Old 07-10-2020, 11:57 PM   #1
Default 2017 Roadtrek Simplicity No DC power
Hi all,
I have hooked up two 12v Battle borns in parallel to 2000w Kisae inverter. I get 120v output to coach but no 12v DC to power fridge, water pump ect.
GJorey is offline   Reply With Quote
Old 07-11-2020, 03:08 PM   #2
1. check that battery disconnect switch is on
2. check that you reconnected the wire from the coach batteries to the DC load center.
Old 07-11-2020, 04:04 PM   #3
As Mark said, you need a wire from the new batteries to your DC buss bar to get 12V power to your rv. In the case of my upgrade, this connection was previously made by a short jumper wire at the coach battery connection to the battery isolator (which was near the rear buss bar - not under the hood).
Since I was no longer using the original battery isolator in favor of a new DC to DC with lithium charge profile, it is now just sitting there disconnected. So I ran ran a new 4 gauge wire with an in-line ANL 40A fuse (or is it 60A?) from the lithium batteries to the power bar. Problem solved.
Don't know if yours looks anything like mine, but here is a picture of my prior jumper connection that I ran the new 4ga. wire to replace.
File Type: jpg 20190917_103428 captioned Large e-mail view.jpg (99.9 KB, 5 views)
