Old 10-09-2020, 07:16 PM   #1
Default Need help in SF Bay Area, switching to lithium
2008 Roadtrek Sprinter. I've purchased two Renogy's and an inverter. If you have experience, please drop me a line. Well paid.
Thanks -David (415) 495-4585
david@davidfischer.com is offline   Reply With Quote
Old 10-09-2020, 08:17 PM   #2
If I were nearby, I'd offer my services for free because that's about what they are worth. But I did a similar conversion on my Chevy Express Airstream Avenue Suite last year. I can barely read schematics, so I just carefully determined what original wires went to what and carefully re-routed them to my new 2 X 100Ah Renogy lithium batteries and 3000W Inverter/Charger. No sparks or flames and it's worked well for the past year.
You'll want to include a DC to DC charger between your lead-acid engine battery & alternator and your new lithium coach batteries. Also, you need a Battery state-of-charge (SOC) Monitor to track charging and draw from your new lithium batteries as voltage alone only works with lead-acid for assessing the battery charge state at any given point. I used Renogy components for each.
Here is my crude wiring drawing plus a diagram I made from a screen-shot from a Renogy video.
Note: I originally used 4ga. wiring as it was the original gauge. I later upgraded to 4/0 wiring which was a huge overkill and hard to work with. 1/0 gauge is a good compromise while still being mild overkill.
Old 10-12-2020, 02:09 AM   #3
New member TaxWonk just posted this.
https://www.classbforum.com/forums/f...tml#post119234
Old 10-18-2020, 09:25 PM   #4
Originally Posted by Lauraetuck@aol.com View Post
Guy who runs the service is Gordon. My experience w him has been terrific. Tell him Dr. Laura Tucker referred w Carado Axion.
Other person is Dan Neely Mobile RV services — he’s around SF a lot and has a good reputation. Good luck, Laura
Welcome to the forum Dr. Laura!
Great and helpful first post.
Old 10-19-2020, 03:45 AM   #5
Gordon's shop put front and rear Sumos on my SS Agile. Great shop and great people working there. I recommend them as well.
Boondocker is offline   Reply With Quote
