Old 11-25-2022, 05:09 PM   #1
Default Embassy SL Class B RV
Now that we've had our Embassy SL Class B RV for a little while, thought I would add a review...
The Embassy’s are built with no wood, therefore no mold worries. Also, the entire build uses marine grade vinyl, so no worries about things getting wet either. Some people will love this but some want more options for colors and finishes.
They all have uperior insulation… no worries at all about staying warm in winter or cool in summer. Heating uses the gasoline you already have in the tank, so no extra propane to deal with.
It’s also has a powerful battery system. We got the Mastervolt 920 Ah batteries, but you could spend a little less and get the Lithionics 630 Ah batteries. We like the extra power that lasts forever. It also has a second alternator so we can charge while driving or even more slowly when parked. No need for solar panels on the roof.
And it is STEALTH! Not a single hole anywhere on the body except for the 30amp plug. And since we have the split a/c system, no big a/c on the roof.
There are always issues of course, but nothing I can think of at the moment!
Be seeing you!
If the roads of life were a straight path, we'd all fall asleep at the wheel!
-- Roads of Life
Roads of Life is offline   Reply With Quote
Old 11-26-2022, 03:29 PM   #2
920 ah battery? How big is that? lol
2015 Roadtrek 170
2011 LTV Libero
2004 GWV Classic Supreme
Old 11-26-2022, 04:10 PM   #3
Likely big, but stealthy. This "review" lists main advertising talking points.
Old 11-26-2022, 05:49 PM   #4
Just saw ModVans has the largest available battery for class B van. 1000Ah to 2000Ah max. The entire van floor is the battery. Very interesting by doing it this way, the battery consumes very little space. About 1 inch for 1000Ah and another inch for the 2nd 1000Ah?
2016 PW Lexor TS
Old 11-26-2022, 06:49 PM   #5
Around 12k watt hours
-- Roads of Life
Old 11-26-2022, 06:49 PM   #6
Difficult not to. The things I like about it are the main features.
-- Roads of Life
Old 11-26-2022, 06:51 PM   #7
Very interesting... is this a 12 volt system?
-- Roads of Life
Old 11-26-2022, 07:15 PM   #8
Originally Posted by Roads of Life View Post
The Embassy’s are built with no wood, therefore no mold worries............
PSA: Mildew & mold don't need wood. Dust plus moisture will do it. It will form on synthetic materials also.
Old 11-26-2022, 07:27 PM   #9
True... but the wood in RVs is behind the walls, so not exactly easy to get to.
-- Roads of Life
Old 11-26-2022, 08:28 PM   #10
Boxster1971's Avatar
I really liked the Embassy RV design in general. But the toilet options, or lack of, was a deal killer for me.
Boxster1971 is online now   Reply With Quote
Old 11-26-2022, 09:28 PM   #11
What van did you decide to get instead?
The options for the Embassy are now the Laveo Dryflush or the Separett Tiny.
-- Roads of Life
Old 11-26-2022, 10:49 PM   #12
Yes, it is 12 volt. The only appliance requiring inverter is the microwave. Even the heating and hot water tank is 12 volt DC. You can order their largest battery and get 2000 Ah of battery but will lose another inch of height in van. The battery is integrated into the entire floor. Very interesting concept. They are not crazy about diesel or gas fired heating systems? Something about high altitude precariousness?
2016 PW Lexor TS
Old 11-26-2022, 10:57 PM   #13
Have not decided yet. I would have moved forward with Embassy RV if they still offered the cassette toilets. But they won’t do those any longer.
Old 11-27-2022, 12:54 AM   #14
Yeah... they had some major issues with macerators, so that kind of killed it for them.
-- Roads of Life
Old 11-27-2022, 12:55 AM   #15
"Something about high altitude precariousness"
Altitude does something to that kind of heating system, not enough pressure or something. I thought that was propane only though, but I could easily be mistaken. I usually am!
-- Roads of Life
Old 11-27-2022, 01:00 AM   #16
My cassette doesn't need a macerator.
Old 11-27-2022, 01:55 AM   #17
Embassy was using a cassette that went to a macerator so you wouldn't need to take the cassette out and dump it... nice idea, but didn't work out well...
-- Roads of Life
Old 11-27-2022, 02:11 AM   #18
“Cassette with macerator” is a very, very questionable concept, like a dentist working through ears. From my perspective “Cassette with macerator” just doesn’t make much sense, contrary to “Black tank with macerator” which does and is well proven as evident by large group of followers.
Old 11-27-2022, 02:17 AM   #19
That was a bit of a strange setup - one of the many things that Terry claimed were so good but were not.
But I just wanted a plain cassette toilet that I could remove the tank from back door. When I visited Embassy RV last year - they would not do a cassette toilet of any kind.
Old 11-27-2022, 02:17 AM   #20
Like I said... it didn't work out.
-- Roads of Life
class b, embassy, no wood
