View Poll Results: Do you use synthetic oil?
Yes, I use synthetic oil. 11 61.11%
No, I use regular oil. 7 38.89%
Voters: 18. You may not vote on this poll
Old 09-09-2011, 12:21 AM   #1
Default Do you use synthetic oil?
Old 09-09-2011, 06:40 AM   #2
g1g
Default Re: Do you use synthetic oil?
I have used Mobil 1 in everything since it came out including my lawnmower. On one car I overheated it and it was fine as was going out and starting them when it was 22 degrees below freezing. In one car I tore off the cylinder head after almost 100,000 miles and there wasn't even a ridge around the cylinder. On more than one occasion I forgot to change my oil when i should have but thanks to synthetic all is fine.
