Old 08-22-2013, 10:15 PM   #1
Default 12V toggle won't turn off battery
Greetings all,
The 12V button that toggles the house battery off and on is not working. After pushing it the battery remains on instead of turning off. With the button to the left the battery should be off, but it seems stuck to the right with the battery on. It is a 2006 Leisure Travel Free Spirit. Has anyone has this problem and is there an easy solution?
It's in the driveway right now and I can plug it in, but we are leaving tomorrow and will be boondocking.
LInda
lelvin is offline   Reply With Quote
Old 08-22-2013, 11:50 PM   #2
Default Re: 12V toggle won't turn off battery
Lots of Class B RV's have an Intellitec Battery Disconnect relay.
From the service manual: http://www.flemingsalesoem.com/intellit ... 9100-2.pdf
Relay won't disengage:
- Check fuses on relay
- Check battery voltage, must be greater than 10.5 volts
- While switch is engaged, check voltage across the coil terminals (+ on the "S" terminal and ground on the "I" terminal) If 0 volts, replace panel, if + voltage, replace relay.
The switch can be located far away from the actual relay and would look similar to this:
Old 10-21-2014, 11:04 PM   #3
Ron
Thanks Mark.
Ron
Ron & Rose Cabral
New Bedford, MA
2010-Chevy/RT-190P
FMCA:303873 ~K1RRC~ RRRCRT@aol.com
Ron is offline   Reply With Quote
