Old 10-24-2021, 08:55 PM   #1
Default Wanted: two good RT front capt. Seats or covers, repair
Our 1995 RT Versatile needs some work in the front seats. Drivers needs foam and restitching, then a cover- or a new/used seat if I can find it.
Starboard- passenger side needs a matching cover (if we go that route) and some adjustments to the floppy armrests, or replacement.
We are in AZ , travelling much if the SW is very doable.
Also starting to look for replacement clips for a few broken ones or maybe a new set of window coverings.
Koyote is offline   Reply With Quote
Old 10-24-2021, 11:46 PM   #2
On my Pleasure way/ chev I got new foam from the seat shop
they carry for many models
replacing was easy, removing seat from van then removing cover.
my cover was/is ok, just gave it a good shampooing
plenty of upholstery shops can create a new cover for you, using yours as a pattern
if you just need "bits" Fabric Depot 16803 N Cave Creek Rd, Phoenix, AZ 85032 carries all kinds of automotive upholstery stuff, also rubber door and window seals
Old 10-25-2021, 05:28 AM   #3
Or you might try DICK'S AUTO PARTS.
https://dicksautoparts.com/c-1144216...oem-seats.html
Old 10-25-2021, 05:48 AM   #4
omitted that https://www.theseatshop.com/ products are available at their website or amazon
I went with their "durofoam" replacements
mike
Old 10-25-2021, 06:02 AM   #5
I will look. I have a torn seam and a fabric tear on the driver's seat in addition to collapsed foam. And a spring popped in the back
I need to see if I can tighten the armrests
