-   Electrical | Charging, Systems, Solar and Generators (http://www.classbforum.com/forums/f23/)
-   -   Inverter clunking when plugged in. (http://www.classbforum.com/forums/f23/inverter-clunking-when-plugged-in-7814.html)
Toolman0114 06-15-2018 10:20 PM
I gave a 2018 Carado Banff, (Hymer, Road trek) and when I plug Into AC and turn on the inverter, it makes a clunking noise randomly.
I realize there should be a click, but this is a loud clunk.
What’s wrong?
BBQ 06-15-2018 10:31 PM
What’s wrong?
Take it back to the dealer; that's what warranty is for.
ps. do you smell any smoke?
Hatteras Jim 06-22-2018 10:46 PM
Not sure what size inverter you are using or how yours is constructed.
Maybe nothing is wrong with it.
My guess is what you are hearing is the "inrush current" to the transformer. You can google it for a detailed explanation. Doesn't happen all the time as it is in your case. I still would contact the dealer in case something happens; but, don't be alarmed if nothing is found wrong.
I've been using one that clunks every so often for over 25 years without a problem. In my case, if I energize it without a load it doesn't seem to clunk as much.
Your nose should tell you first if something is amiss.:)
