it had fallen off itís top hinge. You have to remove all the screws from the inside of the window frame. The window then comes out from the outside. Itís actually a very easy job.
jmai 06-01-2018 11:10 PM
What did you use to "glue" back the window to the hinge?
Also, did you need to re-attach the brackets (the ones that go on the round wheel at the end of the arm) to the glass?
TC8 06-02-2018 06:55 AM
I used 3 m windshield adhesive
https://www.amazon.com/3M-08609-Wind...hield+adhesive
The lower side brackets that hold the wheel to open the window did not detach Luckily.
TC8 06-02-2018 06:58 AM
Glue rear louvre window
1 Attachment(s)
Clamp window glass to hinge.
jmai 06-02-2018 11:13 AM
Thanks for the info.
avanti 06-02-2018 02:07 PM
Do you guys really want to carry on a substantive discussion in the practice area? I don't think very many folks follow it. :hide:
