Old 07-19-2009, 10:05 AM   #1
Default How to remove Roadtrek air conditioner
Hi,
I have a 2000 Roadtrek 190 Popular. I need to replace the fan in the Fedders air conditioner. I asume it should be removed from the inside. It sure looks like it is a tight fit with not much room to slide out. I hope someone on the forum has removed theirs and can help me in the step by step removal of mine.
Thanks, Sunsine in TN
sunshine is offline   Reply With Quote
Old 07-19-2009, 02:13 PM   #2
Default Re: How to remove Roadtrek air conditioner
I hope someone in the group here can help. If not, you should try the RT Owner's Group at Yahoo and do a search there (use: removing air conditioner) - you will get some good info (msgs 27791&93). Also, there in that section there is information on the size WellNuts used, if and when you have to pull the outside cover. Keep us posted on your task at hand. Ron J. Moore
Ron J. Moore
'15 RT210P
Old 07-19-2009, 05:46 PM   #3
I've attached instructions from Roadtrek. It may not be for your model but I'm sure it will help.
File Type: pdf ROADTREK REMOVE AND REPLACE AIR CONDITIONER.pdf (101.0 KB, 1458 views)
Old 07-20-2009, 08:52 AM   #4
That's exactly what I needed. Much thanks Mr Moore.
Sunshine in TN
Old 05-04-2017, 05:38 PM   #5
Default
thanks for info . I am a newborn here so I hope you get this thanks.
Bobyacht is offline   Reply With Quote
Old 06-29-2021, 03:11 PM   #6
Default
Could you send me the doc on how to remove roadtrek ac from 2000 chev roadtrek 200 I think because of the fireglass roof it has to be done from the inside I can't seem to pull it up the pdf that is attaches
Sheila is offline   Reply With Quote
Old 06-29-2021, 06:15 PM   #7
Default
Thank but was able to download onto laptop
