Old 01-13-2022, 05:01 PM   #41
Originally Posted by MsNomer View Post
Now you have two pans to wash. We have zero.
That's probably true depending on if you heat in the microwave using disposable bags or containers which would also have to be washed. But it's beside the point. My post, directed at the OP, was to point out that you don't have to sacrifice home prepared meals if you don't have a microwave.
Old 01-13-2022, 05:53 PM   #42
I just ate a breakfast sandwich of sausage and egg from frozen to microwave this morning satisfactorily. Not much different than a McDonald's offering. Quick no mess, no cleanup meal. I May rethink what we hold in our freezer underway.
Old 01-13-2022, 06:48 PM   #43
Just an opinion but you need a large battery bank and/or a generator to bother with a microwave. I, too, choose microwave. Very handy.
Old 01-13-2022, 08:21 PM   #44
Depends how you need or use your microwave. if you heat a cup of water for tea or instant coffee you probably don't need a large battery bank if your inverter allows it. Otherwise, without shore power you would need a generator. Large battery banks go hand in hand with inverters capable of handling a microwave and you don't need shore power or generator to do most all cooking you would normally do with a microwave or even longer with a convection oven. You can always use a microwave on shore power or Onan generator which for most of my Class B life back to 2005 was normal use when most Class Bs had one lead-acid battery of a little over 100ah but had a microwave.
Old 01-13-2022, 08:32 PM   #45
It appears that Thor is offering as standard 2 lithium 100 amp batteries with a 3000 watt inverter. Anyone know why 3000 watts, seems like...............
I assume that the Microwave uses 'some' of the 3000 watts.
I listened to a Coachmen Beyond with the ac running powered by about a 260 watt agm battery. I suppose one could have added some more agm watt hours.
Old 01-13-2022, 08:39 PM   #46
A 1500 watt inverter works well for my 1100 watt microwave. I think I saw it draw 110 amps from the two lithium batteries I had at the time.
Old 01-16-2022, 12:54 PM   #47
Default Toast in a Convection Microwave? Advice please.
I'm choosing between a convection microwave oven for a 144" Sprinter, vs a microwave + separate toaster oven.
Toast is very important to me. I'm wondering if convection microwaves are well-suited to making toast, or if I would be better off with a conventional microwave and a separate Breville for toast, pizza reheating, and other food that doesn't do well in a microwave.
I've never seen a convection microwave.
Vanstertails is offline   Reply With Quote
Old 01-16-2022, 11:24 PM   #48
Arlo's Avatar
I’ve had only one microwave+convection oven (in my previous van), but based on that experience vs my current setup my advice is to go with the Breville oven if you want good toast.
Old 01-18-2022, 11:00 AM   #49
David, how did the Ninja work out for you? Any chance it could replace an induction cooktop and cookware?
Thread Tools
Display Modes
