Old 09-13-2011, 12:44 PM   #1
Bronze Member
Default Pleasure Way Ford Owners Manual
Please find attached the Pleasure Way Ford Owners Manual I received from Neal at Pleasure Way. It is in 2 parts due to file size.
Thanks,
Bb
https://i517.photobucket.com/albums/u...20TS/th_RV.jpg
Gail and Bill Burkett
Jupiter, Florida
burkettwh is offline   Reply With Quote
Old 06-24-2017, 01:14 AM   #2
Default
Thank you for the manuals!
I just bought a 2003 Ford Excel TS yesterday and the color pictures in this manual help a lot
I do have a question that you may be able to answer about the dump valves. In my RV, both handles are black so I don't know whther the grey tank is the top or bottom handle. Can you help?
Thanks.
Road Tripper is offline   Reply With Quote
Old 06-24-2017, 02:04 AM   #3
Default
if both tanks are empty...dump a gallon of water in the toilet and see which handle gives water.
or- the grey tank valve is physically smaller diameter than the black tank valve- have a look underneath at the 2 valves.
your grey tank is likely on the pass side and a piece of 1.5 or 2" black pipe will be coming across under the van from the tank to your smaller valve
mike
mkguitar is offline   Reply With Quote
